Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      08-07-2020, 11:42 AM   #23
F80_BK
M3MBER
F80_BK's Avatar
75
Drives: F80 M3 -Yas Marina/Silverstone
2015 BMW M3  [0.00]
Originally Posted by hC1001 View Post
I just started coding and this is the first istep version im coding with. I updated all the ECUs from F020_17_03_505 istep.
I've only touched HU_NBT2, and ASD modules and didnt run into any issues like i do with TMS ECUs. Maybe i should try esys v3.33...
Looks like my i-step is slightly older
2015///M3|Yas Marina Blue|Silverstone|
hC1001610.00
      08-07-2020, 01:51 PM   #24
hC1001
610
Drives: E36 M3, F80 M3
Dont worry about looking at what istep you have. Probably better for someone else who is on a later istep version to confirm if they have worded folders or "." as well.
Thanks tho.
      08-07-2020, 07:16 PM   #25
omgf80
207
Drives: 18' ZCP F80
Yes. You have FLE instead of TMS. I mentioned this in my first reply for people with the newer FLE modules.
For FLE ECUs:
-To turn the side markers off, change LM_ID_LT04 and LM04_Name to F015Wert.
-To turn the side markers back on, change LM_ID_LT04 and LM04_Name back to F015Wert_SA552_SAE.
Ah missed that part. I didn't see "F015Wert" as an option within the "Front light Electronics Left/Right" but I did just change LM_ID_LT4 and LM04_Name to "00x0" which seemed to do the trick!
Thank you for the help!
Current:18' F80 AW | 05' T4R Sport
Sold: 89' 325ix | 09' 135i | 15' M235i | 17' I3
IG: omgf80
F80_BK75.00
      08-07-2020, 07:24 PM   #26
F80_BK
M3MBER
F80_BK's Avatar
75
2015 BMW M3  [0.00]
Glad it worked!
omgf80207.00
      12-07-2020, 10:33 PM   #27
EezyBeezy
EezyBeezy's Avatar
273
Drives: 2018 BMW F[am]80 M3
Just did this on my '18 F80 through expert mode using Bimmercode and worked perfectly. Those (3) little amber LEDs just looked out of place.
For those who have "Front Light Electronics Left" and "Front Light Electronics Right" control units here is exactly what I did.
- Navigate to Front Light Electronics Left
- Click on Expert mode
- Click on 3006 LED1
- Click on LM_ID_LT4
- Change to 02_VALUE / 0x00
- Go back to the 3006 LED1 page
- Click on LM04_NAME
- Back on 3006 LED1 page and click code
Check & verify if value changes worked for the Left headlight. If no-go, revert back. If good, then proceed with the Front Light Electronics Right control unit.
- Navigate to Front Light Electronics Right
Enjoy!
Thanks all to previous posters for cluing me in.
wknd_M225.00
2Times1065.50
      12-10-2020, 02:25 AM   #28
horsepower_and_hounds
1843
Drives: BMW
I wish I could get mine to work...... I was told by Alex that coded my car it could not be done on my 2015 cuz it had the files updated somewhere along the line
      01-24-2021, 04:48 PM   #29
hC1001
610
Wanted to update my situation with the wierd folder names. In Esys 3.3.4, i used detect CAF for SWE and code on both TMS modules. After, i was able to see the correct folder names in Esys launcher pro 2.8.2+Esys 3.27 and successfully coded out the 3 amber LEDs using instructions in post 3.
Also, i found another method to disable the 3 amber LEDs, remove the corner light module from the headlight and disconnect the connector to the 3 amber LEDs. No coding necessary.
      05-04-2022, 05:15 PM   #30
alexhjs
The Muscle Milk.
97
Drives: 2018 F85 X5M
2011 BMW 335is  [0.00]
Enjoy!
I just wanted to chime in and let you guys know that this exact method worked on my '18 F85 X5M. The 2018s have the iDrive updated and BimmerCode did not have easy menus enabled to code off the ambers but this code shared via expert mode worked perfectly. Thanks again!
      05-06-2022, 02:20 PM   #31
EezyBeezy
EezyBeezy's Avatar
273
Cheers!
      05-26-2022, 10:49 PM   #32
wknd_M
225
Drives: 18’ MG ZCP F82
I will definitely give this a try, the ambers are an eye sore on my LCI
      05-27-2022, 03:22 PM   #33
KACHM3
KACHM3's Avatar
Italy
267
Drives: G80 Comp
22 G80 🔥 ...  [10.00]
just wanted to say..it works…thank you
      05-30-2022, 12:51 AM   #34
wknd_M
225
Enjoy!
It worked! Did this today on the car, thanks for sharing
EezyBeezy272.50
      05-30-2022, 02:04 AM   #35
Mandi90TT
2714
Drives: BSM 6MT M4 F82
Saw this thread pop up and thought it was another Heard/Depp discussion...
2015 Black Sapphire Metallic 6MT M4
      10-28-2022, 09:11 AM   #36
2Times
I'd hit it
2Times's Avatar
1066
Drives: G82
2023 BMW M4 xd  [10.00]
Enjoy!
This worked perfect on my 2020 F83. Super fast and easy the way you laid it out. Thank you. Going to try the same thing on my X3M later.
EezyBeezy272.50
      10-28-2022, 09:31 AM   #37
EezyBeezy
EezyBeezy's Avatar
273
Glad to hear. Cheers!
2Times1065.50
      11-04-2023, 11:19 AM   #38
Sloblk8
Sloblk8's Avatar
33
Drives: 18 M3 Competition
Enjoy!
I know this is an old thread but what about people that don't have "Front Light Electronics Left" or "Front Light Electronics Right" options on the Bimmercode main screen?
The lighting stuff is in the Front Electronic Module and I don't see 3006LED1 at all in the expert section. There is a cornering lights deactivation but it's already showing active . Thanks for the help.
      11-04-2023, 12:06 PM   #39
kubax86
BimmerPost Supporting Vendor
kubax86's Avatar
1804
Drives: M2
All depends on current lights
      11-04-2023, 12:22 PM   #40
Sloblk8
Sloblk8's Avatar
33
It's an 18 M3 comp so the LCI headlights I assume. I know it's small but the headlights like in my avatar pic.
      11-05-2023, 04:14 AM   #41
kubax86
kubax86's Avatar
1804
Drives: M2
FLE modules then.
Sloblk832.50
      11-05-2023, 08:22 AM   #42
Sloblk8
Sloblk8's Avatar
33
FLE modules then.
Thanks man, I'm gonna hook it up when I get off of work and look for that module. Thanks again for your time.
      02-14-2024, 04:54 PM   #43
vermethlln
Spain
Drives: X3 (G01)
Will this work on my G01 2019 X3 as well? I want to turn off the amber lights for the EU inspection. Thanks in advance
      02-15-2024, 03:02 AM   #44
kubax86
kubax86's Avatar
1804
Drives: M2
Different on G01. Can help if needed.
https://bimmer-remote.com/products/b...f395e811&_ss=r
f80post
