Your E90/E91/E92/E93 Mileage!
01-31-2016, 06:49 PM | #1 |
15
Rep 81
Hey guys wanna share how far your E90 has gone!
Any issues at this stage? Mine is 37,500 miles so far. Last edited by Bimbi; 02-17-2016 at 06:57 PM.. |
01-31-2016, 07:00 PM | #3 |
///Kenney
110
Rep 786
06 330xi e90 - 162k miles. Control arms, valve cover gasket, plugs, coils, thermostat, coolant and radiator hoses, black door, drive shaft.
09 335i - 62k miles. Passenger side day time bulb |
01-31-2016, 07:07 PM | #4 |
88
Rep 239
06 e90 325i 72k (for Sale)
11 e90 335i 43k
M-Sport, 6MT, PPK, JB4 ISO + Rev.3, VRSF 7'' FMIC, VRSF Catless DP, BMS Charge Pipe, MFactory LSD, Öhlins R&T, M3 Control Arms, Rogue 6MT Bushings, Remus Exhaust, Duke Dynamics CF Diffuser, Cyba Scoops, VMR VB3 19s, BMS Clucth Stop
01-31-2016, 07:10 PM | #5 |
Drop-Top Turbo
181
Rep 598
Drives: 2013 991 C2S/ 2013 335is E93
2013 335is 41k miles. Lease is up in June, i'll buy it if they'll negotiate the residual!
Current 2013 Porsche 991 Carrera S [Agate Gray] [Black] PDK, PASM, Sport Chrono, Sport Seats, Sport Techno Wheels, BOSE
Current 2013 BMW 335is E93 [Mineral White] [Coral Red] DCT, Premium Pkg, Convenience Pkg, Nav, Heated Seats, HK, BMW Apps |
01-31-2016, 07:17 PM | #6 |
111
Rep 807
2006 330i @ 111K. Replaced so far are thermostat, water pump, oil gasket housing, valve cover housing
Garage: BMW i3 Giga World BEV | BMW E70 X5 |
01-31-2016, 07:47 PM | #7 |
25
Rep 108
08 335i and just shy of 91k!!! Replaced all the general maint. Stuff i.e. Water pump-t stat, ofhg and did the trans filter and gasket as preventative maint.
01-31-2016, 07:55 PM | #8 |
135
Rep 524
'11 335 with almost 87,000km. Most recent: water pump and t-stat. In the past lots... Control arm, cylinder head, throttle body, MAF sensor, waste gate actuator, passenger side muffler, steering column boot, coolant reservoir, blower motor, and some other things I can't remember
01-31-2016, 08:15 PM | #9 |
167
Rep 191
e90 330i at > 226,000 miles
New starter at 200k, new alternator at 226k, new coils, water pump, and new xenons at 200k. Leaking oil like the Exxon Valdez. I'll get to the gasket eventually. I just had a 2015/2016 Ford Fusion as a rental with 1,000 miles... but it's really nice to be back in the E90. |
01-31-2016, 08:16 PM | #10 |
34
Rep 307
62k miles. Bought mine a month ago, as a preventive measure replaced all pulleys/tensioners, serpentine, tranny oil and filter ( crankcase), spark plugs, brake pads front and rears, engine oil and filter w/Castrol 5W/30, flushed cooling system with new BMW factory blue coolant,thermostat and water pump,starter,valve cover gasket, oil filter gasket, cabin filter(charcoal), the a/c blower motor and resistor, new factory wipers, a/c evaporator,pressure sensor and dryer. Plus four new Aquilles ATR2 radials 235/40/18 fronts and 265/35/18 rears.
2009 N54 335i Sport
01-31-2016, 08:19 PM | #11 | |
15
Rep 81
01-31-2016, 08:20 PM | #12 | |
15
Rep 81
01-31-2016, 08:24 PM | #13 |
34
Rep 307
Sport factory suspension. But it has from previous owner, Intercooler, Cobb V3, Chargepipe, Downpipes and dual intakes.
2009 N54 335i Sport
01-31-2016, 09:03 PM | #16 |
Chief Warrant Officer 4
53
Rep 726
Drives: 335I, E46 M3, X5M
07 335i
33670 mile garage queen. |
01-31-2016, 09:07 PM | #17 |
135
Rep 524
01-31-2016, 09:53 PM | #19 |
I got lei'd
845
Rep 7,594
07 328i, 104500 miles
valve cover, oil gasket housing, valve tick fixed, transmission drain/fill at 65k new battery at 92k new starter at 98k maintenance plans, replace steering fluid/coolant fluid/hoses/alternator, all pulley's idler/tensioner, serpentine belt, A/C freon recharge, replace with front/rear m3 susp bits, lemforder endlinks, mishimoto tstat, waterpump, plugs/coils, MAF sensor, replace o2 sensors if i ever get enough money for AFE headers, maybe fuel injectors/fuel filter |
01-31-2016, 09:54 PM | #20 |
239
Rep 1,255
09 335. 75200. Just replaced Dmtl pump, t statt, alternator, oil filter housing gasket and battery. Before that injectors, water pump, 1 coil. Valve cover has a crack so that's next
01-31-2016, 10:29 PM | #21 |
15
Rep 81
33,670 for a 9-year old car.. Thats
