02-16-2018, 12:37 AM | #1 |
814
Rep 5,530
F8X LCI2 Headlight Retrofit
Just finished
This retrofit was done on a 2016 LCI Comp Pack. The current headlights are LED Adaptive and we set out to retrofit the LCI 2 LED Adaptive headlights. I am not sure how this retrofit would go on a bi-xenon car, I think it would work similarly just more coding required. 'Regular' LCI Headlights Front Bar Removed Side by side and skip ahead to new headlights in... To match the new headlights we retrofitted the LCI taillights as well |
02-16-2018, 01:15 AM | #2 |
193
Rep 806
Drives: 2016 lci m3 mw
wow seems easier than i thought. great job
02-16-2018, 05:50 AM | #7 |
Gone Fishin’
7318
Rep 12,125
Temper Tantrum15.50 |
02-16-2018, 06:07 AM | #8 |
193
Rep 806
lights in itself are sujective but in flesh lci2 light cars look more sharper up front.
02-17-2018, 10:51 PM | #10 |
99
Rep 824
Drives: E91 335i, B5 RS4, F31 330i, i4
Garage List 2024 BMW i4 [0.00]
2016 F31 330i M Spo ... [9.00] 2019 718 GTS [0.00] 2001 Audi RS4 SOLD [0.00] 2008 E91 335i SOLD [0.00] |
I think the LCI2 DRLs are a nice upgrade and big savings on LCI cars.
Stuart, what is the total cost, parts and labour to do the headlights? |
02-18-2018, 11:38 PM | #11 | |
814
Rep 5,530
Install and coding is a much smaller cost at $450. |
02-19-2018, 02:21 AM | #13 |
SCHNELL
227
Rep 835
"Well that’s off my list lol". My list?: BM3 flash, E85, BMS meth kit, Cup2's, Pure Turbo Stage 2, charge pipes, Dodson clutch kit, Pagid pads, catless DP, M4GT4 canards. That'll do donkey.
02-24-2018, 11:13 PM | #15 | ||
36
Rep 78
What was your username again I forgot???? |
07-09-2018, 02:51 PM | #16 | |
1709
Rep 2,053
In other threads I've seen reference to needing (6?) modules, needing to run two additional wires from the main fuse box, and a possible additional passenger side wire harness. Or—are you including all of those parts in this retrofit from pre-LCI LED? Thanks!
Moved to the darkside: '23 718 GT4; 11-10-2022.
Le Mans Blue F80 - Munich 5-22-2015 / US 7-7-2015 / SOLD 9-17-2022 ED RecapArctic Grey G05 - Spartanburg 8-29-2019 X5 PCD Recap |
07-10-2018, 01:18 AM | #17 |
464
Rep 495
I'd love to do the LCI 2 headlight retro-fit but it's too damn expensive!
I think the new headlights transform the whole car. I wish the headlights were like this from the start.
2018 ///M3 ZCP
Mineral White | Black Leather | DCT |
07-12-2018, 02:16 AM | #18 |
Rep 30
Drives: F82 M4 Competition + F20 118d
Great job! I love the LCI headlight look. Who did the work on the car?
11-07-2018, 04:51 AM | #19 |
144
Rep 931
ALL functions (Automatic , cornering etc etc ) work correctly ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
04-21-2020, 06:36 PM | #20 | ||
Rep 8
5218201a73.00 |
04-22-2020, 04:05 AM | #21 |
26
Rep 133
Search the forums, only a few members will make it for you otherwise it's DIY which is well documented in this forum.
If you have Xenons 14-15 then u will need the extra wires. If '15 July+ LCI with LED, it's plug and play. The drivers side u just need to cut the zip ties to extend a cable the bit more to reach. Then 5 minute coding |
