Just bought an N55...need help/advice.
06-06-2014, 01:13 AM | #1 |
Rep 33
Hey guy, I had an N54 for a long time and just got an N55.....don't know much about this engine/car. Can anyone hook me up with the good to know info on it? Does the N55 respond as well to performance mods as N54? Thanks
06-06-2014, 07:30 AM | #3 |
26
Rep 85
Drives: 2016 SO M4
Search search search. There's a million threads
06-06-2014, 07:45 AM | #4 |
154
Rep 3,143
06-06-2014, 07:50 AM | #5 | |
136
Rep 1,192
Drives: 2011 335i MT
http://www.e90post.com/forums/forumdisplay.php?f=204 I have purchased from Mike at N54Tuning.com as he is very responsive. Despite the name, he carries a wide range of N55 mods. Also check Burger Motorsports - N55 JB4, N55 charge pipe, etc. Just exactly how much money do you have to spend? |
06-06-2014, 08:12 AM | #7 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Turbo on the N55 is quite a bit smaller, so that is the limiting factor. Tune is still a huge jump in power (JB4 is the choice right now or AP protune) but after that you won't see as big of gains. Max on stock turbo seems to be 370-380whp. The pure stage 1 turbo has been showing very good gains and will probably get you close to N54 stock turbo levels.
06-06-2014, 08:52 AM | #8 | |
Rep 33
Not sure if there was plus side or neg side to N55 vs N54. Kinda was looking for the answer JETmn gave. Thank you again to everyone! |
06-06-2014, 10:01 AM | #9 |
Rep 175
Drives: 2011 335i 6MT
Basically what JETmn said. Turbo is the limiting factor compared to N54. It is still a great engine imo.
If you are dead set on 400+whp then return it but I don't really understand all the shit-talk against the N55. There is a lot of potential in the platform and the benefits of the new engine outweigh the drawbacks by far in my book. Although I have a track car with a big turbo to satisfy my top end desires |
06-06-2014, 10:58 AM | #10 |
93
Rep 716
Drives: 2015 YMB M3
Although the N54 has more potential (power-wise) at the moment, the N55 is a more reliable engine with newer technology including Valvetronic and a state of the art transmission. The N55 is the current production engine in the 1, 2, 3, 4 & 5 series and has lots of potential. There's already a tested Stage 2 turbo upgrade showing 477whp, a Stage 1 showing great results up top in the rev line, and a couple more coming soon. I'm dying to make more power but i would never trade my N55 for a N54. My .02
2015 BMW M3 | DCT | Yas Marina Blue | Silverstone | Executive | Lightning | Driver Assistant | Carbon Ceramic Brakes Instagram: @benrivasplata |
06-06-2014, 12:50 PM | #11 |
Rep 33
Cool thanks guys! I guess I'll just wait it out for new toys(upgrades) that come out for the N55. I appreciate all the input/info
06-06-2014, 01:04 PM | #12 |
Rep 639
N55 hasnt been out as long as N54 (obviously), thats why there isnt a huge aftermarket following for it. tuners have only recently started playing with the turbos to see what they can do. going FBO with JB4 is about the best you can do right now, without dropping 5K+ on new turbo upgrades. given enough time, ive read that the tuners expect as much HP out of the N55 as the N54. ( im not a tuner, thats just what ive read on here.)
06-06-2014, 01:35 PM | #13 |
Rep 107
The n54 has twin turbos; the n55 has a dual-turbine, single-compressor turbo, which rotates counter to the standard rotation - this is why the turbo is the primary limitation to power potential. it's a hybrid, which is fantastic for general driveability, but it runs out of steam ~6.5k RPMs. the counter-rotation, along with the turbine being integrated into the exhaust manifold, is why it's such a goddamn bitch to upgrade the forced induction. systems exist, they're expensive.
Cobb + ProTuningFreaks is easiest to reach maximum power, unless you're OK with ethanol, then JB4 is your ticket. I'm relatively sure the JB4 does better with ethanol/methanol, and Cobb does better with octane. Cooling isn't as big an issue in the n55 and the n54; you won't NEED an oil cooler, but if you're going FBO, do include it in your FBO specs along with charge pipe, intercooler, intake (or at least drop-in filter), dp, and exhaust. there is a companion exhaust mod for the n55 (straight pipes w/in muffler instead of perforated pipes) - it is fucking jawdroppingly sexy sound w/o a catalytic converter. if you have the 6at, get the Alpina TCU flash; this really isn't even worth discussing. it'll be ~$100 and i'd be fine paying 3-4x that much. makes slush box into zoom box. also, the n55 doesn't have the carbon caking problem or oil getting everywhere inside the engine problem. walnut blasting is every 85k or so, not 50k. catch cans go 15k miles and catch nothing. |
06-06-2014, 04:47 PM | #16 |
Rep 33
06-06-2014, 06:11 PM | #17 | |
BimmerPost Supporting Vendor
24197
Rep 190,805
Its unfair to compare it to the N54 since the N54 is one of these rare cases where you can get couple hundreds Hp without much effort or money. But to answer you question yes the N55 reacts good to modding and increased boost.
06-06-2014, 06:20 PM | #18 |
245
Rep 1,595
Where did you see that? Only the very early 2008's can't do the flash. Other N54's can do it just fine. 6AT N54 and N55 are the same, just a different control module on the early '08's.
06-06-2014, 06:29 PM | #19 |
Rep 171
06-06-2014, 11:25 PM | #21 |
Rep 33
Cool, np... I have a 6sd manual. Hope I can use the clutch I bought for my n54. I'll have to try and call or look it up tomorrow. Thanks for the info guys.
06-09-2014, 09:09 AM | #22 | |
Rep 107
http://www.alpina-automobiles.com/en...e90919293.html |
