Help Amplifying stock Underseat Subs (e93)
06-07-2014, 09:29 AM | #1 |
143
Rep 518
Hey guys, I'm interested in amplifying the stock underseat subs in my e93 with an aftermarket amp. Just a little confused when shopping for an amp --
First - Are the stock underseats set up in 2 ohm or 4 ohm? Also curious what you guys think is the most power (watts rms) I can push to them And last but not least, if any of you have already done this set-up - What Amp would you recommend.... Thanks, and hope this isn't a repetitive topic - But I couldn't find much searching. |
06-07-2014, 09:37 AM | #2 |
69
Rep 994
I don't recommend amping the stock woofers. I recommend replacing them.
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
06-07-2014, 12:15 PM | #3 |
1911
Rep 13,103
FYI
BMW stereo types
http://www.e90post.com/forums/showthread.php?t=352586 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/showthread.php?t=343673 http://www.e90post.com/forums/showthread.php?t=138949 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/showthread.php?t=641323 http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ http://www.e90post.com/forums/attach...1&d=1209780865 http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja http://www.musicarnw.com/page-2/ http://www.e90post.com/forums/attach...4&d=1278871872 Depends on the stereo type. for ohms and size.(base system 6.5 inch and others 8 inch. They will give you some bass with more power but they are muddy. You will want replace them pretty quickly. |
06-07-2014, 04:04 PM | #5 |
1911
Rep 13,103
Well if they were in the audio build thread I wouldn't
Well if they were in the audio build thread I wouldn't.
I guess some of them are but they are spread out. And for the newbys its a wealth of info . If they bother to study it. |
06-07-2014, 05:22 PM | #6 |
2288
Rep 13,001
06-07-2014, 05:24 PM | #7 | |
2288
Rep 13,001
Including your OEM system in your thread will determine the level and detail of help that you will receive...
06-07-2014, 05:53 PM | #8 |
223
Rep 5,120
06-08-2014, 01:13 PM | #9 |
143
Rep 518
I hear you guys. I Only considered amping the underseats because now that ive done what i wanted to thw cars audio i kind of miss the feeling of bass from under the seat vs my trunk sub.
My current setup has a trunk sub with stock power to the underseats. So in theory i wanted to bring that feel or slight thump back from under the seats without adding tooo much additional bass to my 1000rms trunk sub. |
06-08-2014, 09:00 PM | #10 |
Rep 57
If it helps, I have the Hk system in an e92. The under seat woofers are 8 inch 4 ohm. I power them with a 100 w RMS x 2 amp high passed at 63 Hz. Tapped with Technik harness. 60 Hz down goes to the trunk sub.
06-08-2014, 10:11 PM | #11 |
143
Rep 518
06-08-2014, 10:19 PM | #12 |
69
Rep 994
Doubt you'll be happy with that.
06-08-2014, 10:54 PM | #13 |
Rep 57
Depends what you want. With a couple of amps and a sub you can improve the HK system nicely. I am older now so I am not looking for the db's I was 25 years ago, just good sounding tunes. And the HK system limits the upgrading significantly unless you're willing to spend $$$. On my e46 it was a piece of cake: a set of Morels up front, an ID sub, a couple of amps and an audio control matrix and you had superb music. But with the e92 it's not as simple. If $$$ is no object, of course upgrading the under seat subs is ideal, but amping them is not that bad. Turning off Logic, fading full front, adjusting the eq to get rid of the peaks, and balancing for what you are listening to yields very good sound with the amped woofers and a sub.
06-09-2014, 09:30 AM | #14 |
223
Rep 5,120
06-09-2014, 02:11 PM | #15 |
102
Rep 952
A couple stereo iterations ago I had the stock L7 underseats running off an ARC mini amp, didnt push them very hard and used them only for midbass as I have a trunk sub, it worked pretty well.
Eventually went to Jenherts, still only doing midbass, but I of course can push them harder and they sound great. |
