F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Delayed Climate Control (cooling)
proTUNING Freaks
      06-18-2014, 09:17 AM   #1
glfwdw
61
Drives: 2022 X3M Comp
I understand in the winter, my auto climate control delays before increasing the fan speed. However, I noticed the cooling is also delayed in starting. In my E90, the A/C starts blowing cold air almost right away but my F32 seems wait a couple minutes before increasing the fan speed. Is this normal in the F30/F32 lines?
      06-18-2014, 10:04 AM   #2
KGB_123_99
404
Drives: '17 330ix M-Sport, '09 528ix
What if you put it on max A/C?
      06-18-2014, 10:08 AM   #3
Halsifer
Halsifer's Avatar
251
Drives: 2018 Audi RS7
If it's warm air inside the A/C and it's on Auto, it will not increase the blowers until cooled so it doesn't blow hot air in your face. So that's normal in the F30. But try as the last poster said and put on Max A/C. Should blow air pretty fast.
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP
2010 Audi S5 4.2L [Sold]
2014 BMW 335i xDrive M-Sport [Sold]
2010 Audi A6 3.0T [Sold]
      06-18-2014, 12:05 PM   #4
Caught Looking
14
Drives: 2023 M340i xDrive
I can't seem to get the fan to auto adjust (auto is lit) the blower speeds for the AC either. I can keep auto on and manually increase or decrease the fan speed without it taking it off auto but it never auto adjusts the fan speed.
      06-18-2014, 01:21 PM   #5
chiefneil
772
Drives: 2014 335i M-Sport
I noticed the same thing. I assumed it was something to do with the a/c now being electric, perhaps it has to wait for the battery to start receiving enough amps from the alternator, which itself is now some sort of smart gizmo that decides when and how to charge.
      06-18-2014, 01:38 PM   #6
Steven1077
England
240
Drives: M140i
It doesn't seem to work well on my 435i either, I thought the whole idea of auto was that it set the fan speed, but it never blows hard unless I tell it to
      06-18-2014, 01:49 PM   #7
Halsifer
Halsifer's Avatar
251
"Auto" makes it so the air amount, distribution location, and temperature are controlled automatically. You can select the temperature and Auto Intensity, and it will adapt based on cabin conditions and outdoor conditions. Air will be sent to the windshield, side windows, upper body, and into the footwell based on what the system thinks is necessary.
So when you increase the level of Auto, it doesn't increase the fan speed, just the intensity. On a side note, if you are using ASS, and your engine is switched off due to ASS, your A/C fan speed will slowly reduce because the engine is no longer running, meaning the A/C isn't running.
2018 Audi RS7 4.0T
      06-18-2014, 02:24 PM   #8
COKen
COKen's Avatar
981
Drives: M Rster / Z4 M40i / X5 M50i
Also, when you set the fan speed, you are only setting the max speed you would like the computer to use when needed. If you have the fan speed set to low, it will never go any higher, but if you set it on high, the computer will adjust the fan speed as neede from low to high.
      06-18-2014, 02:32 PM   #9
S4NoMore
S4NoMore's Avatar
253
Drives: 16 340i, 15 X3d, 91 318i
2016 BMW 340i  [0.00]
2015 BMW X3 28d  [0.00]
1991 BMW 318i  [8.66]
Normal as others have stated, the car won't blow hot air at you so the delay is for the compressor to work the refrigerant and get it flowing.
The AC compressor is not electric, it's conventionally engine-driven.
      06-18-2014, 02:46 PM   #10
Steven1077
England
240
Drives: M140i
Oh no wonder my fan never runs fast as I have it set low, I thought auto set the fan speed to suit the conditions
      06-18-2014, 03:05 PM   #11
Caught Looking
14
Which doesn't make much sense since prior BMW's did this
      06-18-2014, 03:09 PM   #12
OC40
51
Drives: 335i MSport + MPS/MPPK
2013 MINI S  [0.00]
2013 BMW 335i  [0.00]
Delete. My error.
      06-18-2014, 03:14 PM   #13
Caught Looking
14
Originally Posted by OC40 View Post
Delete. My error.
Not an error. I should have been more clear that prior BMW's did auto adjust the fan speed to cool down the car and then would auto lower the fan speed as the interior temp became cooler and cooler.
      06-18-2014, 03:43 PM   #14
COKen
COKen's Avatar
981
It still does. It's just that you can set the max speed it will use. It can still use lower speeds than the one you set.
      06-18-2014, 03:44 PM   #15
OC40
51
2013 MINI S  [0.00]
Delete. My error.
It was my error. I wrote something and then realized that I misinterpreted your original post. I removed my comment as I couldn't delete the entire post from the app.
f30post
