MY N53 (NOX, Injectors, rough run, sooty exhaust) Is running badly how do I diagnose
10-12-2019, 04:33 PM | #89 | |
34
Rep 187
If that's what happens, then simply coding a new nox cat will not help, because all of that nox ppm will just fly through the cat not neutralized and sensor will still see higher than usual nox ppm. Which is not great because that's exactly what I did - coded new nox cat without replacing anything yet.
Current: 2017 F30 330e PHEV
Past: 2007 BMW E93 N53 Convertible |
10-12-2019, 04:37 PM | #90 |
34
Rep 187
I think they will be quoted often as there is tons of technical knowledge on their page, the trick is to filter out the disinformation that promotes NOXEM as the only viable solution.
jirka330i21.50 Will_460cs213.50 |
10-12-2019, 06:05 PM | #91 |
34
Rep 187
I'll be installing NOXEM on Monday. Kinda scared now a little after reading about the problems, but hoping it will work fine.
Any suggestions? Should I put anything onto the insert or threads? How much force to use then tightening it?
10-12-2019, 07:18 PM | #92 | |
46
Rep 183
Some have mapped, some have NOxEM both from everything everyone has said and I've read are the only 2 options available and both have pros and cons! |
10-13-2019, 12:29 AM | #93 | |
22
Rep 83
5AZ NOX sensor to exhaust system N53 M20 New part 52 Nm and make sure you apply some antiseize (Loctite or so) on the thread...BUT! make sure the head of senzor remains clear! and finally...GOOD LUCK!...at least better luck than me |
schriss33.50 |
10-13-2019, 12:39 AM | #94 | |
22
Rep 83
10-13-2019, 12:50 AM | #95 | |
22
Rep 83
Will_460cs213.50 |
10-13-2019, 01:05 AM | #96 | |
22
Rep 83
Interesting experiment would be to connect bosch wideband probe to oem nox unit (where the nox head already died)...if the output signals of ngk nox probe and bosch wideband probe were similar it might work...but it would be too simple as I guess that bosch probe has a different output which is then "corrected" in the analogue part of nox unit...while digital parts (those reporting to ecu via canbus) are probably very same in oem nox and noxem... |
Will_460cs213.50 |
10-13-2019, 03:19 AM | #97 | |
34
Rep 187
It might be a pain to later remove the insert from the pipe in case whatever fails...
10-13-2019, 04:33 AM | #98 |
22
Rep 83
definitely apply antiseize in the outside thread of the insert....but my problem was to get insert from the pipe even though loctite was applied..bosch sensor itself came out very easily (after couple of weeks in place...)
10-13-2019, 04:42 AM | #99 |
22
Rep 83
..and maybe check with some experienced mechanic..I think that the catch here could be the size of the thread...TIS refers to the thread M20! While noxem is M18 with this strange insert. When I checked (before installation) about the torque with bimmerprofs they responded something like "...no big deal...no high pressures in the exhaust...you can follow TIS..." so my mechanic applied 52Nm ...couple of the weeks later the sensor went out easily but the insert stayed in the pipe and broke in 2 parts when mechanic used special tool to get it out...I do not know whether that was rather result of the correct torgue on incorrect sensor or just a low quality issue of the insert
10-13-2019, 05:39 AM | #100 |
34
Rep 187
I will be doing it in a garage so will ask mechanic before I do anything.
But antisieze and loctite are like the opposites as far as I know. Antisieze is more like grease to prevent rust while loctite is like glue. I do have red and blue loctite I used in my RC helicopters, I remember one was more like permanent and the other was to prevent screws from self-unscrewing due to vibrations, but easy to remove (not super hard permanent). So unless there is a risk of this coming out by itself due to vibrations, antisieze is probably the only thing needed. EDIT: found it: "The red products are so powerful that they require heat to be disassembled. Loctite® Blue Threadlocker is of medium strength can be dissembled with hand tools." I would assume if loctite is used, the probe will come out easily and the insert will not and it will have to be picked with some pick tool breaking it in the process.
10-13-2019, 05:46 AM | #101 |
34
Rep 187
Actually, I could use blue loctite on the probe itself so that the insert glues a little bit to it and then antisieze on the outside thread (outside of the insert). This way when its taken out later, more likely the probe will come out with insert still attached to it.
Again, I'll have to check with mechanic what he thinks.
10-13-2019, 06:08 AM | #102 | |
22
Rep 83
I think it should not definitely be any threadlocker...the temperatures in the exhaust when regeneration runs are well over 600 celsius EDIT : perhaps it is this one... https://www.grainger.com/product/LOC...Compound-2VFF3 |
10-13-2019, 06:20 AM | #104 | ||||
214
Rep 465
If you want cheap buy a replacement 8 wire nox probe and reuse the existing electronics.. |
10-13-2019, 06:21 AM | #105 | ||||
214
Rep 465
Please don't use loctiite of any type! Taking out the old sensors requires use of a small propane blow torch and lots of wd40 + plenty of patience !! as they are seized in place and corroded.. |
10-13-2019, 06:24 AM | #106 | |||
214
Rep 465
This is like the age old argument of using copper grease on spark plugs!!! It is always Recomended that any sensor is fitted dry with out anti seize as anti seize can effect the sensor Operation, the sensor has a nickel layer if I remember which is in effect the the anti seize provided by the manufacturer same as spark plugs! Ngk wrote an in-depth article on spark lubrication if you want to know more |
10-13-2019, 06:38 AM | #107 | ||||
214
Rep 465
The nox delete is a misnomer, everything is still in place however the error condition is deleted... you see a shadow code which is unknown in the ecu... mine used to fail for the the heater element of the probe... now I see a a unknown code... and all 3 modes work |
10-13-2019, 06:40 AM | #108 | |||
214
Rep 465
10-13-2019, 06:40 AM | #109 | |
22
Rep 83
Installation: If an oxygen sensor is reused, only apply a thin and uniform coat of Never Seez Compound (refer to BMW Parts Service) to thread. The part of the oxygen monitoring sensor which projects into the exhaust system branch (sensor ceramic) must not be cleaned or come into contact with lubricant. |
10-13-2019, 06:44 AM | #110 |
34
Rep 187
With spark plugs, the thread is the ground, you don't want to isolate that, so that's why they argue what to use and what to not use. (electric conductivity).
Ok then, will just put the probe in as is.
