05-16-2014, 01:00 PM | #2 |
8571
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Not true kickdown as in pressing accelerator to the floor to get maximum drop in gears.. not sure why but I always just find it a touch uncouth and just not how I like to drive.. hard to explain!
Intelligent kick down where the gearbox senses that you want to get a move on based on your throttle opening and choice of driving mode is sufficient for me most of the time, or if I'm enjoying a proper blast then it's always the paddles.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
05-16-2014, 01:00 PM | #3 |
155
Rep 1,224
All the time, whenever I want to floor it, foot all the way down (activates kick down).
Very rarely i use the shift down with the paddles, as they're set to go down one gear at a time, where as kick down is automatic, could bring you down 2 gears at a time |
05-16-2014, 01:26 PM | #5 |
M Performance
672
Rep 755
I hardly use the full kick down, as per Tengocity a blip of the throttle shows the car you are wanting more power.
The M DCT box has some short cuts like flooring it then down shifting with the paddles jumps you into the gear that will give you the rev's for peak torque (e.g. 7th to 4th). Not tried this on the Auto 8 speed box wouldn't surprise me if it did similar... does anyone know? Mat
F90 M5 Frozen Dark Silver Ultimate
G80 X Riviera Blue w/ Kyalami Carbon Ultimate G05 30d Mineral White Instagram - @matfireworks |
05-16-2014, 02:38 PM | #6 |
371
Rep 1,216
Use kickdown all the time, every journey probably. Unless my mum's in the car!
Nearly done 12,000 miles and apart from checking the paddles work just after I got it, haven't touched them since.
M3 Azurite Black now instead of the 335d. Roughly the same really.
05-16-2014, 02:40 PM | #7 | |
6659
Rep 15,858
I'd not normally use kick-down, like yourself and Tengocity, a bit of nifty throttle action gets the changes you need. No aversion to using kick-down when wanting maximum response in any auto I've owned. I'd normally flick the stick to M/S for a fast overtake anyway, whether intending to kick-down or not, to break from driver adaption and into the full cream sport program. I know my car has dropped from 7th to 2nd in one block change, pretty aggressive and uses the full revs of the petrol engine. It's at those times you know rear grip can be near the limits. HighlandPete |
05-16-2014, 04:38 PM | #9 | |
M Performance
672
Rep 755
I have heard stories of M5 drivers having trouble with the 7th to 2nd change. The car holds 7th as long as possible, slowing down whilst coming to a roundabout, clear and foot down to go... car then changes to 2nd and near 600bhp is now in peak torque. My F31 is definately programmed differently although to the shock of many I drive it almost always in ecopro mode. I shall have to do more playing in sport mode. Love the auto and dct BMW are producing... I am very much one of those who has no interest in manual anymore. Mat |
05-16-2014, 05:04 PM | #10 | |
6659
Rep 15,858
I assume you've used the shifter, moved across to M/S, that action will change down 1 or 2 gears according to speed/rpm. HighlandPete |
05-17-2014, 03:20 AM | #11 |
357
Rep 1,349
I do like Kickdown and have used it quite often but in day to day driving for overtaking etc I normally notch the down paddle a couple of gear and press harder on the throttle... does the job for me.
I do like the paddle shift but other than the odd ad hoc gear up or down, I dont use it much. |
05-17-2014, 03:57 AM | #13 | |
6734
Rep 20,651
Pulled out to over take on A9, then nothing, pulled straight back in with red face lol. |
05-17-2014, 04:29 AM | #14 |
Rep 44
I've used kickdown a couple of times to try it out - including when overtaking. I find it a bit unrefined as a 330d really doesn't need that many rpm to be able to accelerate well and, being a diesel, sounds a bit harsh. Scares the wife! I expect it's more useful and pleasant in a petrol.
It's useful to know it's there though, for example if the driver of the car you're overtaking is a d**k and decides to accelerate. |
05-17-2014, 05:49 AM | #17 |
1050
Rep 3,154
I do miss that sounds of the straight six, especially in tunnels. Also just blipping the throttle made a lovely sound. Oh well c'est la vie - maybe next time
335d is better sounding that I thought, its very nice one pushing on and warm, but its just not the same as the petrol beauty. Have used kickdown pretty much straight away, amazing the amount of very expensive metal one can show a clean pair of heals to. |
05-17-2014, 06:45 AM | #18 | |
6659
Rep 15,858
My experience, shifter across to M/S and kick-down is the most rapid and brutal way to get the gearbox into the optimum gear for maximum revs, ideal for the petrol engines. M/S shifter position and full throttle is less savage in the 535i, (my normal approach to fast overtakes) but still wakes up the gearbox and is pretty rapid. M/S and kick-down will have you in the upper rev range virtually instantly. Some diesel users don't like that at all, particularly from lower speeds, as it means you can be past the best torque/power range. In a petrol, watch out if you touch the paddles, as you could soon be sitting on the rev limiter and it's waiting for you to change up. HighlandPete |
05-18-2014, 06:20 AM | #20 | |
6734
Rep 20,651
Any car can over take another car, obviously at 150 there is less range available. Confused what you want from your question. If one car is travelling at 70 and another car accelerates it, it will over take it. |
05-18-2014, 09:00 AM | #21 |
3533
Rep 11,292
I used kick down last night to overtake my mate in his Jag XF 3.0 V6 diesel as we were coming onto the A34. Left him standing.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
