E90 Exhaust Hanger
06-12-2014, 08:45 AM | #1 |
125
Rep 654
E90 Exhaust Hanger
This is a pre-LCI 328i E90 exhaust. I have the tips hanging a little lower than it used to when it was new. When I lifted up the pictured rubber hanger, tips seemed to re-align in the back. I was thinking about replacing this (Part #18207590154). But I see the metal studs have a bulged up ends. So this means this cannot be simply inserted? It has to be cut, then re-inserted, then re-welded? My last car, I wrapped a metal strap around the bushing, causing it to be lifted slightly. I wonder if that could work |
03-05-2016, 12:06 PM | #3 |
125
Rep 654
I noticed my tips are hanging lower than before.
Even if u lift up both rubber hangers with hose clamps all the way, I notice that they are still lower than they should be: What else can I try to lift the tips about ¼" ? |
03-05-2016, 02:15 PM | #4 | |
88
Rep 239
If you are really having trouble even with a touch of lube, use a screw driver or small pry bar and stick it through the center hole and twist the rubber hanger a little to walk it off. They should been pretty resilient.
M-Sport, 6MT, PPK, JB4 ISO + Rev.3, VRSF 7'' FMIC, VRSF Catless DP, BMS Charge Pipe, MFactory LSD, Öhlins R&T, M3 Control Arms, Rogue 6MT Bushings, Remus Exhaust, Duke Dynamics CF Diffuser, Cyba Scoops, VMR VB3 19s, BMS Clucth Stop
03-06-2016, 07:00 AM | #5 |
17367
Rep 18,769
OP, sorry, I gotta flame here...
This is seriously the only thing you have to worry about? Like someone else already said. Buy a pair of $10 exhaust hanger pliers and use some WD-40 on the studs. The hanger will slip right off.
03-06-2016, 02:42 PM | #6 |
252
Rep 1,157
Is the hangar support bolted to the chassis? I seem to recall being able to unbolt it. Maybe it has shifted or you can readjust it so it hangs a little higher?
Although I might be mistaken... haven't been under there in a while. I referring to #10&12 |
