8/12 Test N Tune at Pacific Raceways
08-10-2011, 01:19 PM | #1 |
60
Rep 1,065
Drives: RB PWRED E90 N54 6MT
8/12 Test N Tune at Pacific Raceways (Slips included)
Hi guys,
this coming Friday, the 12th, will be the last Test N Tune at Pacific Raceways for this year. I'll be there to test out my newly installed methanol injection kit. I'm wondering if anyone else from here is attending this event?
RB Turbo/Procede V5/Vishnu PWM Meth Injection Kit/Vishnu DCI/AR Catless DP/AE Performance Exhaust(Sold)/Helix FMIC/Forge DVs/Rixster Vent Boost Gauge/Wavetrac LSD/KW V3/ACT Street Clutch Kit
08-10-2011, 03:56 PM | #3 |
60
Rep 1,065
Nice. Maybe we can shoot some videos for each other.
08-10-2011, 09:54 PM | #6 |
60
Rep 1,065
Should be able to see some mid to low 12's numbers with my current setup. 11's will be tough with street tires.
08-11-2011, 01:25 AM | #7 | |
198
Rep 4,647
but who knows if your 60ft comes out good, then it might also be possible. i hit 1.7 something on 60ft for my record run (admit that was rather luck than skill ). i hope you get to run a lot of times and hopefully break into 11's. i ran like 17 times on my last day of T&T last year. luckly no accident until towards very end so... have fun and record back!
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers |
08-11-2011, 11:38 AM | #8 |
Seattle Area
52
Rep 363
I am attending the Car Control Clinic tomorrow so there will be a bunch of Bimmers there
1999 M3 Estoril Blue/Dove 1974 2002 Inka 2013 135is Alpine White 3 |
08-11-2011, 12:26 PM | #9 | ||
60
Rep 1,065
I'll bring mine!!
Do you still remember how did you launch to achieve 1.7? Quote:
Hopefully some of you guys will stay for drag.
08-12-2011, 03:59 AM | #10 |
Sticky Mess.
Rep 156
Drives: e90 DS 2
Me in my e90 and my buddy in his flying Miata will be there. happy to see what I do here, vs in utah.
08-12-2011, 12:27 PM | #11 |
113
Rep 2,015
buy my DRs :P
08-12-2011, 01:13 PM | #12 | |
60
Rep 1,065
I have to save some money to fix my front bumper.
08-13-2011, 03:05 AM | #13 |
60
Rep 1,065
It was a dissapointed day for me at the drag strip today. I had absolutely no idea how to cut down the 60' time.
Spoke with Jeff Butler, one of the instructors of BMW CCA, and he said we should be seeing at least mid 12's of ET with my trap speed. These were the best two runs that I did today. #5308 Last run with #523 (First Generation Eclipse) was pretty exciting though. I was still behind him at 1000' and finally caught up with him right before the line. Mods: Procede V5 7-29 beta map (map 4 @ 16.5 psi) FBO 50/50 methanol mix Roughly 2~2.5 gallons of Shell 92 and 4 gallons of Trick 101 Maybe the boost and methanol mix were a little bit too conservative? The best run were actually done with the traction control on. (Forgot to shut it off!!) LOL
08-13-2011, 08:04 AM | #14 | |
62
Rep 1,476
It must of seemed like you blew his doors off at the end with a 5mph advantage? |
08-13-2011, 10:55 AM | #15 |
829
Rep 3,982
Was it a TSX or AWD Mitsubishi? If so, perhaps the track is just too slippery. Last time out when I ran the 11.26, track conditions started to deteriorate so much I actually had a run in the 12's. I just gave up after that, wasn't interested in going into the wall.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
08-13-2011, 05:09 PM | #16 |
198
Rep 4,647
ah man. this is bummer... i would expect you to run mid to low 12 at the very least.
well, as i pointed out, i don't think the power was the issue (i ran 12.3 without meth and 1:4 gal of 92/101 on street tires) rahter the traction so DR with good 60ft might've shave another minute or so... how many run were you able to go? p.s. btw, my launch was rather simple because mine is auto. just playing around RPM range at launch and toggling between M1 and M2. think i overall god better time with second gear if i remember correctly but my best 60ft came from first gear start and i launched it around 3k rpm or something...
08-13-2011, 06:54 PM | #17 | |
60
Rep 1,065
12.3x with no meth is quite amazing. I think Eric's best time was 12.3x as well with meth. I guess AT is a lot easier than MT then.
08-13-2011, 06:56 PM | #18 | |
60
Rep 1,065
08-14-2011, 12:56 AM | #19 |
113
Rep 2,015
it's hard to launch in the turbo car, especially with the manual. because when the turbo kicks in the first gear, you're automatically lost the traction. if you can shift the first gear before the turbo kicks in. OR there is always a good option for you GET MY DRs! jk.
08-14-2011, 05:38 AM | #20 | |
198
Rep 4,647
when i and eric was there last year for the last day of t&t, we got to run like 17~18 runs and if there were no accdient, we would've probably ran like 20+ runs... u kinda get the kick of it after 4~5 passes so 8 run is sorta short... when did you get there? did you adjust traction nany or something like that (procede feature)? it helped my launch tremendously. i adjusted down to like 50% on first and second or soemthing like that... i wish i can help any better but i never actually ran any this year so everything that i say is so so outdated stuff probably... lol
08-14-2011, 12:56 PM | #21 | |
60
Rep 1,065
I was running the 7-29 autotuning beta map and if I remembered correctly, the traction nanny is disabled?
08-14-2011, 07:47 PM | #22 |
198
Rep 4,647
i'm still on V4. my last update was probably a year and a half ago lol.
i'm sure if you stay til the end, u would've hit mid 12's or something at the least... oh well, did u have fun at least? anything interesting that day?
