10-06-2016, 09:02 PM | #23 | |
B.E.
444
Rep 761
Keep in mind, the FI-Rs are my track setup, daily driving on stock ZCPs. So I might change it up to less aggressive cambers if I start going through my tires like there's no tomorrow and adjust it before tracking
Current: 2022 TRX & 2010 GT3RS
Past: 2016 M3 Individual Grigio Telesto Pearl, Sakhir Orange/Black Full Leather w/ CF trim, 6MT, ZCP, CCB, etc... Previous: 2011 E92 M3 Melbourne Red on Black 6MT ZCP. --> now 2010 dedicated track car |
10-19-2016, 04:31 PM | #24 |
570
Rep 1,234
10-19-2016, 08:42 PM | #25 | |
B.E.
444
Rep 761
19x10.5 et35 with 305/30/19 R888
10-25-2016, 10:28 PM | #26 |
Rep 56
So it's confirmed that this setup will work?
Front camber is -2.9, rear is -2.3 265/35/19 | 305/30/19 R888 KW HAS, vorsteiner vff101 , 5mm spacer up front to clear HAS collar. Front 19x9.5 offset 22 Rear 19x10.5 offset 34 What exact modifications am I'm missing? |
10-27-2016, 02:11 AM | #27 | |
3139
Rep 2,953
Confirmed, it works. |
10-27-2016, 01:24 PM | #29 |
B.E.
444
Rep 761
Doesn't bother me, but it's a little louder than MPSS. I swap them out at the track so can't really give you an opinion on highway driving. Windows are down at the track so there's a lot of wind noise that hides everything else
11-02-2016, 12:37 AM | #30 |
Rep 56
11-02-2016, 12:47 AM | #31 | |
3139
Rep 2,953
I am confident that you will have no issues. I believe Shmelgy just tested it out on the track with no problems |
11-02-2016, 12:56 AM | #32 | |
B.E.
444
Rep 761
As Justin mentioned, I have no issues
11-16-2016, 11:27 AM | #33 |
23
Rep 141
11-16-2016, 01:53 PM | #36 |
6586
Rep 5,305
JamesGames1326.00 |
11-16-2016, 01:56 PM | #37 | |
6586
Rep 5,305
The rear can go to -2.3 easily, but your toe settings will be very limited with that much camber. Toe arms might be a good idea if you want that much negative camber and good toe adjustment range. |
11-16-2016, 02:12 PM | #38 | |
1326
Rep 1,481
As far as rear camber I'm on stock toe arms / bolts and I have -2.3 rear with 1/8th total toe in or 1/16th on each side. |
11-16-2016, 02:30 PM | #39 | |
6586
Rep 5,305
Where did you go? Maybe I need to go to a different shop. |
11-16-2016, 02:38 PM | #40 | |
1326
Rep 1,481
When I had swifts, I went to Westend, and then when I got the coilovers I ended up going to Platteform AG. What I mean by the differences from shop to shop, when I had swifts, the drop wasn't as low as coilovers, but west end was able to get my camber to -2.0 in front (which I didn't understand how...) But then I went to platteform with my PSS10 and they were able to get only -1.8 because it was fixed. However both were able to get the rear to -2.2 to -2.3 with the toe I listed. Westend uses hand tools and platteform AG uses Hunter alignment rack for what it's worth. |
11-16-2016, 02:46 PM | #41 | |
6586
Rep 5,305
I wonder if there are any other good alignment shops out there. |
11-16-2016, 02:56 PM | #42 | |
1326
Rep 1,481
11-17-2016, 01:18 PM | #43 |
3139
Rep 2,953
Shmelgy has KW 2-way, another option is Ground Control or Vorshlag camber plates if you have springs already.
Yes. I've seen someone go as far as -3 |
11-17-2016, 11:29 PM | #44 |
69
Rep 128
So On my f80 I'm lowered on Macht schnell springs, I recently put 295/30/19 cup 2 tires on and with a 10mm spacer (stock 19s) under compression have rubbing in the rear. When I jacked the car up and looked in the wheel well I can see rubbing marks but only on the actual wheel well liner.
I took the rear spacers off for now but would like to put them back on should someone have any good suggestions. |
