More BOOM!
06-06-2014, 12:11 AM | #1 |
146
Rep 1,493
More BOOM!
Hey guys
I recently purchased Tech Harness and added an XD 700/5 amp to power the speakers and sub but I think I'm going to be adding an amp to power the sub alone. How can I add onto the harness? Do I connect amp 1 to amp 2? Or just do it as if I was starting from scratch? Thanks in advance. |
06-06-2014, 05:32 AM | #2 |
255
Rep 2,547
Since you don't have pre-outs on the xd700/5 you can connect the front rca's from the Technic harness to a set of y connection rca's and run to both the xd700 and the new sub amp.
06-06-2014, 06:05 AM | #3 |
300
Rep 3,969
You could also make sure that the second amp you buy has RCA pre-outs, then simply run another set of RCAs from the new amp to the XD700 sub input.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
06-06-2014, 01:36 PM | #4 | ||
146
Rep 1,493
Now I got it. Thank you fellas. Quick question I would need to put a new battery connector right? |
06-06-2014, 02:23 PM | #5 |
255
Rep 2,547
If you have already run 4ga or larger powerline to your first amp you could just add a distribution block at the amp location.
06-06-2014, 04:01 PM | #6 |
300
Rep 3,969
You can use 8-gauge up to 1000 total watts RMS (even a little more if necessary), as long as the run is no longer than 5 or 6 feet. I hate how thick 4 gauge is, and it does not tuck easily under the floor panel. I had no voltage drops whatsoever with 8 gauge on both amps (900W and 600W).
06-06-2014, 08:01 PM | #7 |
223
Rep 5,120
I wouldn't use 8 gauge for 1000 watts regardless of how short the run is. I have 4 gauge to my xd600/6 and 0 gauge to my sub amp. I ran my 4 gauge wire through the rear deck instead of under the trunk panels.
