05-29-2014, 05:45 PM | #1 |
Rep 99
Help. stability control light problem
Hi, I haven't been on the forum in ages.
I have just replaced my 19 inch back tyres 255/35/19 Bridgestone run flats. I put on good year eagle f1 none run flats because of good online reviews and price. After 300 miles and trying then on the bends. Not crazy. My stability control light is flashing very easy. Even if I don't have the throttle pressed and the car is nice and balanced going around a corner it will start to flash. Do use think it's tyre related or possible electrical problem? Any know problems like this with f30? I took alloys off the check hubs and bolts every thing seemed good. |
05-29-2014, 06:36 PM | #2 |
127
Rep 976
The traction control compares speeds of all wheels to each other at a set ratio for the standard tyre setup. If you have changed only two tyres to a different type, I would bet it's is what's causing the issue.
05-29-2014, 06:48 PM | #3 | |
Rep 99
I have the same good years ordered for the front to change as well. But was thinking of canceling them if this was a tyre issue. So you think get the fronts changed and should be happy family's again? |
05-29-2014, 07:06 PM | #4 |
10998
Rep 32,881
I find this very unlikely tbh! As long as tyres on the same axle are the same then there should be no problems!
05-30-2014, 12:42 AM | #5 |
851
Rep 1,860
I guess it could be the slippy tyre mould releasant still on the tyres?
I put a set of new tyres on my last car and the TC was forever triggering, even in 6 the gear on a straight Mway in the dry for >the first 400 or so miles till it wore off |
05-30-2014, 02:40 AM | #6 | |
6659
Rep 15,858
Even mixing tyre types (all non run-flats) front to rear has given this issue over the years. E46 330ci was very sensitive to tyre matching. Even users mixing Michelin PS1 and PS2 could have issues. I remember one case where both BMW and Michelin got involved as new tyres messed the TC. With over 300 miles on the new tyres they should be well scrubbed, other than pressure being totally wrong, I do suspect the mixing of RFTs with the softer F1 non run-flat. Could be completely different with say a Pirelli, but even so, it is not recommended to mix RFTs with non run-flats. What is experienced is one of the very reason mixing of tyres is not recommended. HighlandPete |
05-30-2014, 02:50 AM | #7 |
6734
Rep 20,651
Obviously technology has changed but a mate with a cavalier 4x4 had weird fault, car would jerk during driving.
This was finally out down to brand new on front and half used on rear, sufficient difference to trigger a fault. He had to fit new on rear. |
05-30-2014, 02:59 AM | #8 |
18
Rep 147
I am having some GY Eagle F1 Asymmetric runflats fitted to the rear this morning.
I've read on a forum that they are very slippery for the first 500 or so miles until the residues wear off. Give them time to settle and you should be okay. |
05-30-2014, 03:03 AM | #9 | |
10998
Rep 32,881
Anyway we're talking about a rwd car so i don't see how tyres on the undriven wheels can affect the traction on the driven wheels! Lateral grip and/or oversteer/understeer bias maybe, but traction no. I would think they are just less grippy tyres in certain condition/temperatures. |
05-30-2014, 03:15 AM | #10 | |
6659
Rep 15,858
As I say, this type of issue is well documented for BMW models, so no surprises if it is the tyre mix issue. HighlandPete |
05-30-2014, 03:39 AM | #11 |
166
Rep 415
I don't understand why you would have TC related to the undriven wheels at the front when there is no power to cut? Stability/break control yes but no traction. I love the Goodyear Eagle F1 (GSd3 and asymmetric) and have always fitted them to my cars however there was an issue once with the GSD3s and a poor quality rubber batch from Asia, tyre dealers changed them FOC to the German stamped rubbers.
05-30-2014, 04:10 AM | #12 | |
6734
Rep 20,651
True and same reason I avoided them. As Pete said it may be tyres, they do take a hundred or so to bed in. However, being a E91 driver (until 10 June) I am soo used to flashing lights lol. |
05-30-2014, 04:25 AM | #13 |
875
Rep 2,060
My cars an x drive so when it comes time to change the rears will I also need to change the fronts even though they will likely still have decent tread left?
05-30-2014, 05:05 AM | #14 | |
4275
Rep 6,953
On a previous xdrive (X5) I always changed fronts or rears together over many years of ownership, and that worked fine. |
05-30-2014, 06:49 AM | #16 | |
6659
Rep 15,858
BTW, I loved the Eagle F1 GS-D3, tried them on my E91, suited my driving conditions, particularly as they were excellent in the wet. They didn't get the name "The Wet Meister" for nothing. It was a shame some unapproved Asian tyres (different compounds) got to the UK, to a degree, tarnished the GS-D3's reputation. HighlandPete |
05-30-2014, 06:56 AM | #17 |
6659
Rep 15,858
I'd still be cautious of what tyres you fit, if not using the same brand and specification as on the car. We are still on a learning curve for the xDrive in the cars. X3 users (and tyre shops) have learned hard lessons in the X3 changing to other tyre options, particularly with staggered setups.
There is obviously more experience with xDrive in other markets for saloons and tourings. Tyre sizes are more the norm, (X3 was a bit different) so hopefully we won't be reading of issues. HighlandPete |
05-30-2014, 07:44 AM | #18 | |
4275
Rep 6,953
Did the X3 issue arise when using different tyre types on the front and rear? Even though I changed them in pairs, on my X5 I always had a full set of the same tyres on both my summer (OEM staggered 20" Michelin) and winter (non-staggered 17" Conti) sets. JD6 Last edited by JD6; 05-30-2014 at 07:50 AM.. |
05-30-2014, 08:07 AM | #19 | |
875
Rep 2,060
Tyres still have decent wear as my mileage is fairly low so it's not likely to be an issue for s while. I did notice that the car has different tyres on the front than on the rear which I'd not really seen before but think this is the staggered set up that I have seen many people referring to. Not entirely sure of what the benefits or reasons for this are (I'm no engineer unfortunately ) but I did plan to buy identical tyres to what the car came with when it comes time to replace whereas in the past I have to say I've mixed and matched. Thanks for your continued useful advice. |
05-30-2014, 08:47 AM | #20 | |
6659
Rep 15,858
The biggest issue appears to be with the M-sport staggered setups, where if you deviate from running all four tyres as 'star' marked approved tyres you can expect drivetrain issues. My son runs an E83 X3 and he had trouble sourcing a couple of rear tyres. Our local National tyre shop couldn't get any as they were on back order, had an optional pair (in the correct size) on the shelf, but the guy would not fit them on an X3, even if my son had wanted them, too many issues from his own experience. My son sourced the OEM Pirelli P-Zero from BMW Direct, the only supply at the time in the whole country, National fitted them for him. HighlandPete |
05-30-2014, 09:00 AM | #21 | |
6659
Rep 15,858
Benefits are debateable, wider rears do help make the car safer on the limits, as the car will tend to understeer. I had a square and staggered set for my E91, personally preferred the square setup, handling was more neutral, gave a finer balance to the chassis. Wider tyres can give more grip, in some conditions, but in the wet can be a worse combination than a square setup. Opinion will vary, but wide rears can be an overkill for normal driving. Sporty looks often win out, even if it doesn't always mean better performance in all key areas. HighlandPete |
05-30-2014, 10:07 AM | #22 | |
127
Rep 976
