ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      05-04-2014, 02:41 PM   #1
Tonymiabmw
Tonymiabmw's Avatar
552
Drives: Nardo F90 M5 on order
Thumbs up Liquid-to-Air instead of Air-to-Air
It's a air to water cooling system, heat soak plays a big part in these kind of intercooler systems.
      05-04-2014, 02:51 PM   #2
ASAP
ASAP's Avatar
10137
Drives: '23 X3 M40i
It is beyond me why they chose liquid to air for a street car. Same thing w the M5 but once that water boils, your performance is done. A well sized air to air would have been a better option IMHO.
Although 96F is still extremely hot.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
      05-04-2014, 03:23 PM   #3
Tonymiabmw
Tonymiabmw's Avatar
552
Hopefully someone makes a larger heat exchanger and water tank. I'm in Miami so I deal with the same 80-90 degree weather 7-8 months of the year.
      05-04-2014, 03:24 PM   #4
ASAP
ASAP's Avatar
10137
Drives: '23 X3 M40i
Piggy and meth, and all those problems r gone but I would not trust that for the guys that will want to track this car.
      05-04-2014, 04:22 PM   #5
Boss330
Boss330's Avatar
No_Country
1712
Drives: BMW
I hope you guys are just joking
Air to water cooler is a much more efficient way of cooling the charge air than a air to air intercooler.
The cooling capability of water is much higher than air (hence why we also have very few air cooled engines left...). The S55 has a separate water system that has a radiator mounted in the front, electric water pumps that circulate water from the cooler and through the chargecooler, then back to the radiator to cool down the water again.
Does the water in the intercooler system for the M5 really boil? Have never heard any M5 owner report that over on the M5 Boards...
What would be the benefit of a air to air cooler?
-Longer tubing = lag
-Lower cooling capacity than air to water
If using air as a cooling medium was better than water, I'm sure we would see a lot of air cooled engines...
Water cooling adds weight and needs more associated ancilliaries than a air to air intercooler, that's why early turbo cars had simple air to air intercoolers.
      05-04-2014, 04:47 PM   #6
ASAP
ASAP's Avatar
10137
Drives: '23 X3 M40i
Even without getting into any sort of pros and cons... what kind of IC does a 911 turbo / GTR run? Pretty much the 2 best turbo cars on this planet.
      05-04-2014, 05:04 PM   #7
Boss330
Boss330's Avatar
No_Country
1712
Drives: BMW
Bugatti Veyron uses air to liquid intercoolers...
So does McLaren in their cars...
It will be interesting to see how efficient BMW has managed to deal with heat soak and track driving, but if they can cope with that, air to liquid is the best way to cool the charge air
      05-04-2014, 05:09 PM   #8
ASAP
ASAP's Avatar
10137
Drives: '23 X3 M40i
A Bugatti Veyron, nor an M5 are track lap cars. The only convincing arguement that I would believe would be for the Mp4 but engine placement and size of the car there alone makes the liquid to air argument obvious.
      05-04-2014, 05:16 PM   #9
Boss330
Boss330's Avatar
No_Country
1712
Drives: BMW
Not quite sure what you mean by engine placement making it obvious for the 12C and not for the 911? Both have their engines in the aft part of the car. If air to air was that much better, I'm sure McLaren could have found a way for some air ducts/intakes to cool the intercoolers?
Heat soak is the main issue that air to liquid cooling has to deal with. Control that and it's the more efficient cooling medium.
One way is to use the cooling capabilities of the AC, as a way to cool the radiator and avoid heat soak... Not sure BMW has done this though.
      05-04-2014, 05:17 PM   #10
Boss330
Boss330's Avatar
No_Country
1712
Drives: BMW
The 'Ring taxi seems to cope well at the most demanding track
      05-04-2014, 05:23 PM   #11
ASAP
ASAP's Avatar
10137
Drives: '23 X3 M40i
Rear engine and Mid engine are 2 totally different things...
The heat soak comment is a big deal.
It sure does for the 1 lap that it has to finish by showing off to a few people with no timing.
      05-04-2014, 05:28 PM   #12
Needsdecaf
Needsdecaf's Avatar
6518
Drives: 2024 G80 Comp xDrive
Lag.
      05-04-2014, 06:20 PM   #13
Tonymiabmw
Tonymiabmw's Avatar
552
Yes it does boil, these system are similar in my mind to Cobra/ford GT motor. A root style super charger with a/w intercooler under. Water tank, heat exchanger("radiator") that water gets pumped thru. They are efficient but they get heatsoaked. Cobra guys put larger water tanks(also you can put ice cubes in it) heat exchangers to avoid heat soak.
      05-04-2014, 06:22 PM   #14
Tonymiabmw
Tonymiabmw's Avatar
552
Larger tank and heat exchanger which help.
      05-04-2014, 07:46 PM   #15
karbonphiber
178
Drives: 2015 AW M4
I wonder if BMW dilutes the fluid with glycol for freeze protection for all vehicles, even those that are sold in climates that do not drop below freezing as it will hinder heat transfer capacity...
      05-05-2014, 09:10 AM   #16
CanAutM3
CanAutM3's Avatar
21115
Drives: 2021 911 turbo
Very well put
I was about to post the same but you beat me to it .
      05-05-2014, 10:26 AM   #17
ASAP
ASAP's Avatar
10137
Drives: '23 X3 M40i
Very well put
I guess Porsche, Nissan, Mitsubishi and Subaru have all not figured this magic out yet. All of which build turbo track cars and have many mounds more years in turbo gas motors than BMW. My #1 guess is that this was done for product differentiation and nothing else.
      05-05-2014, 10:27 AM   #18
ASAP
ASAP's Avatar
10137
Drives: '23 X3 M40i
Lets also remember who the turbos for the N54 came from.
      05-05-2014, 10:40 AM   #19
JoeFromPA
1792
Drives: '15 AW M3 6MT Stripper
Yes, Nissan, Mitsu, and Subaru all are not as worried about turbo lag and are more focused on keeping cost down. They used TMIC air-to-air for the most part, though a few FMIC on Mitsu products are around too at the expense of...more lag.
Porsche does not have cost control issues nearly as much but do they have packaging issues in their application. They are already running max radiators at the front, use their side vents for air intake, and vent through intercooler through the rear decklid. Where are they going to stick ANOTHER radiator and more cooling hoses? And then the question becomes whether or not it would gain anything in their application.
My guess is BMW saw the primary benefit being lag reduction and cooling in this platform and decided to go for it.
      05-05-2014, 10:48 AM   #20
CanAutM3
CanAutM3's Avatar
21115
Interresting to note that the less "performance oriented" models from BMW use air-to-air intercoolers...
It is a question of specific heat properties of fluids. Water can store 3300 times the quantity of energy for one degree of temperature elevation by volume compared to air (about 4x by mass). You need a lot of "air heat" to heat soak a water system...
      05-05-2014, 11:01 AM   #21
JoeFromPA
1792
It is a question of specific heat properties of fluids. Water can store 3300 times the quantity of energy for one degree of temperature elevation by volume compared to air. You need a lot of "air heat" to heat soak a water system...
I agree with you here but I'd like to know how much of that capacity is used up just by sitting still or warming up at the track and at what rate the heat is 'bled off' when driving full bore at a given MPH.
Hope that makes sense. An air to air intercooler heat soaks easily but also gets rid of heat soak quickly. A water to air intercooler does not heat soak easily but nor does it shed heat as easily. Let's identify the rates.
      05-05-2014, 11:07 AM   #22
CanAutM3
CanAutM3's Avatar
21115
Good point. The inverse is also true, due to the high specific heat of water, once heat soaked, a water system needs a lot of air to cool down.
To prevent heat soak, usually the radiator will be significantly larger than the intercooler, hence, in principle, there is more heat extraction capability in the system than there is to add heat (temperature delta and mass flow is also part of the equation). If BMW have done their homework right (which I suspect they did), the F8X intercooler should not heat soak.
f80post
