Help! what noise is this
06-04-2014, 12:10 PM | #1 |
Mike: Everyone's Pal
2044
Rep 2,972
Drives: F80 M3
Okay so it started last night.
My car: 2010 328xi 37xxx miles 17 seconds I put it into drive the noise happens 31 it stops when I start inching forward then starts again at 47 seconds the sound stops at highway speeds, just when I start the car I did just get my secondary cats out... exhaust rattle? Seems like it happens sometimes when I put the car into gear...sometimes when braking at very low speeds... no codes are thrown
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
06-04-2014, 04:05 PM | #2 |
2044
Rep 2,972
Drives: F80 M3
anyone? any ideas?
06-04-2014, 04:12 PM | #3 |
91
Rep 611
kinda hard to tell, but i think its gotta be exhaust related, maybe loose brack.
driveshaft dont rotate when u in P, so maybe its touching something.
N51- PI - PE - ESS Tuned - SSK - CDV Delete - AFE Header - B12 - Mfactory LSD
06-04-2014, 04:21 PM | #4 |
2044
Rep 2,972
Drives: F80 M3
its so weird...whenever I put the car from park to drive or park to reverse from a cold start, it happens...it rattles like crazy for like 5-10 seconds, then i drive a little and it stops, until next time I stop the car, turn it off...let it sit for a bit then turn it on.
06-04-2014, 07:20 PM | #5 |
200
Rep 1,834
Drives: '05 E90 330i Manual
I would have the exhaust brackets checked. When going to Drive or Reverse the engine is under some load, so it changes the engine idle speed probably to the point that this vibration is taking place.
06-04-2014, 07:30 PM | #7 |
2044
Rep 2,972
Drives: F80 M3
thanks guys... makes me feel so much better. I searched for it and it was like going to web md to look up what had the symptoms of a cough haha
I suspected it was an easy fix since it was right after I got my cats out..something prob just came loose
06-05-2014, 09:24 AM | #8 |
200
Rep 1,834
Hope this is what we suspect, and should be an easy fix!
