KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
08-26-2009, 04:25 PM | #24 |
yodog
197
Rep 5,025
I thought rom3n has a 10" +15 due to the 5mm spacer. He told me he didn't rub when dropped on h&r's. He was running ps2s, I hope RE-11s have a similar shape.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
08-26-2009, 05:24 PM | #25 |
Automotive Industry Insider
462
Rep 1,948
The effective offset goes down when you add a spacer to a positive offset wheel. (equal to width of the spacer)
So a +20 offset becomes +15 offset after a 5mm spacer install. Spacers push the wheel out towards the outer fender well. This drives the offset number down. (until you hit zero! )
The best is yet to come...
08-26-2009, 06:17 PM | #26 | |
Wheel Whore
158
Rep 937
for example: 20x10 4inch lip offset +20 20x10 3inch lip offset +20 these two would fit completely different...? |
08-26-2009, 06:29 PM | #27 |
yodog
197
Rep 5,025
The 10" with 4" lip would be +20 while the 3" lip can't be +20 unless it used a 5mm spacer which would make it as flush as the 4"
lip but still carry the 3" lip. This is just an example.
08-26-2009, 07:11 PM | #29 | |
191
Rep 2,867
Correct me if im wrong... |
08-26-2009, 07:23 PM | #30 |
Wheel Whore
158
Rep 937
i always thought the offset was determined by how far the actual wheel center is from the hub...i hope someone can chime in because i have never fully understood this
08-26-2009, 09:08 PM | #31 | |
Rep 70
offset explained
http://www.tirerack.com/wheels/tech/...jsp?techid=101 |
08-26-2009, 09:28 PM | #32 | |
462
Rep 1,948
There are a number of 'tricks' in the aftermarket wheel business. Many of these tricks are not widely publicized by the wheel companies themselves. This often leads to confusion among wheel buyers about certain wheel specifications. One of the 'tricks' that is often employed is the manipulation of the wheel center/spoke forging or casting. You can change the angle of the spokes to artificially create a bigger wheel lip. By designing the center to sweep the spokes back (inboard), you can make the wheel lip wider or narrower within a certain wheel width and offset range. The center of the wheel actually sticks out farther than where the end of the spokes meet the outer barrel. Now you can simply widen the wheel itself. (while lowering the offset value) That will also get you a wider outer lip. Cars WITHOUT a BBK installed can have bigger wheel lips than cars with a BBK. That's because the larger aftermarket BBK calipers require more outward wheel spoke clearance, and that eats into the same real estate the wheel needs to make huge outer wheel lips possible.
