06-13-2014, 08:12 PM | #1 |
Rep 58
engine start even when stopped in auto start / stop
When i stop at a red light, and wait for it to turn green, the engine "shuts down" and goes into "ready" mode. It stays there for good 15-20 secs.
But after 15-20 seconds, it starts again without me moving anything. I have even tried putting it in P and still it start after some time. Is this normal ? shouldn't it be in "ready" mode till i take my foot of the brake or go in Drive ? Thanks for help ! |
06-13-2014, 08:30 PM | #3 | |
317
Rep 3,619
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
06-14-2014, 12:02 AM | #4 |
175
Rep 766
this. it only stays off it it can and keep you comfortable.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
06-14-2014, 01:24 AM | #5 |
1983
Rep 3,216
The auto startstop looks at what's going on with the car : what's in use (A/C, etc), the current level of charge in the battery, the outside temp even (batteries are less efficient in the cold, this is why ASS doesn't operate below about 3 C/37F). It then decides whether to stop the engine at all, and if it does, it continually keeps monitoring to see whether it is happy with the levels.
06-14-2014, 02:21 AM | #6 |
251
Rep 640
The engine will automatically restart if:
- The Auto Transmission is changed from D to N, R, or M/S - The Auto Transmission is changed from P to N, D, R, or M/S - The car starts rolling - The windows get foggy when the automatic climate control is enabled - It begins getting warm when the A/C is on - If begins getting cold when the heater is on - The Steering Wheel is turned - The battery is heavily discharged - If the brake vacuum pressure is low (if you press the brake pedal multiple times) ALSO, the Auto Start-Stop will not switch off the engine if: - You just switched out of reverse - If your Auto Transmission is in R, N, or M/S - It's too cold outside - If it's hot and the A/C is running - If the cabin is not at the desired temperature set on the climate control - The windows get foggy when the automatic climate control is enabled - The engine is not warmed up enough - If you are in Stop and Go traffic - If Parking Assistant is active - If the Steering Wheel is turned too far or if it's being moved - If the battery is low - If the hood is unlocked/opened - If you are running your car on high ethanol
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP 2010 Audi S5 4.2L [Sold] 2014 BMW 335i xDrive M-Sport [Sold] 2010 Audi A6 3.0T [Sold] |
