jack advise needed (fixed pics)
12-06-2007, 04:55 PM | #1 |
18
Rep 201
i stopped by my local pepboys and found a jack that had a removable plate. Wondering if this jack will work with me using the plate or removing it.
jack jack adapter w adapter jack without its adapter jack without its adapter and car adapter Last edited by cas; 12-06-2007 at 05:40 PM.. |
12-06-2007, 07:03 PM | #2 |
129
Rep 1,048
I think it would work best without its adaptor (the third picture from the top) - With both it will never fit under your car.
I place a 5/8" or so socket inside the plastic surrounding the jacking points with a jack similar to yours and the jack fits directly underneath. |
12-06-2007, 07:25 PM | #3 | |
18
Rep 201
it could work that way. talking with TORIN the jack maker they say the last picture will work. |
12-07-2007, 07:48 AM | #5 |
15
Rep 649
My jack looks similar to your first picture but the plate is not removable. No big deal; I cut a piece of wood to fit in the jack point on my car. Works fine.
12-07-2007, 07:59 AM | #6 |
18
Rep 201
I purchased Josh's jack adapter. Used to use one with an audi I owned and liked that it didnt damage the jack point. I would like to use Josh's adapter shown in the 2nd and last pic
12-07-2007, 11:51 AM | #7 |
137
Rep 1,914
That's what I do as well . But I did have a problem getting the jack to fit underneath the front rocker panel. Even in the fully lowerd position, My inexpensive Chinese made jack would not clear the panel. I had to put the front tires on a small step to gain clearance.
12-07-2007, 12:38 PM | #8 |
252
Rep 6,664
Whatever setup you are interested in, I personally would do a drop of machining.
In the first setup I would put a pocket in the bottom of the adapter block so that the adapter block sits on top still, but now you have the diameter of the pocket close to the OD of that cup acting as a lateral constraint. I have done that a few times now for members here, that comes out real well IMO, every one so far has fit like a glove.. Second setup I would want something to provide lateral constraints from that bottom piece to the adapter. You don't want the adapter block slipping off the top of that flat rectangular piece. Different ways to accomplish this. Machine away the bottom ~0.250" leaving a circular extrusion on the bottom of the adapter block that fits into the hole, put some hardened steel pins sticking out on the bottom of the block and touching that hole diameter diameter so that it can't move, etc.. Personally, I like to see some lateral constraints. Glad you got the part.. Josh
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
12-07-2007, 12:53 PM | #9 | |
18
Rep 201
Josh,
Thanks for your advise. Instead of sending your adapter back I think Im going to get the aluminum jack that everyone has. though this got me thinking of just putting down some rubber where I pulled the jack pad off the jack. Quote:
12-07-2007, 01:19 PM | #11 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
When I jack up my car, I slide Josh's adapter into the plastic piece under the car, then slide the jack under that. This way I know its centered on the jackpad.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
12-07-2007, 02:43 PM | #12 | |
252
Rep 6,664
Yeah I sent you a link a while ago for a harbor freight jack that a lot of people are using/are happy with.. Looks like the similar craftsman jack (which I have) is no longer on the sears website..
12-07-2007, 03:21 PM | #13 | |
18
Rep 201
actually PEPBOYS here in jersey had the same aluminum jacks like everyone shows from sears or that blue michelin jack. the aluminum jacks only have a 1.5 ton rating while this one had a 2.5 ton. I dont know really how to size jacks. Im really only lifting a 1/4 of the car I assume. |
12-07-2007, 03:38 PM | #14 | |
252
Rep 6,664
I haven't said this before in this thread, so I'll say it as a general statement to everyone, always make sure to put a jack stand, cribbing, etc under the frame as a failsafe while your car is lifted/you're doing work on it..
12-08-2007, 12:00 AM | #15 |
Rep 586
I used a wood block on top of my floor jack for awhile, but one day it cracked, the car didnt fall off the jack or anything. I went out and got a 1/4" steel plate because i know that wont crack or slip.
12-08-2007, 12:31 AM | #16 |
this is the way
18339
Rep 8,553
Do it cheap and right all in one...
First off if your jack is too tall return it and get this. It's even on sale!
http://www.sears.com/shc/s/p_10153_1...jack+craftsman Next go to any sports store and buy a hockey puck. It cost $1 and works like a charm. This is the jack I have and I've used it with the hockey puck without any issues and it doesn't leave a scratch. |
12-08-2007, 07:50 AM | #17 | |
18
Rep 201
12-09-2007, 12:36 AM | #18 |
this is the way
18339
Rep 8,553
12-09-2007, 01:46 PM | #19 |
15
Rep 649
Hockey pucks are vulcanized rubber, yes? (I don't play hockey). They don't get crushed under that weight? This is safe?
12-09-2007, 10:06 PM | #20 |
this is the way
18339
Rep 8,553
Nope, they won't get crushed and it barley makes an impression on them. You would be surprised how strong a puck is. It's safe as long as you center the puck which is common sense and won't slip because it's rubber. I learned this trick from a tire shop that works on a lot of BMW's. I saw them using the hockey pucks and talked to some of the shop guys who showed me a stack of pucks they use on Bimmer's.
12-10-2007, 09:13 AM | #21 | |
15
Rep 649
I guess I knew hockey pucks were somewhat strong given what I've seen of hockey players' faces. |
12-10-2007, 10:00 AM | #22 |
252
Rep 6,664
The hockey puck idea could work, although I would think you would still want to cut it to fit within the jack block. Then you are lifting through a solid medium from jack to frame, and not lifting through a flimsy shell walled piece of plastic. Next time you're under your car feel the walls of the jack block, and move it around. Then feel inside of the jack block. It should become apparent what you want to be lifting through. Just my 2 cents.
