F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Just Got JB Stage 1
Studio RSR
      07-16-2013, 12:18 PM   #45
ZheHbKa
ZheHbKa's Avatar
78
Drives: the Wind
2014 BMW 335 Xi  [10.00]
can you guy help me out and post DIY for stage 1, i know its easy and i have done N54 tunes but i just want to make sure i'm looking in the right places
thanks a lot
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      07-16-2013, 03:33 PM   #46
thebadboy
19
Drives: 335i f30
Originally Posted by tdizzle View Post
Stage 1 is very easy. You can just buy Stage 2 or you can buy stage 1 then upgrade to stage 2. Stage 2 isn't a huge upgrade over Stage 1 unless you are doing other mods such as a down pipe.
The below thread should tell you a lot about upgrading to Stage 2.
http://www.n54tech.com/forums/showthread.php?t=18588
To order either stage and find out the gains and dynos go here: http://www.burgertuning.com/products.html
thank you for answers
I will first buy the stage 1 is that I can put the stage 1 the dowpipe ==> http://www.burgertuning.com/F30_BMW_..._downpipe.html
or it must also set the stage 2 to put the dowpipe.
once the stage 1 and dowpipe install, put the internship must be changed other parts to the car (intercooler. .....)
thank you
      07-16-2013, 05:25 PM   #47
tdizzle
107
Drives: 2017 F80 ZCP
thank you
Stage 1 with a Down Pipe works fine and gives more power than stage 1 alone. Stage 2 + Down Pipe gives even more power when you select map 2.
      07-16-2013, 06:07 PM   #48
thebadboy
19
Drives: 335i f30
thank you,
not for me to make a mistake, you can just put the stage 2 more down pipe
or to install the stage 2 must first install the stage1.
So ==> Stage 1 + Stage 2 + down pipe
or
==> Stage 2 + down pipe
for stage 1 which connection should I make type A or type B
my car is a 2012 335i f30
thank you very much for your help
      07-16-2013, 09:20 PM   #49
tdizzle
107
thank you,
or
2012 F30 should be Type B (but you can look at your car to confirm)
http://burgertuning.com/N55_Jb_BMW_P...nce_Tuner.html
You can go Stage 1 > Down pipe if you want.
If you are going to install stage 2, you may as well just buy Stage 2 and skip Stage 1. Stage 2 kit is the same as Stage 2 with extra connections and different box.
Stage 2 is a bit more complicated to install as you tap into CAN wires, but it's not that difficult if you follow the instructions.
      07-17-2013, 10:28 AM   #50
thebadboy
19
Drives: 335i f30
thank you for the answer,
for stage 2 bmw f30 it is registered it (motortsport burger), but the translation does not mean anything, can you explain to me with another word.
thank you
==> JB4 support for the F10 & F30 is limited and does not yet include in dash features. Follow along on N54Tech for the most current updates.
or you can find a tutorial for mounting the stage 1 or stage 2
      07-17-2013, 11:07 AM   #51
tdizzle
107
thank you
Here is a stage 1 video install:
You may not want Stage 2 if you cannot understand the instructions. There is no video for it yet and the software you must install on your computer to change the maps are in English only as far as I know.
Here is the stage 2 upgrade instructions: http://www.n54tech.com/forums/attach...8&d=1364851654
      07-17-2013, 11:27 AM   #52
thebadboy
19
Drives: 335i f30
a big thank you all,
I think I'll take the stage 1 because I'm afraid I do not know how to install the Stage 2, a shame because the stage 2 gives more power but if I do not get ca is useless
f30post
