04-25-2020, 11:03 AM | #1 |
377
Rep 416
Tuning Boxes
Anyone got any previous experience with this company?
Gains off this box is good. https://tdi-tuning.com/car/bmw/1-ser...uning-box-chip |
04-25-2020, 01:00 PM | #2 | |
62
Rep 41
No personal experience but 20% off at the mo by the looks of it! Hmmmmmm Better gains than Racechip - not sure how much their warranty would actually be worth either! If only they could add pops and bangs! 🤔 |
JustChris17607.00 |
04-25-2020, 01:40 PM | #3 | ||
377
Rep 416
Also from a safety point of view you don't really need to be running full power all the time, 340-350 mark for playtime and 310-330ish normally. |
04-25-2020, 06:13 PM | #4 | |
282
Rep 1,491
With turbos, it's very simple to get more power — just add boost! But, unless you also add some fueling to mitigate detonation, the results can be disastrous!
BMW F22 M240i; F48 X1 25i, BMW F20 M135i
Peugeot T9 308 GTi 270 Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182. |
MrFoxy376.50 |
04-25-2020, 07:03 PM | #5 | ||
377
Rep 416
And what would you need to look for to determine if the tune is safe? I wouldn't even know where to start mate |
04-25-2020, 10:53 PM | #6 | |||
282
Rep 1,491
That's why I like to check if tuning companies are providing a full set of data, to see if they are safe. If not, then — personally — I stay well away from that company.
04-26-2020, 02:45 AM | #7 | ||||
377
Rep 416
Surly if a sensor wasn't connected an error would flash up? That's probably enough to put people off 😂 I'll phone this company on Mon and see if they'll give me the AFR charts 🤷🏼 if so I'll put them up mate |
ttimbo281.50 |
04-26-2020, 11:35 PM | #8 | |
457
Rep 359
I was sceptical about the racechip when I first got it back in 2018 for my f30.. After following RC for some time now and watching all of their other car tunes, I feel more comfortable in their work. Especially after the tuners took us through the detailed process of whats involved to get a car map-to production. For RC the sensors connect to the turbo boost sensor, intake pressure sensor and Cam position sensor. So my thoughts are that they monitor air-fuel ratios and ignition timing. Last edited by knali8; 04-26-2020 at 11:48 PM.. |
MrFoxy376.50 |
04-26-2020, 11:44 PM | #9 | |
457
Rep 359
Ttimbo what tuning have you got on your M? Last edited by knali8; 04-26-2020 at 11:49 PM.. |
04-27-2020, 02:30 AM | #10 | ||
377
Rep 416
ElmoMan12.00 |
04-27-2020, 07:28 AM | #11 |
377
Rep 416
Here is the data sheet that's been sent to me after a phone call.
https://www.tdi-tuning.com/variant-datasheet/13043 The guy was brand new! And didn't flinch when I was firing questions at him. He says the gains are possible due to BMWs new turbo 🤷🏼, the gains they were getting are higher but they are keeping the box at 362bhp when at full power. Also said to bare in mind they have been trading for 16 years and never had any issues with there products. DMS are into the 400s in power? Merc is managing 400+ standard also a 2L. Stuff to think about lads!! https://www.tdi-tuning.com/car/bmw/1...p?currency=GBP ✌🏼🤘🏼 |
JustChris17607.00 Stan_Brook61.50 |
04-27-2020, 03:19 PM | #12 | |
62
Rep 41
Did quite a bit of research into TDI tuning and def seem to be well received on the whole. No idea what I am going to do really. Guessing it’s best to wait until after run in period is done so have a bit of time to make my mind up. How do these sorts of mods go down with insurance companies?! How would you describe it to them without them running a mile!? Currently insured with BMW who are not particularly friendly about modifications but due to renew in May.... |
04-27-2020, 08:31 PM | #13 | |
457
Rep 359
Some facts to consider and a couple of things I have picked up during my research: BMW's new B48A20T1 engine has: New pistons Stronger crankshaft with bigger main bearings Stronger con rods Upgraded turbo with a max boost pressure of 2.7 bar/38psi @1025°C Compare this to AMG A45s, their turbo at 2.1bar/30psi My car is currently running about 26psi @315hp Applying some basic maths, if the boost pressure is raised 30psi like in the A45s, you get 363.5hp. The graph looks smooth so without looking into it too much it. My only concern is that; if you watch the Racechip clip, they managed to get higher numbers but had to pull back the tune due to reliability issues (temperature & ignition timing). And here's where I think 'what is considered a safe tune' is different amongst tuners. On the flipside Tdi might be really good at tuning engines! References: Last edited by knali8; 04-27-2020 at 09:51 PM.. |
Stan_Brook61.50 ~RS3.00 |
04-27-2020, 09:38 PM | #14 | |
457
Rep 359
04-28-2020, 10:47 AM | #15 | |
62
Rep 41
I think for me I will be getting quotes in May to see what it’s like based on having a tuning box to test the water. |
04-28-2020, 05:36 PM | #16 |
62
Rep 41
#truetune is another option but can’t recall if I stumbled across it on here or not so link below.
https://satuning.co.uk/truetune/ Annoyingly the F40 doesn’t appear on their model selector but having been in touch with them they map to 360bhp / 540NMs which is similar to TDI but SA Tuning is flashing the ECU via OBD rather than piggyback. They say the flash counter is reset though when returned to stock so can’t be detected by dealer.... 🤔 Quoted £399 but you only get the one map rather than a choice of a few to play with. More can be purchased for those wanted to go to different stages. Something else to throw into the mix! Will be glad to go back to work to stop looking into all this! |
04-28-2020, 05:58 PM | #17 | |
377
Rep 416
For me going in through the ECU isn't an option just yet, sensor box is the safest I think pending the tune is safe 🤷🏼*♂️ TDI's box does look good and first setting is 340hp but your not getting 500nm till mode 5 with 360hp. So why was RaceChip 339hp and 500nm... this would give you a sore head lol |
04-28-2020, 07:21 PM | #18 | |
457
Rep 359
This would definitely be a concern! It will be good to know how much extra insurance would cost to include the box |
04-28-2020, 07:45 PM | #19 |
457
Rep 359
360hp 5xxnm seems to be an ideal max figure poping up.. im questioning the RC tune now 🤔
I think having the option to select different tuning levels is an added advantage for the price however, if you want pops and bangs, then you might be better off going with the ecu tune and add in pops and bangs.. 360hp will be at the very top of the rev range anyway so you are not stressing the car always. Interestingly, I did my first Launch the other day and my wife was in the car with me recording the launch, the car shot so hard (zero wheel spin) that my wifes phone slipped off her hands and hit her on the face! so I can imagine 500nm would be a lot of torque down low. On the RC box max torque (500nm) comes on from 3k to 5k. Last edited by knali8; 04-28-2020 at 08:04 PM.. |
04-29-2020, 10:04 AM | #20 | |
62
Rep 41
Did a bit of research into insurance last night and for me it went from £350 to £550 but haven’t really spent much time on it yet. Would be acceptable to me to pay somewhere in between to have it all covered..... |
04-29-2020, 10:08 AM | #21 | ||
377
Rep 416
04-29-2020, 03:07 PM | #22 |
62
Rep 41
Don’t know a huge amount on the subject other than what I have researched recently.
The below is a crap video from someone having a rant and slagging off a competitors piece of kit but actually informative and makes sense To me at least.... https://www.youtube.com/watch?v=QNu17zA1sRg |
MrFoxy376.50 |
