Sirus Retrofit to Built in CIC radio - where to pull sat attenea cable from?
06-01-2014, 03:25 PM | #1 |
108
Rep 1,042
So upgrading to a newer 2011 CIC unit w built in Sirus. While my (2008) is prepped to sat, i believe the attenea cable is in the trunk... i assume i need to plug that into the back of the new CIC unit that has SirrusXM built in?
How should I go about this?
06-01-2014, 06:33 PM | #2 |
2288
Rep 13,001
Run antenna cable extension from trunk prep to back of CIC; there are 10' and 20' Sat radio antenna extension cables available. You will need Fakra adapters at both ends.
06-02-2014, 02:33 AM | #3 | |
108
Rep 1,042
Also - sorry have another question.. when going to the '11 radio how does BT phone and USB audio work? Will this still work w my MULF2 setup or will i risk losing these w/o a combox added?
