03-26-2020, 08:27 AM | #67 | |
368
Rep 697
03-26-2020, 08:31 AM | #68 |
General
21132
Rep 20,742
Drives: 2021 911 turbo
Some cars need a fair bit of camber to compensate for chassis and suspension flex. The M3(4) chassis and suspension keep improving with subsequent generations. Going from my E46 to my E92 to my F82 and now F82cs, I kept needing less and less camber for optimal tread temperature distribution.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-26-2020, 10:09 AM | #69 | |
General
21132
Rep 20,742
Did you get the caster increase from the simple installation of the TCK plates, or does the caster angle change with camber adjustment, or both? Can you share your current caster angle at your current alignment setting?
03-26-2020, 11:19 AM | #70 | |
General
21132
Rep 20,742
From what I gather, the benefits are not significant on higher speed corners (lower steering angles) but more so on low speed corners (higher steering angles). The caster adjustment slots on my GC plates is not huge. The small increment they allow on caster angle likely have minimal impact on camber. IMO the adjustment is mostly there to allow equal left and right caster settings.
03-26-2020, 11:23 AM | #71 | ||
25
Rep 113
CanAutM321131.50 |
03-27-2020, 08:49 AM | #72 |
368
Rep 697
I would have to root around my paperwork to find the original caster but I believe it was around 6.9. After installing the TCKline plates it jumped up to 8.8. It was pretty easy to see how much caster was going to be gained just by looking at the bearing to plate location. Again, I would have to look back at the pictures of the plates themselves, but I *think* the caster change was built into the design, rather than adjusting with the camber.
CanAutM321131.50 |
03-28-2020, 06:27 AM | #73 | |
General
21132
Rep 20,742
03-30-2020, 09:00 AM | #74 |
368
Rep 697
Steering felt much better after adding camber plates, but I can't for certain say that was due to the increase in caster angle (not experienced enough to realize difference).
04-07-2020, 02:10 AM | #75 |
1189
Rep 1,224
CS factory camber specs
Can anyone confirm if the factory front end camber on a CS is the same as a normal F/80. Seems if BMW has optimized this model for track use they would add a bit of camber in there for us. Thanks.
04-07-2020, 08:27 AM | #76 |
General
21132
Rep 20,742
Exact same as all other M3/4 variants (except for the GTS).
05-18-2020, 11:39 AM | #77 |
18
Rep 48
Reading thru this thread it's obvious that most of you have a good handle on how suspensions work and what adjustments to make. For people that are a little confused, this recent video by FCPeuro does a really good job at explaining what each setting does and why.
jfritz271126.50 |
05-19-2020, 01:16 PM | #78 |
Grid.Life
325
Rep 383
I heard a rumor that the GT4 M4's are running upwards of -5.0deg of camber on the front. I currently have my GC plates set to around ~-4.0 and zero toe. Has anyone played around with higher levels of camber?
05-19-2020, 04:59 PM | #79 |
General
21132
Rep 20,742
I depends what type of tires you are running. Super sticky race slicks tend to like more camber.
fanatic11018.50 |
05-19-2020, 05:13 PM | #80 |
1019
Rep 859
Think my GC plates are about maxed at -4.0 and planning on trying that with used DH
05-19-2020, 11:50 PM | #81 |
Grid.Life
325
Rep 383
That's right about where I get to before the camber slide lock bolts hit the aluminum brace. My shop actually had me at -4.2 but I dialed it back some, looks like I could clearance the aluminum brace some and get more if I wanted to get crazy haha. We'll have a pyrometer with us at Gingerman in June to hopefully get some solid data and I'll def report back toe will be kept at 0.
fanatic11018.50 |
05-21-2020, 09:44 AM | #82 |
610
Rep 1,014
What do you guys think about these alignment specs for mostly street with 2 hpdes a year?
-2.4 degrees front camber .06 degrees total toe in(very very slight toe in) -1.7 degrees rear camber .26 degrees total toe in Should i reduce rear toe in? Maybe .20 or .16 toe in? Should i reduce front and rear camber a little? Thanks. |
05-22-2020, 09:55 AM | #83 | |
368
Rep 697
hC1001610.00 |
08-11-2020, 08:16 AM | #84 |
Instagram: matte_f80_competition
127
Rep 219
i'm running -2.6 camber at the front but the outer shoulders of my front Cup 2 are gone now (front tire pressure was 32 psi hot at track). i'm considering to increase the camber to -2.9 for the next track day with new front Cup 2.
18' M3 (F80) ZCP 6-Speed - IG: matte_f80_competition
Ind Frozen Dark Grey/M-Perf CF Pkg/MPE/KW CS 2-W/Girodisc+Carbotech/Vorsteiner VFF103 Track: Michelin Pilot Sport Cup 2 F: 265/35-19 R: 285/30-20 Street: Michelin PS4S F: 265/30-20 R: 285/30-20 |
stahpeht6.00 |
08-11-2020, 09:41 AM | #86 |
3663
Rep 3,422
Might have more even wear at slightly higher pressures (mid-30's), but should really consider bouncing from Cup 2. This spec is just not durable enough for hard running session after session fitted to M3/M4. Fighting a losing battle, imo
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
08-11-2020, 10:03 AM | #87 |
General
21132
Rep 20,742
The GT4 are also running race slicks...
08-11-2020, 10:43 AM | #88 |
Rep 34
Had an alignment done today following recent Bilstein B16 Damptronic / Millway camber plates install.
I drive 50/50 road/track so looking for a sensible compromise and really just to get the car a bit sharper, neutral and confidence inspiring on circuit. I'm running Pirelli Trofeo R's, F265/35/19 and R295/30/20. Next track outing in a couple of weeks. Will try increasing the front camber and find the sweet spot! Shame the rear adjustment is so limited/compromised. Guess I need adjustable rear toe arms to get a touch more camber on the rear (with the desired toe settings).
M4CS San Marino Blue | X5 M50d Arctic Grey | 720S Spider
