Play in bushes
06-14-2014, 07:01 AM | #1 |
Rep 123
Play in bushes
Hi all,
Just got my Michelin PSS's fitted so decided to pay the aligners a visit. Prior to them even doing anything, they checked the front two wheels and stated that there is play in the bushes hence not worth aligning prior to getting them replaced. They said this is common for E92's. So my question is, is this the case? Even for a 2011 E92 that's only done ~30k miles? If so, i'm assuming this would come under wear and tear and therefore not a warranty item? My local indy quote just over £300 for replacing the front two. I knew it was going to be an expensive Saturday... but not this expensive! |
06-14-2014, 09:23 AM | #4 | ||
Rep 123
You'll have to excuse my ignorance. This includes the lower control arm too. |
06-14-2014, 09:59 AM | #5 |
684
Rep 4,261
My mechanic did mine for £50 , I supplied the bushes.
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
06-14-2014, 10:56 AM | #6 |
11
Rep 208
Your indie has more than likely quote for arms to be replaced which houses the bushes!!
The cheaper fix would be to remove the arms and just replace the bushes which can some times be a nightmare to remove and that's probley why you was quoted 300! |
06-14-2014, 12:40 PM | #7 |
Rep 97
Yea I had same problem Saturday got two new tyres and asked for alignment to be done and had to replace front arms to cost just under £400 with the alignment expensive weekend
06-14-2014, 12:51 PM | #8 |
112
Rep 2,621
Get M3 control arms instead for an upgrade..
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
06-14-2014, 04:36 PM | #9 | ||
Rep 123
How much would these set me back? |
