Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      08-14-2016, 02:04 AM   #1
Bucketsbentley
18
Drives: BMW M4
Why 666M on GTS?
Wondering why BMW would put the 666M wheel on the GTS, rather than choose a lightweight wheel that would reduce unsprung weight significantly
      08-14-2016, 02:08 AM   #2
schnell325
Bored at work....
schnell325's Avatar
893
Drives: 2016 F82 M4 GTS//2022 M235iGC
What's the weight of the 666's?
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      08-14-2016, 02:12 AM   #3
Bucketsbentley
18
Drives: BMW M4
25lbs front, 26.5lbs rear, according to IND
mshab356275.50
      08-14-2016, 02:17 AM   #4
schnell325
Bored at work....
schnell325's Avatar
893
Good info
      08-14-2016, 03:26 PM   #5
Draper
Draper's Avatar
3468
Drives: M4 Comp / Macan Turbo
The GTS wheels are not the same as the CP wheels. GTS has 19in front, 20in rear.
Maybe they're lighter too?
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic - for sale
      08-14-2016, 04:08 PM   #6
Bucketsbentley
18
Drives: BMW M4
Weight measurements above are for 19" front 20" rear. Happy to be proven wrong that the GTS wheels are somehow different, apart from the paint of course
      08-14-2016, 09:08 PM   #7
Draper
Draper's Avatar
3468
IND weighed the standard CP 666M wheels which are 20" front and rear.
      08-16-2016, 05:03 AM   #8
Bucketsbentley
18
Drives: BMW M4
I'd thought they'd have offered lighter wheels too. This is what the GTS technical training manual says:
"As standard, forged 19” M light-alloy wheels are used at the front and 20” M light-alloy wheels at the rear in 666M styling."
I guess this is why they offer the carbon wheels as a way to reduce weight
      08-16-2016, 09:28 AM   #9
CanAutM3
General
CanAutM3's Avatar
21132
Drives: 2021 911 turbo
A few data points on dimensions and weights:
  • GTS 681M - 19X9.5 20.4lb / 20X10.5 24.2lb
  • GTS 666M - 19X9.5 24.0lb / 20X10.5 28.4lb
  • ZCP 666M - 20X9.0 25.3lb / 20X10.0 27.1lb
  • STD 437M - 19X9.0 22.9lb / 19X10.0 24.2lb
When you consider that the front GTS wheel is 0.5 wider than the 437M, the 1.1lb weight penalty is not that bad. Maybe they made the 666M very sturdy.
But I still find the 666M wheels quite heavy compared to the 437M though. I had much higher expectation when BMW advertised the 666M to be "weight optimized" .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
Appreciate 4
Pennzoil130.00
mshab356275.50
Stronie313.50
      08-17-2016, 02:05 AM   #10
Bucketsbentley
18
Drives: BMW M4
Totally agree. Don't know why BMW didn't opt for the sort of lightweight wheels Porsche fit on their GT3/GT3 RS.
BBS FI-R weigh in at 16.5lbs front, 18.5lbs rear with M4 GTS spec.
Weight-saving for all 4 wheels is 34.8lbs (15.8kg)!!!
http://f80.bimmerpost.com/forums/sho....php?t=1155359
mshab356275.50
      08-17-2016, 09:11 AM   #11
Nate@IND
BimmerPost Supporting Vendor
Nate@IND's Avatar
2875
Drives: BMW
GTS should have came from the factory with BBS FI-R's
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
Appreciate 5
      08-17-2016, 12:06 PM   #12
te37
te37's Avatar
546
Drives: F80 SS/SO 6MT
You guys are forgetting about the carbon wheels
      08-17-2016, 12:15 PM   #13
Bucketsbentley
18
Drives: BMW M4
The point I was making is that BMW are not fitting lightweight wheels as standard. Carbon compound wheels are an option at a considerable price
      08-17-2016, 12:16 PM   #14
CanAutM3
General
CanAutM3's Avatar
21132
Even the 681M Carbon composite wheels are quire heavy compared the BBS FI-R:
Originally Posted by CanAutM3 View Post
Starting with the weights of the GTS 666M wheels and (grossly) estimating the 7kg is split at 1.5kg for each front wheel and 2.0kg for each rear wheel, we can estimate the following weight for the 681M CF wheels:
~20.7lb front
~24.0lb rear
      08-17-2016, 12:23 PM   #15
CanAutM3
General
CanAutM3's Avatar
21132
The weight you quoted seem to be for CP 666M (they are very close to the ETK quoted weights). It is important to note that beyond the fact that the front GTS wheel is a 19", the GTS front and rear wheels are also 0.5" wider than the CP, which increases their weight.
      08-25-2016, 01:35 AM   #16
mshab356
Go ///M or go home
mshab356's Avatar
276
Drives: 2015 F80 M3 6MT
~20.7lb front
~24.0lb rear
That is just ridiculous. 20.7/24 lbs?? Get outta hear with that malarkey.
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT
      08-25-2016, 10:59 AM   #17
SROC3
The limit of adhesion is my home.
SROC3's Avatar
1703
Drives: Like a Boss.
Didn't the GTS do the 2nd fastest time around the Nurburgring on these wheels?
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
      08-25-2016, 11:05 AM   #18
CanAutM3
General
CanAutM3's Avatar
21132
2nd to what ?
The point is that the weight of the 666M wheels is not a big contributor to the M4 GTS' good performance.
      08-25-2016, 11:40 AM   #19
davey111483
davey111483's Avatar
109
Drives: my GF crazy!
2016 BMW M4 ZCP  [0.00]
Tbh, i just switched my 666m to the 437m wheels and i don't know for some reason my car felt slower. i don't know if it was the tires or whatever reason, maybe psychological, but i felt like my car doesn't feel the same. lol. maybe i'm just getting used to the 19s.
What is power without control?
      08-25-2016, 12:03 PM   #20
myzmak
Advocatus Douchebagus. Sex Marxist.
myzmak's Avatar
2417
Drives: Lucy.
2015 F80 M3  [10.00]
2013 MB E350 Wagon  [10.00]
Because Satan, obviously.
Drivin' Lucy
CanAutM321131.50
      08-27-2016, 04:08 AM   #21
Rasya
Rasya's Avatar
Belgium
37
Drives: 2011 BMW 1M; 2016 M4 GTS
2011 BMW 1M  [10.00]
2005 BMW e60 M5  [0.00]
I think they wanted a really stiff and sturdy wheel seeing probable track use?
Porsche 991 gt3 wheels are also 24-28 lb front-rear...
      11-14-2016, 12:25 AM   #22
MW16M3
58
Drives: 2016 BMW M3
The 666m's probably felt faster to you because it took you longer to slow down..
f80post
