BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Off-Topic Discussions > Hunter Wheel Alignment
      05-12-2014, 04:25 AM   #1
RCUK
RCUK's Avatar
100
Drives: 911 Turbo
Thought id get some advice,
Just changed the bushes and front/rear control arms (and rear suspension) and been told i need to have my alignment done again.
From what i can see can either get normal alignment done, or do the Hunter laser alignment.
2 questions - is one better than the other, and how much should i be looking to pay?
Thanks!
Been there, done that, driven the 'Ring
      05-12-2014, 04:34 AM   #2
Mr Rauf
16
Drives: 320d
Average going rate is about £60 for 4 wheel alignment with hunter machine.
      05-12-2014, 04:36 AM   #3
Sparky68
Sparky68's Avatar
694
Drives: 2016 M2 Alpine White
2016 BMW M2  [0.50]
2017 BMW F30 330D  [0.00]
2014 M135  [0.00]
2007 BMW 335i  [0.00]
I find that it depends on how many adjustments are needed.
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
      05-12-2014, 04:42 AM   #4
RCUK
RCUK's Avatar
100
Drives: 911 Turbo
Found these guys fairly local and they saying £75.
http://wheelpoweralignment.co.uk/
      05-12-2014, 06:06 AM   #5
Mr Rauf
16
Drives: 320d
What is the most you have ever paid?
      05-12-2014, 06:30 AM   #6
Sparky68
Sparky68's Avatar
694
2016 BMW M2  [0.50]
2014 M135  [0.00]
£85 at JPS Motorsport
      05-12-2014, 09:22 AM   #7
Russbmw
Russbmw's Avatar
Australia
680
Drives: 2018 630iGT sport
Yes - A 4 wheel alignment is a necessity on a BMW, or most cars to be honest. If the alignment is out, the car does handle noticeably weirdly! Not to mention odd tyre wear and sometimes even odd tyre noises.
A regular tracking basically checks that both front wheels are pointing the same direction (ie: toe in/out adjustments).
If you've only just had the bushes changed, leave it a week or so to let things settle before you have the alignment done
A 4 wheel alignment checks all 4 wheels are aligned, that everything points the right way when the steering wheel is centred. The camber, toe and castor are checked (no castor on the rear, obviously) - and if done properly this is done with some weights added to the car....or a couple of guys sat in it at the time!
National Tyre centres tend to have Hunter machines - I know my local one does. I think the last time I had it done a few months back the checking was £45, and then adjustments charged on top of that. Pretty sure it didn't work out to any more than £60 or so with all adjustments done.
It used to be more expensive because it was considered something only enthusiasts and people who were anally retentive about their cars did (and BMW would charge stupid money for doing it), but it's a lot more common these days so isn't as pricey.
      05-12-2014, 09:42 AM   #8
Burned
Drives: E92 330D M Sport
Watch out for which alignment mapping they're using. Someone tried to put the M3 adjustments on my M-Sport because they didnt know what they were doing.
      05-16-2014, 03:25 AM   #9
gaza01
gaza01's Avatar
105
Drives: E92 335i
Originally Posted by RCUK
Found these guys fairly local and they saying 75.
These are the guys i usually use. Great service and Mark the owner is really nice.
      05-16-2014, 09:22 AM   #10
Mr Rauf
16
Drives: 320d
Can anyone recommend me any good places in essex / east london area for hunter alignment
cheers
      05-17-2014, 08:52 AM   #11
RCUK
RCUK's Avatar
100
Drives: 911 Turbo
Had it done there today - all of it was out!
They could do everything but camber at the front they couldn't do - something about needing to move a pin or whatever - didn't really understand.
Rest of it was all green tho - and they took a good while doing it as well.
      05-17-2014, 09:08 AM   #12
Mr Rauf
16
Drives: 320d
Was it something with the track rod being seized? (Problem I had yesterday during alignment)
How much did they charge?
      05-19-2014, 09:40 AM   #13
RCUK
RCUK's Avatar
100
Drives: 911 Turbo
They charged a flat £75 ... and was a good hour my car was on the ramp.
Not sure it made a huge diff to the car, but they def did a lot of adjustments on the car, so all in i would recommend them.
      05-20-2014, 07:57 AM   #14
MaccyD
Drives: E92 335D
Yeah the camber at the front is fixed by a pin (can be removed with difficulty), probably to do with easier setup and installation on the production line.
Anyone else had trouble with the front toe pinch bolts? Mine is siezed on there!
Does eveyone just get factory settings put in? Im being charged more as im having it done to my own setup.
      05-21-2014, 10:51 AM   #15
achu
103
Drives: E93 335i
just had mine done for £75 at southall tyres and exhausts
i asked them to max the rear camber (got it from -1 to -2.5) without the toe going outta line... and fix the front toe and steering alignment...
PAST: 2007 E93 335i 6MT
NOW: 2012 F10 M5
Facebook: Achu Ckr|Twitter: AchuCkr|Instagram: AchuCKR|Flickr: AchuCKR|G+: achu.ckr
THE BUILD THREAD|COMPILATION OF PHOTOS
      05-22-2014, 03:08 PM   #16
Ajerthan
Bimmaaaa
Ajerthan's Avatar
23
Drives: E46 M3
2004 BMW M3  [0.00]
2009 BMW 325  [0.00]
Are they good? I was thinking of taking mine there too! Do they change spring there? Need some1 to fit my springs!
InstaGram: Ajerthan
      05-22-2014, 03:11 PM   #17
achu
103
Drives: E93 335i
yeah pretty good, but quite expensive i think... theres a guy next to ace cafe... he's pretty good but his ramp is out of order atm...
NOW: 2012 F10 M5
      05-22-2014, 03:40 PM   #18
AzRiz
AzRiz's Avatar
130
Drives: E92 M3 LE500
PM me for custom Hunter alignment in Surrey for less than any of the costs listed in this thread.
Done by knowledgable car enthusiasts like ourselves.
A few members have already had it done there through me (Sumil, Josh, Shaun) as well as myself of course.
Tyre supply/fit also.
Nothing in it for me - just trying to help people get their cars how they want them without spending a fortune to get mediocre 'mechanics' to do it.
      05-22-2014, 04:30 PM   #19
Ajerthan
Bimmaaaa
Ajerthan's Avatar
23
Drives: E46 M3
2004 BMW M3  [0.00]
2009 BMW 325  [0.00]
inbox me details plz
InstaGram: Ajerthan
      05-22-2014, 05:28 PM   #20
Mr Rauf
16
Drives: 320d
Pm me details too.. thnx
      05-27-2014, 03:49 AM   #21
Russbmw
Russbmw's Avatar
Australia
680
Same here please.
The only other place I'm, aware of that is reasonably priced is Hounslow Tyres.
