Pictures of my audio install - DA2, Helix DSP, Mosconi amps
06-16-2014, 06:58 PM | #1 |
136
Rep 1,192
Drives: 2011 335i MT
First of all, special thanks to all those on this forum who have generously provided information, including Kaigoss69, Ctuna, Technic, VP Electricity, 6spdcoupe, etc.
I first updated all my drivers:
I had already decided to have a professional install a Dynaudio 1200 subwoofer in an infinite baffle configuration and run separate cables for the tweeters, so I decided to have them install the amps, Mobridge DA2, and Helix DSP as well. Chris Pate and his crew at Mobile Toys in College Station did the installation. As a part-time musician, I wanted room to haul my percussion gear to gigs so I asked that there be room in the trunk. At first glance, the trunk appears stock: If you crouch down, you can see the amps mounted on the roof of the trunk as well as the Dynaudio Esotar 1200 mounted infinite baffle: The Mobridge DA2 and Helix DSP are mounted where the OEM amp was. You can see how they tapped into the OEM harness so that the car can be restored to stock at a later point: |
06-17-2014, 10:01 AM | #4 |
Rep 21
I can't quite see how the DSP is connected to system in the 3rd pic. Please explain how it was done as I am going to do something very similar to this. Thanks!!! And are you firing sub thru the ski pass?
06-17-2014, 10:46 AM | #5 | |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
06-17-2014, 09:47 PM | #6 |
136
Rep 1,192
Sounds great but still EQing. I used a measuring tape to measure distances and entered them into the Helix and I have quite a nice image. I am in the process of using an RTA to EQ. The Helix software is very easy to setup and use. Once I have it fully EQd it should sound very good indeed.
The Dynaudio 1200 is very impressive ("prodigious") and the IB install works well - the sub bass appears to originate from the front of the car. Current crossover frequencies and slopes: Tweeters - 2000 Hz, 12 db Mids - 400 Hz 12 db, 2000 Hz 12db Woofers - 60 hz 24 db, 400 Hz 12 db Subwoofer - 25 hz 24 db, 60 hz 24 db I still need to play around with these. I will probably move the frequencies around a little bit. Don recommended band passing the sub to prevent any low level noise from damaging the sub. Last edited by snaimpally; 06-17-2014 at 10:08 PM.. |
06-17-2014, 09:52 PM | #7 |
136
Rep 1,192
06-17-2014, 10:01 PM | #8 | |
136
Rep 1,192
The Mobridge can do optical out and the Helix can accept optical in so I may try connecting the two using a TOSlink cable. Both use Burr Brown D/A so not expecting a big difference. The sub is being fired through the ski pass. The specs say this sub shouldn't work well for IB but many have run this sub IB and love it. Chris Pate is a Orca/Focal dealer but he has installed quite a few of the Dynaudio 1200 subs IB for his clients and he thought it was a great idea when I proposed it. Many on DIYMA have also run this IB. Don (6spdcoupe) also installs a lot of Dynaudio 1200 subs in BMWs and recommends IB for this sub. |
06-17-2014, 10:10 PM | #9 |
136
Rep 1,192
Also, in case anyone is interested, I have a new JL Audio 600/6 and new Technic power cables for hooking up the amp to power and ground. Please PM me for details.
06-18-2014, 01:31 AM | #10 |
221
Rep 2,339
Oh. I thought you meant the regular L4SE, not the carbon.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
06-19-2014, 12:58 PM | #11 |
300
Rep 3,969
Looks great man, but why oh why are you not doing those beautiful carbons any justice by crossing them so high at 400Hz? Think more like 150Hz! I've been playing my L3SEs at 160Hz 24dB.
06-19-2014, 03:03 PM | #12 |
221
Rep 2,339
150Hz is the minimum recommended crossover frequency by Hybrid. The carbons are not a wideband driver like the standard SEs. I think he can get it much lower than 400Hz but 150Hz might be kind of pushing it. Looking at the response graph, the resonant frequency is right around 130Hz so maybe something around 200Hz or a little higher might be more appropriate.
06-19-2014, 04:07 PM | #13 | |
300
Rep 3,969
06-19-2014, 04:56 PM | #14 |
221
Rep 2,339
Honestly, I have no experience with any of the Hybrid products but just looking at the FR graph, it looks like you would be approaching the resonant peak on that driver which is usually not a good thing for the overall sound. Real world application could be different though.
06-19-2014, 08:19 PM | #15 | |
136
Rep 1,192
Tweeter - 6000 and up Mid - 500 to 5000 Woofer - 60 to 400 Fs for the L3SE is 113 - I thought the rule of thumb is to cross at around twice the Fs, but perhaps that is why you are using 24 db. I might try crossing the L3SE lower as you suggest. One thing I have learned about car audio is that experimentation is the key - sometimes doing things differently makes a big difference. |
07-14-2014, 11:04 AM | #17 | |
281
Rep 4,121
07-14-2014, 01:44 PM | #18 | |
136
Rep 1,192
http://www.mobridge.com.au/en/produc...analog-pre-amp
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
07-14-2014, 03:23 PM | #19 | |
255
Rep 2,547
The Mobridge can do optical out and the Helix can accept optical in so I may try connecting the two using a TOSlink cable. Both use Burr Brown D/A so not expecting a big difference. |
07-14-2014, 08:51 PM | #20 |
136
Rep 1,192
Yes, that was before I found out that the optical on the Helix was disabled.
