BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > USA - Midwest / Rockies
EXXEL Distributions
      06-17-2023, 07:14 AM   #397
jdfzhp
Drives: BMW M3, BMW 330i
2004 BMW 330i  [0.00]
2011 BMW M3  [10.00]
Originally Posted by patroklai View Post
So you basically need an unmodified factory pipe from the headers to the axle back with the 4 cats and dual resonators, correct?
Im sure someone here might have that. I basically have a similar setup as your current except I have no resonators and only the secondary cats.
Pat
I'm fairly certain secondary cats and resonators are in place still and the primaries were the only thing removed as that's all I have separate from the car. I'll be under there today to confirm.
      10-26-2023, 01:48 PM   #398
cloumeM
169
Drives: BMW e93 M3
Sad to see these go but if anyone locally is interested, please LMK: https://www.m3post.com/forums/showthread.php?t=2057577
      10-26-2023, 08:23 PM   #399
jdfzhp
2011 BMW M3  [10.00]
Dang, if I hadn't have just picked up an MCS set I would have been very interested. Good luck with the sale. I do believe those should work on any E9x M, just going to have a bit more of an exciting rear end on an E90 with the rear spring rate. They could very likely be set up for flatride though.
I'm also still looking to trade my test pipes for a catted mid section.
I also have everything to install f80 brakes including basically new rotors and two new sets of pads. I'm dumb and didn't read the solo rule book well enough to know that setup would kick me from street touring. 3k and I can even install.
      10-26-2023, 08:26 PM   #400
cloumeM
169
Drives: BMW e93 M3
That sucks... You may want to check with Pat as he may help find a solution for you. He is my go-to guru on trouble shooting. LOL
      12-19-2023, 03:29 PM   #401
seanjohn291
Drives: 2008 E90 M3
Hey guys,
Semi-new to M3 ownership, bought an E90 in May, and am needing the CD changer coded active to finish the Mr12Volt install.
Is the OP still around or anyone have another resource for coding in the St. Louis area? I’m in O’fallon but willing to make the trek wherever.
      12-19-2023, 10:16 PM   #402
patroklai
patroklai's Avatar
227
Drives: Camaro SS | e92 M3
Originally Posted by seanjohn291 View Post
Hey guys,
He's still around but his laptop is in the trunk of my M. Lol.
I do have bimmer code. Quick forum search suggests the setting might be editable via expert mode. Do you know the setting that needs to be changed? Saw a lot of misses / struggles finding the setting.
If it's there and its a cut and dry change, happy to do it.
Pat
      12-20-2023, 11:35 AM   #403
Cbozz
Cbozz's Avatar
690
Drives: M3
Pat
Damn Pat! I’ve been looking for it for a long time! I forgot you have it! I need it back lol
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
      12-20-2023, 11:50 AM   #404
patroklai
patroklai's Avatar
227
I've got some free time coming up bro. Happy to swing by.
Cbozz690.00
      12-20-2023, 01:05 PM   #405
seanjohn291
Drives: 2008 E90 M3
Appreciate the responses guys. From my searching this is what I've found. I too have seen all the struggles. CIC coding can be done via Bimmercode and expert mode on Audio module and but CCC can't. One post I found said you cannot change the "CDC" from "not active" to "active"
https://www.e90post.com/forums/showthread.php?t=1499463
Post #5 states "Add $672 and remove $694 to 2URAD, CAS, FRM." and the info I got from the Mr12Volt distributor says to code $672 to the VO and remove $694
Any help appreciated. Cbozz, is this in your wheelhouse?
      12-25-2023, 09:04 PM   #406
patroklai
patroklai's Avatar
227
That sounds more like Cbozz. Those parameters probably aren't easily accessible via bimmercode. He may need to get to those via INPA instead.
      12-26-2023, 05:57 PM   #407
Cbozz
Cbozz's Avatar
690
Drives: M3
Yeah I can code that for you no problem… just have to get my computer from Pat and figure out when I have the time..
      02-22-2024, 10:02 AM   #408
jdfzhp
2011 BMW M3  [10.00]
So who has the laptop these days? 😜 I'm hoping to install new shocks in the next month and would like to code out edc before buying one of the cancellation kits. Also would like a couple little things done on the E46 but certainly not a priority.
      02-22-2024, 11:03 AM   #409
patroklai
patroklai's Avatar
227
Cbozz has the laptop now!
      03-28-2024, 08:54 PM   #410
omblee
Drives: 11 E90 M3
Hey ya'll. New to the STL area. Just wanted to introduce myself. Hope to see you guys out during show season.
-Brandon
      03-29-2024, 10:00 AM   #411
cloumeM
169
Drives: BMW e93 M3
-Brandon
Welcome Brandon and it was a pleasure meeting you! Hope to see you around.
omblee5.50
      04-07-2024, 11:33 AM   #412
patroklai
patroklai's Avatar
227
-Brandon
Welcome! Do post pics of your ride. Maybe I've seen it around.
What area of stl do you generally frequent?
      04-07-2024, 11:37 AM   #413
omblee
Drives: 11 E90 M3
Thank you Pat. You will likely see me most in the St. Peters area
cloumeM168.50
      05-16-2024, 01:52 PM   #414
M3Stow
M3Stow's Avatar
Drives: E91 328xi, E46 M3
Hey everybody, I live in Maplewood and recently picked up a 2011 e91 328xi. I want to code out TPMS and activate the Flat Tire Monitor. I swapped some wheels I had laying around from my E46 M3, they don't have TPMS so now my dash light is constantly on... it's driving me crazy. Is that something you guys could help me with?
I can disable the RDC module but I'm nervous about making the code changes myself.
I'll post some photos of my cars when I get back to my home PC.
      05-16-2024, 04:42 PM   #415
patroklai
patroklai's Avatar
227
Welcome buddy and congrats on your new ride.
I've actually done this mod on my car. Cboss helped me with the coding. You'll have to also physically remove the module (located inside the trunk on the passenger side quarter label) for this to work.
Pat
      05-17-2024, 12:01 AM   #416
M3Stow
M3Stow's Avatar
Thank you! So you fully removed the module rather than just unplugging it?
-Dylan
      05-17-2024, 03:48 PM   #417
patroklai
patroklai's Avatar
227
-Dylan
IIRC you can't just unplug it. It seats into a linked tray similar to that of putting a game cassette into a Nintendo.
Hope that helps.
M3Stow1.50
      05-17-2024, 06:52 PM   #418
Cbozz
Cbozz's Avatar
690
Drives: M3
Hope that helps.
Quick google search will lead you to a post about this…
If you want that coded maybe we can set something up.. maybe we can set up some kind of meet up and I’ll do some coding for people… I know there is another guy that wanted some stuff coded I never had the time to meet with..
M3Stow1.50
m3post
