Helix DSP help. Help!
06-18-2014, 03:12 PM | #1 |
Rep 21
Hello fellow BMW audio enthusiasts! I recently purchased a Helix DSP and am stuck on getting it to work the way I want. I am sure it is something simple but I thought I would put it out there and hope that someone has done something similar or has experience with them. Here is the setup:
Car is an '06 325i (e90) with Hi-fi system. I am using the Technic harness to the Helix. Only using front RCA inputs to go out to front mids/tweets and under seat subs (4 outputs total). I have the front mids/tweets high passed and the 8" under seat band passed. I am using a 4 channel amp to run them. My problem is, the subs are not working. I get no sound out whatsoever. What am I missing??? Thank you SO much for any help you can provide! |
06-18-2014, 03:59 PM | #3 |
1911
Rep 13,104
You are not being specific with equipment.
You must list model numbers and the way its hooked up. What amps you have , What speakers you have and the model numbers . |
06-18-2014, 05:54 PM | #5 |
Rep 21
Good call, taibanl! I will see if I can find that adjustment. I snapped a couple pics of the screen but have forgotten how to post pics. Haha! I will see if I can fet tehm from my phone to the forum. Thanks all!
06-18-2014, 06:53 PM | #6 | |
Rep 21
I am only using front RCA from harness into Helix. 4 channels are coming out. 2 channels are high passed and the other 2 are bandpassed. |
06-18-2014, 09:03 PM | #7 |
Rep 21
Here you go, cdgatti. See what you think of this setup.
06-18-2014, 09:21 PM | #8 |
255
Rep 2,547
That looks fine, how about the input/output matrix screen?
06-19-2014, 08:30 AM | #10 |
2288
Rep 13,001
Why are you not using the rear OEM HU outputs as the rear inputs of the DSP?
There are no front inputs going into channel 3/4 outputs. That's the problem. By the way, the input/output settings are indeed in Page 20: http://www.helixhifi.com/downloads/a...ol_eng_web.pdf Last edited by Technic; 06-19-2014 at 08:48 AM.. |
06-19-2014, 08:51 AM | #11 | |
Rep 21
P.S. Please ignore your PM Technic. I sent it before seeing your reply on this thread. My apologies. Also, it appears that the right side of last image was cut off. It reads: A/B Front L/R Mid and C/D Front L/R woofer. Is that the correct way? Last edited by CDA325i; 06-19-2014 at 08:57 AM.. |
06-19-2014, 09:04 AM | #12 | |
2288
Rep 13,001
Either: A) Plug the rear harness RCA into the DSP ch C and D inputs. B) Set the output section of the DSP ch C and D to Front L Full and Front R Full instead of Rear L Full and Rear R Full. |
06-19-2014, 09:15 AM | #13 |
69
Rep 994
You have C and D set to use Rear R and Rear L when they should be Front R and Front L. That's why you have no sound. You have it set to use rear inputs but you have no rear inputs.
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
06-19-2014, 09:24 AM | #14 | |
Rep 21
Thanks mathematics!! I will try that when I get home tonight! |
06-19-2014, 09:25 AM | #15 |
69
Rep 994
No problem. That's 100% why you have no sound, provided everything else is working properly
06-19-2014, 09:33 AM | #16 |
Rep 21
Most excellent!! Makes sense now. BUT, I am going to add subs (along with a 2 channel sub amp) as soon as I get the box built. How will I get that incorporated into my DSP? I am out of RCA input cables.
06-19-2014, 10:02 AM | #17 | |
2288
Rep 13,001
Again... read page 20. Everything is there. |
06-19-2014, 10:13 AM | #18 | |
Rep 21
Edit: That configuration pic could be incorrect. I was in a hurry this morning to post it up from my laptop and might have chosen the wrong config file. |
06-19-2014, 10:19 AM | #19 |
255
Rep 2,547
Also for the matrix selection... you need to use every box on the line. For example for your front left underseat, choose 'front L full' in every box, I know it sounds redundant, but that is the only way the output will get the full power signal. Do not select 'not used' in any of the boxes on that line.
06-19-2014, 10:33 AM | #20 | ||
2288
Rep 13,001
You need to keep reading... input/output section starts at page 20.
06-19-2014, 10:51 AM | #21 | |
Rep 21
06-19-2014, 01:29 PM | #22 |
255
Rep 2,547
yea the center section. In a literature piece that i had from helix, it said to select a signal in every box of a line that is used in order to assure the output has full power. try it, can't hurt.
