Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Seized Track Rod/Tie End?
      06-03-2014, 02:30 PM   #1
Dragon88
Dragon88's Avatar
Drives: BMW E92 320i M-Sport
Went to get my wheel alignment done earlier and was told the front near side toe couldn't be adjusted as the track rod / tie rod end was seized - got a replacement part on order awaiting fitment in the weekend. Is this a common problem?
Mine is a 57 plate so almost 7 years old.
BMW E92 320i M-Sport - Titanium Silver - Red Leather
      06-03-2014, 02:34 PM   #2
Mr Rauf
16
Drives: 320d
Hi mate
I had the exact same problem last week. Just havent had time to get the tracking rod replaced. The guys were saying its a common problem with bmw.
How much did the part cost you and how much for labour?
cheers
      06-03-2014, 02:40 PM   #3
wallsmk2
28
Drives: e91 325i
very common as the thread is exposed
      06-03-2014, 02:42 PM   #4
Dragon88
Dragon88's Avatar
^I was quoted £95 inc fitting and VAT.
Going to pop back in on Saturday for fitting and realignment check, hopefully should solve my 11 o'clock steering position.
      06-03-2014, 02:49 PM   #5
Mr Rauf
16
Drives: 320d
I need to sorr out my 11 o clock problem too, just being lazy with it
How much did the rod cost and where did you order it from?
      06-03-2014, 04:19 PM   #6
sohail330
Drives: BMW 330i E92 272ps
I have the exact same problem.
Went to get my wheel alignment done.
They checked the rear wheels and said they are spot on and don't need adjusting.
The fronts were out but they couldnt adjust as it was seized and said to get the track rod end changed.
The part itself can be had for about £20 afaik. Just need to find out the labour cost to change it but cant imagine is being more then £30 or so as it shouldnt take long..
      06-03-2014, 04:40 PM   #7
danb21t
Drives: Le Mans 335d M Sport
£20 will likely be for the rod end only. Most places will replace the rod and rod end. I had lots of fun freeing up the rod ends on mine a month ago.
      06-03-2014, 04:58 PM   #8
Digitalize
Photographer
Digitalize's Avatar
412
Drives: 320D
Track Rod with Track Rod End is about £40 cost price.
      06-03-2014, 05:17 PM   #9
sohail330
Oh right, I just assumed that
http://www.eurocarparts.com/ecp/c/BM...8716170&000349
is all that was needed..
any one got a link to where I could buy the track rod with the end then?
      06-03-2014, 05:36 PM   #10
Jase 320d
Wheelbarrow Edition
Jase 320d's Avatar
Scotland
60
Drives: Arctic 320d
Same place just looked ECP do the track rod and end for £45
      06-03-2014, 05:51 PM   #11
Jules59
Jules59's Avatar
56
Drives: Still searching ...
Didnt they try a little heat from a blow torch to expand the sleeve and break the adhesion? Did on my 330D.
Jules
      06-03-2014, 06:21 PM   #12
M power king
Drives: 330i pre lci M sport
This is the complete one for £45 (Lemforder)
http://www.eurocarparts.com/ecp/c/BM...e50c368&000584
£28 (Ocap)
http://www.eurocarparts.com/ecp/c/BM...404091b&000584
The cheaper one will do tbh..Have your pick
      12-18-2019, 10:18 PM   #13
d.parmarBMW
Drives: BMW 320d e90
Mine has just gone as well, can only do the aliment once changing rod ends.
£20 each for parts and £50 labour.
All down to a bad design letting dirt get in between the threads.
      12-19-2019, 06:29 AM   #14
Andystobbs
191
Drives: E91 Lci, Vectra B V6
Not very ambitious of these alignment centres. Get the hot spanner out and sort it out. Its not as if you can replace the track rod end without removing the old one anyway so either way its getting removed.
