Safety for Running Cobb E30 map
06-07-2014, 03:41 PM | #1 |
Vroooomm
23
Rep 352
Hi everyone,
A little overview on my vehicle, I drive N54 with FBO and Cobb Stage 2+FMIC. I used to mix about 3 gallons of E85 with Cali's 91 Octane so I can run the aggressive map. However, when being pushed a little hard, the car sometimes would go into limp mode, engine service light comes on and I get all kind of codes, mostly from improper fuel mixture. Now, the question lol....I just downloaded the E30 map and worried the car won't be able to handle the further stress of this map. Is it safe to run, giving the history of the vehicle and is this map better than me running with the aggressive tune, or should I just go back filling with boring 91 and running the Sport mode thanks all!! |
06-07-2014, 03:48 PM | #2 | |
456
Rep 6,478
if it was a mixture or lambda code, it was likely due to a weak scalar that needs adjustment. So long as you have the octane and the motor is in good condition, the OTS E30 map isn't that aggressive. Load it up, take a few adaptations pulls, log, and post it here.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
06-07-2014, 03:55 PM | #3 | |
Vroooomm
23
Rep 352
When pulling up the codes from the AccessPORT, most of the description was from the improper fuel mixture...How would I adjust the scalar, if that is the issue? I think taking a few pulls and logging it here is the best bet. Also, I think either the spark plugs or the engine coils may need to be replaced. my car has about 65k miles on them and I only replaced one engine coil (by the dealer) haha |
06-07-2014, 04:05 PM | #4 | |
456
Rep 6,478
But if you wish to experiment it's the scalar bank 1 and 2 tables under fuel lookups in ATR. I prefer to set mine a bit strong for additional octane headroom, at the expense of MPG to a certain extent. If you are still on stock coils I would absolutely recommend swapping them out, along with plugs. It's a 30 min DIY job so labor is minimal. The spark components need to be up to snuff to run more aggressive boost and advance.
06-07-2014, 04:54 PM | #5 | |
Vroooomm
23
Rep 352
06-07-2014, 06:13 PM | #6 | |
456
Rep 6,478
To the second part: No. At least in my opinion. I've never heard of or seen evidence of N54s suffering issues due to E85 use. @steveaz I think you would agree? Steve is the resident N54 fuel system genius around these parts. Outside of Munich i'm not sure there are many people on earth who have given more thought and work into understanding the fuel system than Steve.
06-07-2014, 06:43 PM | #7 |
141
Rep 1,423
Drives: '07 N54 e90, '10 N54 e93, TBSS
I do 5 gal of e85. Test the e85 at your normal pump and adjust accordingly. I track tested Dyno, and daily drive that map 92k miles so far.
E90 - H&R Touring - M3 Front Arms - Work Genosis GS-1 19x9+30 x10+26 225f 265r stretch - AA FMIC - AR DP - Cobb E30 Map +160rwhp/+200rwtq
E93 - Style 95 - RB Turbo - AR DP - Evolution RW FMIC - PTF E50 +242rwhp/+234rwtq |
06-07-2014, 07:52 PM | #8 |
60
Rep 654
Holy...how do I live up to an intro like that? Thanks though!
As for the fuel system and E85 Your fuel lines and fittings in the tank are all nylon. The line from the tank to the front of the car is either nylon or PTFE. Both of these are compatible with ethanol and I have included the compatibility info below. The line from under the car up to the LPFP sensor assembly (pictured below) is a rubber line that has an interior coating. I can't say for sure what that coating is but I have yet to hear of any problems with it. When I removed mine, there were no signs of degradation but I never re-installed it do to not liking the interior restrictions in it. The lines from the LPFP sensor to the injectors are all stainless steel hard lines. As for running the E30 map, 135Pats is probably right. Your scalar in your previous map wasn't adjusted to accommodate for the ethanol content. The OTS E30 map will already have those adjusted and you should be fine. But you are right...post logs and there are many on here that are knowledgeable and typically happy to review them.
2008 E88--Fuel-It! Stage 4 LPFP & PI--PS2 turbos--JB4/MHD--FBO--662whp/604wtq
2011 E90--Fuel-It! S2BL LPFP and PI--PS2 Turbo--JB4/MHD--FBO--546whp/589wtq 2013 Mini JCW--Tune--DP--FMIC--a couple Fuel-It! goodies--265whp/320wtq 2013 F10--JB4/BM3 2015 F82--Fuel-It! Stage 3 LPFP & PI--PS2 Turbos-- JB4/BM3-FBO |
06-08-2014, 12:47 AM | #9 | |||
Vroooomm
23
Rep 352
Thanks for your help! Quote:
06-08-2014, 11:15 PM | #11 |
Vroooomm
23
Rep 352
06-09-2014, 08:25 PM | #13 |
Vroooomm
23
Rep 352
06-09-2014, 11:22 PM | #15 |
Vroooomm
23
Rep 352
06-10-2014, 02:00 AM | #16 |
77
Rep 2,114
I haven't had the balls to try the E30 map, but having read all of this info, I might just have to now since the E85 station I use is 5 minutes from my house.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
06-10-2014, 12:24 PM | #17 | |
258
Rep 1,084
06-10-2014, 12:49 PM | #18 |
15
Rep 315
Think of e30 as addes safety margin, do it and you wont ever look back. Just dont go tocrazy with added timing at e30. I run peak 12 degrees under load with zero break up.
06-10-2014, 01:11 PM | #19 |
456
Rep 6,478
Wha? Dude go do that like now.
