06-16-2014, 12:37 PM | #1 |
11
Rep 368
First tuned M3 - Burger Motorsports hits 480whp
From another forum~
"Hey guys, Was able to get our new 2015 M3 over to the dyno today for a little test and tune action. It has around 100 miles on the clock... Fuel is 91 octane + a can of octane booster to bring octane up to around 93 octane. To start I did a few baseline runs in 4th and 5th gear. The best of which was 427rw in 5th gear. Boost was around 19.5psi peak, timing around 9 degrees up top, and I was fairly disappointed with the output. I'm not sure what might be holding back power but we'll have to dive in to that as we get further in to the R&D process. Not satisfied I decided to whip up a Stage1 alpha tune and after some work had boost up to 24psi and power up to a more respectable ~480rw. Work continues!" |
06-16-2014, 12:42 PM | #2 |
never could compete with Lloyd Braun
5272
Rep 5,378
I feel like I'm back in my e90post days waiting on the jb4 lol Awesome work though that Terry is wasting NO time getting to work.. I'm excited to see the results.
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
06-16-2014, 12:45 PM | #3 |
1253
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
Well damn that was fast, extra 50 ponies never hurt anyone
06-16-2014, 12:51 PM | #5 |
5272
Rep 5,378
That is correct.. I'm guessing this will be like the f1x and be very tough to crack for a complete reflash.
06-16-2014, 12:51 PM | #6 |
11
Rep 368
06-16-2014, 12:51 PM | #7 |
1712
Rep 5,109
I find it strange that he was disappointed with 427RWHP on a engine that is supposed to have 430HP on the flywheel... Was he expecting more RWHP than the stated flywheel HP number???
It's a substantial improvement though. Even though it's a fairly crude "tune" that just manipulates the MAP sensors, tricking the DME and hence more boost is added (even though the DME still thinks it's running stock boost...) |
06-16-2014, 12:52 PM | #8 |
293
Rep 1,512
Drives: Ever changing fleet
And this before E85 blends, or anything. This car is going make well into the 500 whp range with simple bolt-ons and more octane. Awesome
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
06-16-2014, 12:54 PM | #10 |
186
Rep 413
I put a JB+ on my 135i and it brought that car up to where it should have been from the factory. That extra 50 goes a long way
"Most things I worry about never happen anyway"
-Tom Petty |
06-16-2014, 12:54 PM | #11 |
846
Rep 3,249
Yesssss! Sub'd. The only thing is I figured 24psi would have yielded more power. Those torque numbers are looking solid!
'21 /// M5 Comp - Frozen Brilliant White/Black
'18 Porsche GT3 Carrara White/Black/Red - Sold '18 /// M3 - Individual Imola/Black - Sold '15 /// M4 - YMB/SO - Sold '12 E92 ///M3 ZCP - AW/FR - Sold |
06-16-2014, 12:55 PM | #13 | |
11
Rep 368
In terms of the power, he said he was dissapointed not with the power output, but rather the power output at 20psi with 9* ignition advance. On the N54, we are used to seeing much higher numbers than that. Given the S55 was touted as a much better engine, i think he was hoping for a little more efficiency - like hitting those numbers at 15-16psi or with less ignition advance. I suspect a catless exhaust and air intake should help quite a bit. |
06-16-2014, 12:55 PM | #14 | |
293
Rep 1,512
Also, I'm amused that you think piggybacks still work that way. The days of map clamping and map sensor attenuation are LONG gone. Terry developed hardware and software that directly controls the electronic wastegate actuators themselves...no easy feat.
06-16-2014, 12:56 PM | #15 |
119
Rep 922
That looks like flywheel hp unless the stock rwhp is putting out 427 lol. I think someone made a typo?
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package '11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery) |
06-16-2014, 12:57 PM | #16 |
875
Rep 3,450
perhaps someone more knowledgeable about dyno testing can chime in, but I'm quite pleasantly surprised to see the S55 dyno at well over 400 whp (significantly more than the previous dyno we saw). what would a stock e90M have dyno'd at under similar conditions (i.e. dynojet, corrected/uncorrected, etc.)?
06-16-2014, 12:57 PM | #17 |
11
Rep 368
06-16-2014, 12:58 PM | #18 |
636
Rep 3,039
06-16-2014, 01:00 PM | #19 |
119
Rep 922
And it's stock 427 at the wheels? Meanwhile the SportAuto was 465 crank and supposedly showing 380 peak at the wheels? Too much spread don't you guys think?
06-16-2014, 01:05 PM | #22 | |
590
Rep 5,396
To answer some other comments, the e9x typically is between 335-360whp on a dynojet in stock form (not gonna count EAS's "magic" dyno that reads way too high). Also, thrilled with stock power. That said, the tune is impressive but looks like small timing drop / correction right before 3000 RPM. clearly a first pass tune, but that would be unacceptable on my car
