05-23-2015, 12:15 AM | #23 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
Please don't shoot.........can someone define "detonation"?
05-23-2015, 05:19 AM | #25 |
831
Rep 3,387
05-23-2015, 07:43 AM | #26 |
64679
Rep 24,942
OP feel really sorry about your luck .
But I'm sure before the rod was making a black hole ...rattle noises were ignored or not heard ! And like almost all blown S65's the bearings were the basic problem of this blown S65 ! And personal I think it was "not" the smartest move to run the engine after the failure to move it into the shop ! But think this case is in experienced hands ? Would love to know more... About the video...Is it possible to post the video ? Thanks in advance... Edit : Can you please add here in the "Blown motors, Bearing failure S65 Registry." => http://www.m3post.com/forums/showthread.php?t=786615
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
05-23-2015, 08:32 AM | #27 |
274
Rep 2,665
Drives: Goggomobil
This is very interesting. Bearing failures. I think the culprit here is the oil pump and the pressure.
My experience to date has been, I've been running TWS 10w-60 for the last seven years ownership since new, and every morning when I start up, the car was extremely rough, and even revving was hard doesn't matter how many rpm it was, until the oil warmed up with the rest of the components. But since swapping to M1 0w-40, I have not experience this at all, and despite the rev limited set to 4k rpm for cold start, the engine revs freely, and have no issues (?) what I had with when using 10w-60. So I think, the oil pump was struggling with the cold thickness of the oil, and then squeezing that thickness through the hair-width edge was a struggle. Hence, more mettle-to-mettle contact and the roughness I was feeling. M1 0w-40 has I believe eliminated that. Time will tell when it come to BS analysis. I am planning to do 6k km on this M1, and another 6k km again just so that the engine is free of all the old TWS 10w-60. I think we need to factor is the oil pump to and the effectiveness of it with the thicker oil. Wasn't the oil pump redesigned from the S85 to be more efficient or something like that?
F86 X6///
05-23-2015, 09:40 AM | #28 |
NewFinishColumbia/detailer
604
Rep 2,096
Very good points. I patiently await your results with the 0-40.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
05-23-2015, 10:06 AM | #29 | |
64679
Rep 24,942
It's not really about the oil/spec...It's all about the design flaw of our bearings . Better is.... no matter what oil is used ...is oil change at max 5K . Personal I keep it with Castrol/Edge .
05-23-2015, 11:11 AM | #30 |
427
Rep 1,947
Rod big end blue again. I usually attribute that to clearance, which leads to bearing wear, which leads to bearing failure, which leads to excessive heat, which leads to boom!
Was the rod or cap welded to the crank? I'm still trying to see if I can use that crank, and the picture of the journal has me a bit worried because of what looks like the scratches on it, and the blue rod big end that went along with it. |
05-23-2015, 12:10 PM | #31 | |
31
Rep 120
no the rod moved freely on the crank after I unjammed it from the rod next to it. the force of what happened stretched the rod bolts and the rod cap fracture split joint was clearly visible witch it shouldn't be. the crank journal looks great no marks on it (bad phone photos). most of the wear and little bit of blue from running it after the hole was made. i know not the best idea but DCT car and limited man power to get it up the hill to the shop and what not.
05-23-2015, 01:22 PM | #33 |
233
Rep 1,673
Technical answer, when more than 10-15% of firing cycles result in peak cylinder pressure before the crankshaft reaches 4 degrees ATDC in any given timed period.
Electronics Junkie, Engine Builder.
05-23-2015, 01:34 PM | #34 | |
427
Rep 1,947
05-23-2015, 05:05 PM | #35 |
Bored at work....
893
Rep 5,396
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
05-23-2015, 05:24 PM | #36 | |
274
Rep 2,665
Drives: Goggomobil
But the more I think of it, and how the engine has behave, and the state of affairs now with M1 0w-40, I feel there is more to this RB failure than just the clearance. When you drive the car when it's cold, it's like day and night between the M1 and TWS. I think we do a lot of driving until the engine reaches the optimum temperature, and for me personally, M1 makes sense because I do low of city running and low rpm. Yes, On the weekend I drive the car very aggressively, but that's only 1-2% of the driving. My fuel consumption has dropped by more than a litre for 100/L. As I said, until I get the BS result when I do he next oil change, I am happy. As we agreed in the past, doesn't matter what oil we use, if the RB destined for failure, we cannot stop it. To be honest, I am happy and very comfortable with my choice to go with M1. Phil, as you know, this is not a personal thing against your theory, but another thing that I feel should be factored in.
F86 X6///
05-23-2015, 06:08 PM | #37 | |
64679
Rep 24,942
It's night and day difference between M1 and TWS because the M1 is a thinner oil and affects that the S65 revs more freely and so consumes less and is warmed up quicker . If the M1 is better ...why we see still blown S65's with M1 ? Thought I saw a couple of Malek's S65's that blew with M1 (stock S65's) And they looked really bad , but personal I'm more concernd about the lubrication film of the oil when bearing clearance /tolerance is nok by design flaw . And when talking about the lubrication film I'm feeling better with TWS , because I felt the difference between both oils between my fingers . And the TWS felt a lot more sticky . What I noticed too is that the M1 is showing higher metal ppm wear in BS oil reports what makes me think that M1 is not the perfect oil for high rev + 8K rpm engines . But if you feel good with M1 you really should keep running it with M1. But who knows my friend ? It's more like I said before my friend ...The problem is "NOT" the oil/brand/spec ! The problem is ... " Needless to repeat " But the cause is... "Made In Germany"
05-24-2015, 02:23 AM | #38 | |
274
Rep 2,665
Drives: Goggomobil
F86 X6///
05-24-2015, 07:28 AM | #39 |
64679
Rep 24,942
Exactly !
In numbers .. 50/50 % = Winners/Losers . 1- Winners = Bearings that hold out . 2- Losers = Are f@cked up by BMW from day 1 and from when the S65 was built in the German factory . (A matter of time) Hope we have "# 1".
05-24-2015, 09:18 AM | #40 |
274
Rep 2,665
Drives: Goggomobil
At least we are in a better place compared to some unfortunate souls.
F86 X6///
05-24-2015, 09:23 AM | #41 | |
64679
Rep 24,942
I really hope that we don't need to post up pics of our bearings ! BTW.....Some even twice ! Imagine ....
05-24-2015, 11:44 AM | #42 |
529
Rep 1,122
Is there a company selling kits for these custom holes, or is this something I'd need to get done professionally? Could I request a bigger hole than the one in OP? Just want to make sure I'm getting max airflow to my bearings.
Assimilator1595.50 |
