Dyno Question
05-22-2014, 10:24 PM | #1 |
Rep 33
Dyno Question
Hey all,
I'm wondering if you all would recommend a Dyno on my current set up. This is what I have: JB4 Dual Cone Intakes AR Design Downpipes (as of next week) I'm planning on running Map 2 on the JB4. Would you all Dyno or would you just run Map 2 on the JB4 no problems as Map 2 specifications are downpipes + 94 gas. Thanks! |
05-22-2014, 10:27 PM | #2 | |
BimmerPost Supporting Vendor
24298
Rep 190,989
If you want to dyno your car to see the power difference there is no harm in doing so. If you are asking about map 2, yes you can run map 2 with intake and DP installed.
05-23-2014, 12:50 AM | #3 |
VIP
52
Rep 747
Drives: AW E92 335is
get the back end flash for e85 and run map 5 with 7gal of e85
05-23-2014, 11:02 AM | #4 | |
Rep 33
The reason I ask is because my friend told me I'll NEED to get my car re-tuned and can't just run the DPs with DCI and Map 2 as it'll cause issues and unnecessary engine wear. Thanks, |
05-23-2014, 11:11 AM | #5 | |
24298
Rep 190,989
Each jb4 map is already optimized for different mods, so all you need to do is select the appropriate map and do a few pulls so the car gets adjusted. |
05-23-2014, 11:23 AM | #6 | |
100
Rep 1,040
This may be the case with other cars, I don't really know. However, the JB4 has maps optimized for certain modifications. I believe Map 1 is for just the JB4, Map 2 is for JB4, intake, and some people say downpipes, Map 3 is for Meth, Map 5 is auto tune and what most people run if they're planning on using E85 or are FBO, but this can be used with any mods as it automatically tunes based on octane and modifications. Map 7 is for race gas, etc. Map 2 or 5 are what you would be running with DCI and Downpipes, no additional tuning necessary as that is exactly what those maps are for.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
05-23-2014, 02:16 PM | #7 |
Rep 33
So sounds like what everyone is saying is I don't need to professionally tune - just switch on Map 2 and I'll be good to go after a little adjustment period for the car to get used to the new tune.
05-23-2014, 02:27 PM | #8 | |
39
Rep 315
You will be perfectly fine simply running Map 2 or 5.
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings |
