08-08-2019, 10:15 AM | #1 |
202
Rep 192
Off-center/loose steering wheel
Hoping for a bit of diagnostic help here so I can direct my indy appropriately.
Searched a lot but haven't found a clear answer to my specific issue, no attention in the maintenance section. Steering wheel is off center by maybe a 1/2" or so to the left when the car is tracking straight, meaning I'm constantly driving with the wheel slightly turned left. I had an alignment done recently which I hoped would solve this but didn't. I've also noticed that the steering feels slightly "looser" to the left than it does turning to the right. Not sure if this is just perceived in my head though due to the fact that its already off center (hence the feeling that going just slightly past center to the right has a tighter feel than the other direction). Front tires are new (had this issue long before getting them changed), tire pressure is correct all around. Anyone else dealt with and solved this or have an idea as what specifically I should be asking them to fix/adjust? Huge thanks in advance! |
08-08-2019, 10:23 AM | #2 | |
120
Rep 371
08-08-2019, 11:09 AM | #3 |
202
Rep 192
Thanks, it was sub-contracted out by the indy that does all the work to one of their partners so I would wager that the procedure may not have been followed correctly, however I was experiencing this issue prior to the alignment being done..
08-08-2019, 07:50 PM | #5 |
1438
Rep 3,015
get an alignment, I do mine every year just as an inspection on the control arms also.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
08-08-2019, 09:07 PM | #6 |
90
Rep 151
Drives: 2013 M3: E92, ZCP, DCT
What does this special procedure entail? Is it something a standard reputable alignment shop would know or is it something I should do at a BMW-focused shop?
-Mike M.
2013 M3 [E92, Alpine White, ZCP, DCT] 2016 i3 REx [Tera World, Capparis White] |
zipper228201.50 |
08-09-2019, 10:18 AM | #7 |
202
Rep 192
08-09-2019, 08:55 PM | #10 |
1438
Rep 3,015
If you have had issues even after an alignment, you might want to check the tie rods and control arms. The slightest bend in them you cant even see will have your car steering/pulling to one side.
Drifter2090913.50 |
08-17-2019, 04:58 AM | #12 | |
98
Rep 615
What procedure is unique to bmw m3... so I can explain to the shop when I get them to re check it?
2009 E93 M3 Jerez on Black DTC
HnR Sport springs, GT2 Meistershaft Exhaust. GTS Tune. Love It |
08-17-2019, 08:44 AM | #13 | |
4489
Rep 7,141
Btw various good info here: https://www.m3post.com/forums/showthread.php?t=367003 |
