03-13-2024, 05:53 AM | #1 |
Rep 9
Big engine problems??
Hi everyone. Without going into massive detail I recently bought my 750i from a dealership.
The moment I got into the car to drive away after paying for it, the engine management light was on. I went back in and he took the car away to "fix" it. I'm not naive enough to think that he did anything other than wipe the warning light rather than fix it but I felt reassured with a warranty so thought I'd just follow up with them. Anyway I took it to a garage yesterday for the fault to be diagnosed. The main ones are: 123439 electrical wastegate valve - adaptation: bottom limit position 130713 VANOS Solenoid valve, inlet - position not reached 130714 VANOS Solenoid valve, exhaust - position not reached 130715 VANOS Solenoid valve, inlet - camshaft jammed There were also similar ones for engine slave (DME/DDE) 130704 VANOS Solenoid valve, exhaust 2 - camshaft jammed 130708 VANOS Solenoid valve, exhaust 2 - position not reached Im guessing these codes are all part of the same problem. The mechanic said it may be something to do with the timing chain which may be confirmed with an occasional rough idle. The car otherwise drives perfectly fine. Unfortunately the garage said they were not in a position to repair the car yet with their workload but at least I have a diagnostic to take away. I'm having trouble getting in touch with the dealership and discuss my rights under the Consumer Rights Act. I actually really like the car so I just want them to repair it although I'm conscious they'll just refund me then sell it onto someone else. Anyway my question is whether anyone has had similar issues and/or recognises these fault codes and can provide any insight. Many thanks. |
03-13-2024, 02:43 PM | #2 |
196
Rep 417
This thread looks very similar to your symptoms. Perhaps have the car updated and go from there.
gramezza0.00 |
03-14-2024, 05:06 AM | #3 | |
Rep 9
I'm hoping it could be something as simple as that but I'm not so sure now. |
03-14-2024, 06:52 AM | #4 |
107
Rep 86
The thread that was linked was for the b58 and OP has a n63.
Either way, Get the car programmed with the latest software, if the problem persists it likely needs the vanos solenoids. Not too terribly common but not uncommon either. Timing chains have not been an issue on the updated g12 n63tu2 motor |
gramezza0.00 |
03-14-2024, 11:48 AM | #5 | |
196
Rep 417
Do you know what is the cause of the failure of those valves? Really odd to see three out of four valves failed without common denominator. Also, aren't these the valves that are being screwed in from behind the vanos units and require engine timing afterwards? Perhaps someone already touched these and didn't time the engine. |
gramezza0.00 |
03-15-2024, 06:04 AM | #6 | |
107
Rep 86
03-15-2024, 03:12 PM | #7 | |
196
Rep 417
05-16-2024, 03:19 PM | #8 | |
199
Rep 847
