03-19-2024, 06:09 PM | #45 | |
5789
Rep 4,733
Drives: BMW M550i xDrive (2020)
One after he finished at his shop and one in my office garage a week or so later.
2020 M550i xDrive (Champagne Quartz/Black)
2021 X7 40i M-Sport (Arctic Gray/Tartufo) RETIRED: 2018 540i Luxury Line (Dark Graphite/Canberra Beige) |
03-19-2024, 09:14 PM | #47 |
292
Rep 353
What did u use for this job? Compound, polish, etc
03-20-2024, 07:31 AM | #48 |
5532
Rep 5,443
Drives: Beige G31 40ix m sport
A paint 2 fix kit, cutting compound, wet & dry, polish & loads of elbow grease, doubtful that I’d do it again & would most likely pay someone if I had to do a similar job
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
zvery777292.00 |
03-20-2024, 07:35 AM | #49 |
292
Rep 353
I'm going to try an tackle it myself and use Dr Colorchip. I have all the necessary tools just need to take my time. Never did a full car just small parts and panels in the past. I feel like nobody will do it with the care you would on your own car, and practice should make it an easier job next time.
NGT25788.50 |
03-20-2024, 10:39 AM | #50 | |
7504
Rep 6,870
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [10.00] 2018 BMW M550 [10.00] |
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
zvery777292.00 |
04-24-2024, 09:51 AM | #52 |
292
Rep 353
Has anyone used Dr Colorchip for metallic colors? I got the paint for my Tanzanite Blue and the paint does not have any sparkles in it, which turns out very ugly when applied.
I have OEM paint which has the metallic chips in it and may go that route. I'll just have to sand it and polish afterwards. Wish me luck! Tips and recommendations are welcome and appreciated! |
04-24-2024, 10:25 AM | #53 | |
7504
Rep 6,870
I started with the squeegee but found it was overkill for the few areas I was hitting, so I used the tiny brush.
04-24-2024, 10:28 AM | #54 | |
292
Rep 353
04-24-2024, 10:56 AM | #55 |
7504
Rep 6,870
You may want to wait a bit longer than they say to let it harden and dry before wiping off so the bottom layer in the deeper chip stays. Then wait until the next day and do it again over it to build on it and repeat until the fill is the same level as the paint.
430Scud275.00 |
04-24-2024, 11:19 AM | #56 | |
292
Rep 353
04-24-2024, 12:06 PM | #57 | |
7504
Rep 6,870
There is and has always been blob and sand techniques. There was a product called Lanka years ago. It definitely takes some skill, patience and a good set of eyes. If I ever had a chip that needed that skill, I would hire a pro.
zvery777292.00 |
04-29-2024, 11:44 AM | #59 |
7504
Rep 6,870
zvery777292.00 |
04-29-2024, 12:05 PM | #60 |
292
Rep 353
05-08-2024, 07:52 AM | #61 |
292
Rep 353
Quick update:
I was unable to remove the sanding marks with the tools and chemicals I have, so the car will have to go to a professional unfortunately. I was way more confident about this and it turned out to be a nightmare. Spent 6 hours in my garage with very little results. Unless you have the right tools I would not recommend tackling something like this by yourself. Also, I dropped the door handle screw inside the door which seems to be a huge PITA to get out or replace since the dealer says that part can't be purchased alone and it's part of the door carrier (not so smart engineering imo). I'm asking them to try and retrieve it and attach it in addition to finding out whether the screw was supposed to fall at all since I was under the impression that it simply can't fall inside. Let's see what happens! Will have more updates soon! |
05-08-2024, 07:59 AM | #62 | |
7504
Rep 6,870
zvery777292.00 |
05-08-2024, 08:05 AM | #63 | |
292
Rep 353
Must be how life works 🙂 |
05-08-2024, 08:31 AM | #64 | |
1342
Rep 1,657
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
zvery777292.00 |
05-08-2024, 08:40 AM | #65 | |
7504
Rep 6,870
I am famous for taking on home projects that I end of spending money on and then fail. Mostly projects that involves ladders. I was hell bent on getting on my roof this past weekend to seal a leak in a skylight. I bought all the supplies. Got to the top of the ladder and said NFW am I getting up there. The issue was getting back on the ladder from the roof. Paid a guy yesterday to fix it. Electricity is my sweet spot around the house. Carpentry, not so much.
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| Last edited by Joe-BMW33; 05-08-2024 at 09:06 AM.. |
adhrp1342.00 |
05-08-2024, 08:54 AM | #66 | |
1759
Rep 1,674
That will be the last time I'm on a ladder.
2020 M550 / Dark Graphite / Napa Saddle Brown / DHP Pkg / Exec Pkg / Luxury Pkg / Parking Asst Pkg
Joe-BMW337503.50 |
