brake pads rubbing?
05-27-2014, 01:44 PM | #1 |
14
Rep 208
brake pads rubbing?
hi guys i had done my brake pads and rotors 2013 august and today i have 24K KM on the car since then. I need to change my pads again.
i do about 80% city and 20% highway. I do not brake last minute or speed and then brake around town. typical normal driving. Now i know there are so many factors in driving but does 24K for pads and rotors seem even someone conceivable? or are my pads rubbing? the rotors are really hot when i touch them after driving. I do here a slight howling noise(but it might be my tires) If they are rubbing.. what could be the cause? caliper?
2008 E90 328 X-drive -KW V1- Auto-Sport-Blacklines-LED interior lighting
Summer: Style 195 F-225/40/18 R-255/35/18 on Bridgestone RE760 Sport Winter: Style 161 - Sottozero RFT 225/45/17 square |
05-28-2014, 10:24 AM | #2 |
14
Rep 208
BUMP?
05-29-2014, 04:05 AM | #3 |
1007
Rep 2,109
05-29-2014, 12:56 PM | #4 |
Where'd my VTEC go?
481
Rep 6,067
Rotors are supposed to be hot after using the brakes. What brand of pads did you go with?
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
06-03-2014, 10:32 AM | #6 |
14
Rep 208
im using original BMW parts from dealer. the light went off. I keep resetting it and its good for 1-2 weeks then comes on again. I'm going to inspect the brake pads tonight. I am also getting a squeaking noise from the brakes at slow speeds while turning in my underground parking.
06-04-2014, 06:08 AM | #7 |
84
Rep 1,623
Drives: Alpine White 128i Cabrio
Did you replace the sensors when you changed pads or just use the same ones?
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
06-05-2014, 12:42 PM | #8 |
14
Rep 208
changed the sensor.. i just checked my pads. they seem to have about 6-7mm left(almost double of the backing plate. so i assume its the sensor. the rotors didnt show any signs of irregular wear. must be the sensor.
