07-01-2022, 09:02 PM | #23 |
Rep 7
M235 Wireless Charger Mod
During disassembly, it takes a fair amount of force and required a rag and 2x vice grips to remove.
Just be careful to pull from the top section of tabs, or it will damage the part. |
08-22-2022, 03:10 PM | #26 |
39
Rep 18
IT WORKS!
Ok, so here is what I can tell you.
I have a 2022 F44 that came with NFC but no wireless charging. I ordered BMW part. 9442419 From: https://www.ebay.com/itm/275342480536 To remove it I popped off the plastic phone holder and grabbed the old part with needle nose locking pliers and pulled back as each side popped out the the clips. NOTE: I covered them and the sides of the enclosure with blue painters tape to protect the surfaces as well as the nose of the pliers. Once installed I had wireless charging and NFC control still. Simple easy I have not bother coding left behind phone yet. --Josh |
Bugs Meany32.50 |
08-24-2022, 01:52 PM | #27 | |
Rep 55
It's also meant to have the Digital Key. However I couldn't get wireless charging. Without the wireless charging does that mean it won't have the digital key? |
Bugs Meany32.50 |
08-25-2022, 02:32 PM | #28 | |
33
Rep 35
08-25-2022, 02:34 PM | #29 | ||||
Rep 55
08-31-2022, 01:40 PM | #30 | |
Rep 2
10-13-2022, 03:25 PM | #32 |
33
Rep 35
11-26-2022, 10:50 PM | #34 |
13
Rep 13
You can get it done yourself but would be advisable to get it done through a dealer. You could contact the one that got mine done for me through WhatsApp +1 (401) 206‑0558 He can do it within your own convenience
Greggreg
11-26-2022, 10:51 PM | #35 |
13
Rep 13
A car dealer would be better, cos explaining it to you, something could go wrong. You can contact the guy that helped me with mine through WhatsApp +1 (401) 206‑0558 He can do it within your own convenience.
Greggreg
11-27-2022, 08:18 AM | #36 | ||
Rep 2
12-14-2022, 06:46 PM | #37 |
Rep 1
Can anyone tell me where this plugs in to,
? I took it apart but there is no cable ready to be connected to the charging pad except the one for the usb Do I need a special cable to connect it or from where you get the power from. Thank you in advance Newfy here… |
02-14-2023, 03:43 AM | #38 |
Rep 23
I have rebuild the wireless charging unit but the phone will not be charged. Is there any solution (maybe coding in the new versions)? My Car is build 06/22 with the software 07/2022.58.
Thanks! |
08-06-2023, 03:06 PM | #42 |
Rep 32
Can anyone send me a link for the component required if you already have the nfc phone tray but it doesn’t actually charge, I have the comfort pack but not the full tech pack so although I have the nfc tray it doesn’t charge my phone
08-08-2023, 12:39 AM | #43 |
Rep 3
What link to you mean? You need a tray with nfc and wca. Then you must code the wca and thats it.
But I think you will have the same problem that it not will work. |
