M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      09-29-2014, 03:48 PM   #1
falsalem
falsalem's Avatar
Kuwait
Drives: 2013 F10 M5 Alpine White
Help ! Rattling close to rear axle
I have been driving my recently purchased 2013 M5 for a week now. It is preowned with 15000 miles.
Since this morning, I've noticed a continuos rattling in the rear axle area. I reached down below the car in the rear axle area and can feel a continuous rattling and slight tapping sound on the underside protection panel area around the rear axle. This rattle/tapping can be felt if you touch the underbelly of the rear axle area, as well as heard clearly from the outside of the car if you get close to the rear axle. The sound can also be heard from the inside of the cabin towards the rear.
Moreover, movement of the car, or revving the engine doesn't affect the frequency of the rattling. It is a monotonous, continuous rattle/tapping.
Anybody here know whats going on with my baby ?! help please...
      09-30-2014, 08:00 AM   #2
falsalem
falsalem's Avatar
Kuwait
After looking through many threads, I'm thinking the sound may be related to the fuel pump.
Anybody had a noisy fuel pump before ?
      10-01-2014, 06:36 AM   #3
drbru
101
Drives: f10 m5
not sure what you mean by feeling the rattle? Can you feel something moving?......
One other thing to consider....Getting a stone or pebble trapped around the brake disc area also causes a very load horrible noise which sounds like a pebble being shaken in a tin can....
If this is it, it usually falls out itself with some heavy driving....(this is what happened to me)
      10-02-2014, 03:52 AM   #4
falsalem
falsalem's Avatar
Kuwait
I can feel the rattle if I touch what I think is the underbelly of the gas tank in the rear section of the car.
I doubt it's a stone in the brake disc area because the rattle/clunking sound is consistent even when I'm idling.
      10-02-2014, 04:24 AM   #5
drbru
101
Drives: f10 m5
In that case I honestly dont know so a trip to bmw may be required
      10-02-2014, 09:09 AM   #6
falsalem
falsalem's Avatar
Kuwait
Thanks for responding. The dealership will be closed for a week-long holiday.
I'm seeking answers in the forum till the dealership is ready to take my baby in
      09-17-2022, 01:25 AM   #7
Danishp97
23
Drives: BMW F06 M6 GRAN COUPE
Hi! Were you able to find a solution? I'm having a similar problem.
      09-20-2022, 07:29 AM   #8
Gbmw09
Drives: M5
Have you gotten solutions I'll love to know man
      02-21-2023, 08:39 PM   #9
etnsandman
82
Drives: 2015 M5 Competition
I recently started hearing a slight noise in the rear passenger side area. I've been all under the car looking and pulled the rear wheels and repositioned the shields on the rear disk. The noise doesn't sound bad, but it's annoying.
      03-05-2023, 06:57 PM   #10
etnsandman
82
So for mine I hear a tapping at 10-20 mph when coasting. If I brake or accelerate it stops. I've been up under the car 3 times and can't find anything loose or rubbing. Car feels fine. Just can't track down this rotational ticking noise.
      05-03-2024, 03:57 PM   #11
etnsandman
82
Well, the noise appeared off and on for over a year but was never serious sounding. Week before last it got serious and sounded really bad when coasting off the gas, gets quieter when accelerating.
So I parked it and ordered a rear bearing/hub assembly and required one time use fasteners. So today I installed everything and it didn't change anything. I'm at loss.
Wheel feels fine off the ground with no play or noises when rotated. I put the car in roller mode with the wheels off the ground and ran it up to 4th gear. Sounds perfect, no noise. Diff fluid was changed last year, pads and rotors are good. I looked at the brake shield and that seems fine as well. Axle issue?
Help!!!
m5post
