Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Will a n55 PE for xdrive fit on a n54 rwd? UPDATED: INSTALLED + VIDEO
      06-05-2014, 11:29 AM   #1
nsx_modified
Drives: 2008 335i
Sorry for repost, posted in wrong section originally.
Hi all,
I'm tried searching for sometime but I couldn't get a solid answer.
I've come across a good deal on a PE. The seller has a 2011 e90 335xi, and I have an 2008 e90 335i rwd.
Will this exhaust fit my car, or will I need to make any modifications to my exhaust. It seems from the pics that the mufflers and the xpipe for the n55 is included.
Also is there a difference from him having the x drive and me being rwd?
Thanks in advance.
      06-05-2014, 11:35 AM   #2
turbs
Drives: 335 M Sport
Looks exactly the same as the exhaust on my car. Although mine is a stock exhaust. Its the same set up as pe etc.
      06-05-2014, 06:49 PM   #3
PNWN54
MR. Rocket
PNWN54's Avatar
46
Drives: 2010 E92 335i M-Sport
Hi all,
Thanks in advance.
Is he selling you the x pipe and mufflers only?
I have n55 mufflers with ebays $35 x-pipe. Took it to a very nice muffler shop to weld the rest of the piping and it worked like a charm.
      06-05-2014, 06:50 PM   #4
nsx_modified
Drives: 2008 335i
He's selling me whatever is in that pic
So I guess it's the mufflers and and the xpipe.
It will work with clamps as well instead of welding?
      06-05-2014, 06:58 PM   #5
PNWN54
MR. Rocket
PNWN54's Avatar
46
Yep, camps or welding will work.
Clamps are recommended so that you can easily swap exhausts with just camps vs cutting and welding. But, if welding, make sure you get a good shop to do the work so there's no leaks.
      06-05-2014, 07:00 PM   #6
nsx_modified
Drives: 2008 335i
So just to be clear that exhaust from a n55 will be good on my n54?
I can either: 1) install just the mufflers or 2) cut & replace the n54 resonator with the n55 xpipe together with the mufflers?
      06-05-2014, 07:32 PM   #7
PNWN54
MR. Rocket
PNWN54's Avatar
46
http://www.e90post.com/forums/showthread.php?t=889129
Here's a thread to help you see the difference between all types of PE setups.
You definitely need to replace that resonator with an x-pipe! Step 2 is what you want to do.
      06-05-2014, 07:51 PM   #8
nsx_modified
Drives: 2008 335i
Thanks for your help. I really appreciate it. 😃
      06-05-2014, 07:55 PM   #9
PNWN54
MR. Rocket
PNWN54's Avatar
46
No problem. Post up the result and let us see what it sounds like after it's done!
      06-24-2014, 12:58 PM   #10
nsx_modified
Drives: 2008 335i
So i've finally had some time to make a couple vids.
Install wasn't too bad, I just did it myself.
I previously got rear ended, and when insurance fixed my right muffler, they just cut it off and replaced it. So when I was installing my mufflers I only had to cut the left side, since other side was cut already.
In both videos I've already had the AR Design catless downpipes and a DCI.
The first video will be with just the Performance Mufflers
The 2nd video is the xpipe that came with it (instead of stock, which comes with a resonator in the sedans) as well as the performance mufflers.
I'll try to get some more videos while I'm driving (sounds really mean when driving and when I shift theres a LOUD 'snap' 'bam' sound. LOTS OF GURGLING!!!!
[u2b]
[/u2b]
[u2b]
[/u2b]
ENJOY!!!
