Your E90/E91/E92/E93 Mileage!
02-01-2016, 12:15 AM | #23 |
143
Rep 1,720
115k on my '06 330i.
Just did OFHG, lower radiator hose, camshaft position sensors, and hood struts. Prior maintenance includes: Oil pan gasket, waterpump/thermostat, new shifter assembly, coils/plugs
Current Ride: '16 MK7 GTI//
Former Ride: '06 E90 330i// Don't mind me... just passing along// Old E90 Thread: http://www.e90post.com/forums/showth...first+e90+m580 |
02-01-2016, 04:32 AM | #26 |
17438
Rep 18,805
483,871 KM - 5,000 Miles...
02-01-2016, 09:16 AM | #27 |
They don't want you to drive a 335i - DJ Khaled
126
Rep 443
2010 Alpine White 335i M-Sport. 61,043 as of this morning.
Had her for about 10 months now, she's been running like a champ. I put about 15k miles on my car per year, I plan on putting 95% of it on this beast! |
02-04-2016, 09:47 PM | #31 |
Rep 292
Drives: 2011 E90 328xi 6MT Alpinweiss
Garage List 2014 BMW 535i X-Drive [0.00]
2004 BMW 325cic 5MT [0.00] 2016 BMW R1200RT [0.00] 2011 BMW 328xi 6MT [0.00] |
2011 Alpine 328xi 6MT SULEV bought early 2014 -- now at 37,000 mi. Still a few months left on CPO. No repairs have been needed.
Great car but most of my daily commuting is on my 2013 R1200RT. |
02-04-2016, 11:19 PM | #32 |
79
Rep 447
Drives: 2011 750i
2011 328i N51
70k Oil Filter housing gasket Automatic Transmission fluid & filter change w/ gasket Rear Differential fluid change Coolant change Brake fluid change Braided brake lines Drilled & Slotted rotors w/akebono brake pads Serpentine Belt Bilstein HD struts Spark plugs & Coils AFE filter w/carbon delete Rear Fog lights Drives like a dream still. Will probably need a battery next.
02-05-2016, 12:54 AM | #33 |
165
Rep 276
Drives: F10 M5 Comp 6-spd
154k '08 328i N51 Rosslyn Plant build
Plugs, rotors, pads (switched to ceramic), alternator, one catalytic converter (at 148k!), valve cover and oil filter housing gaskets, suspension and bushing refresh with Bilstein B12 pro kit and M3 front control arms, 18" Style 197's, battery cable recall, cam position sensor, driveline fluids and oils changes out the wazoo. Bought new door pull straps and driver sided door armrest, need to install.
2015 M5 Comp 6-spd manual
1972 2002 2003 Audi TT Coupe 225 2011 Highlander 4WD |
02-05-2016, 06:14 AM | #35 | |
255
Rep 2,547
At least you have a car now that should be good for MANY more miles. |
02-05-2016, 08:23 AM | #37 |
Beamer Mantic
82
Rep 1,191
Wife's 2006 E90 325i - I don't know, last time I took a picture it was around 250,000 miles or something and that was many months ago...
"Efthreeoh" most likely has over 300,000 mile on his 06 325i by now! EDIT: Sorry Efthreeoh did see your earlier post... Last edited by 3s4u2; 02-05-2016 at 06:29 PM.. |
02-05-2016, 08:46 AM | #38 |
Foodie and Gearhead
102
Rep 733
Drives: 2011 335i xDrive Sedan
2011 E90 335i xDrive, ~46k miles on N55.
Only major issues to report (so far): -Water pump replaced yesterday -VANOS recall performed -Leaky driver's side headlight washer (replaced under warranty) Dealership wanted to talk to me about exchanging the car for something newer as part of a program that they're specifically running within their dealer network, but: 1. The dollars didn't work out 2. I love this car - I don't see any reason to get rid of it any time soon I did test drive an F10 535 though... and damn it was nice. I have no doubt in my mind that I'll get a 5-series next as long as BMW hasn't messed it up by the time I'm ready to get one and/or if there's some nice CPO F10 models available.
2011 335i xDrive Sedan, Deep Sea Blue w/Oyster Interior
02-05-2016, 09:12 AM | #39 |
380
Rep 1,497
07 e90 335i..,currently have 92k on the dash. Before I got me a beater I piled up 17k in under a year of ownership driving to work and back. Currently going onto my 2nd year of ownership in july
Had little issues but nothing I wasn't able to fix myself.. All new index 12 injectors New coils Valve cover and valve cover gasket Ofhg gasket Oil pan gasket Water pump T stat Bmw oem brakes front and back, as well as ss brake lines(new fluid as well) New power steering fluid New coolant Rear diff oil replaced with oem bmw oil New gaskets and seals for turbo install Hexon upgraded turbos due to oem turbos smoking M3 upgraded suspension due to worn out ball joints on oem suspension (hr sway bar, new endlinks, new upper and lower arms, new tension struts, new bearings upfront as well when I had everything dissembled Mechatronics unit replaced in trans, with new fluid Yes everything on this list was done by me in my garage using jackstands except the transmission oil and Mechatronics unit Pretty much all the stuff that typically goes wrong with these cars has been fixed, and than i also did alot of go fast mods Last edited by mojobmw_e90; 02-05-2016 at 09:18 AM.. |
02-05-2016, 12:16 PM | #41 |
15
Rep 81
02-05-2016, 03:28 PM | #42 |
154
Rep 342
Drives: 2008 E90 335i; 2016 F80 M3
08 335i jet black 84,5k miles: new engine (warranty), replace coolant expansion tank (warranty), replace radiator hose, new brake rotors and pads, 1 oil change, replace accesory belt and tensioner, replace thrust arm bushings, replace brake hoses with fluid flush and finally installed all new michelin pilot super sports.
02-05-2016, 03:54 PM | #43 |
104
Rep 596
07 N54, @ 141K miles. Original thermostat & water pump are due to replace (no issues yet), as well as tranny/diff fluids. Other than that, pretty flawless.
2007 BMW 335i, 2014 Audi A4, 2016 Acura MDX
Join us on Facebook: E90Post - Houston Houston BMW DIY Services |
02-05-2016, 05:32 PM | #44 | |
15
Rep 81
