Recommend a Tyre Inflator (Compressor)
05-08-2014, 02:00 AM | #1 |
13361
Rep 7,484
The joys of run flat tyres... I have to adjust and check the tyre pressure every 2 weeks at least.
The Halfords one I have used for 8 years is now dead. Read a few reviews on some Michellin one's but a few of the reviews were discouraging saying that it blew out after a month of use and Michellin declined to replace it / that it is not manufactured anymore. Sooooooooo... which one do you use or recommend? Thanks Last edited by Soul_Glo; 05-08-2014 at 02:00 AM.. Reason: Added Compressor to Title |
05-08-2014, 04:28 AM | #2 |
Rep 190
Ive got a ring one, was a tenner on Amazon, Dads got the digital version that was £30 iirc, done well so far. Only used it a couple of dozen times though
http://www.amazon.co.uk/Ring-Automot...xp_grid_pt_1_0 |
05-08-2014, 04:58 AM | #3 |
Rep 94
I had a Michelin compressor/inflator and it died - turned out to be the wire had become loose. My father wanted it, so gave him that one which now continues to work as good as gold.
I just bought this one: http://www.halfords.com/webapp/wcs/s...egoryId_255241 So far so good.
E90 LCI 335D MSport|Space Grey|Sunroof|Visibility|F&R Sensors|Leccy Fold Ext Dim Int & Ext Mirrors|Media Pack Pro|Voice & USB|DAB & DVB|HK L7|Black Leather|Leccy Seats|Lumbar & Heat|Type 313 19" Performance Pack Wheels|Trackstar|Protect & Care|Service Inclusive
05-08-2014, 05:36 AM | #4 |
Rep 29
I would get the Airman kit. Its the same OEM compressor as included in the BMW kit, but for less than a quarter of the price.
http://www.amazon.co.uk/AirMan-ResQ-...yre+repair+kit Can also get it with sealant for £5 more; Can always sell the sealant on to make a bit of money back and then its a bargain. http://www.amazon.co.uk/AirMan-ResQ-...yre+repair+kit |
05-08-2014, 10:48 AM | #6 |
I Can't Drive 55
129
Rep 883
Drives: 2008 BMW 335i (E90)
Garage List 2023 VW ID4 Pro [0.00]
2002 Ford F250 7.3L ... [9.50] 2008 BMW 335i [0.00] 2012 Mercedes ML350 [0.00] 2002 Toyota MR2 Spyder [0.00] |
Viair makes the BEST portable air compressors.
I've got a ViAir Model 400P Automatic that I use for back up to my CO2 air tanks, when off-roading in my FJ w/it's 33" tires, but it's probably more than you need for emergency fill-ups in your BMW. Here's a link to Viair's Portable Compressor site: http://www.viaircorp.com/portables.html. Pick the one you think will fit your needs best and then shop for the best price online.
2008 Black Sapphire 335i E90 Sport & Premium Pkgs - Cobb Stage 1+FMIC Sport map, Mishimoto FMIC & Alpina B3 AT Flash. See: My Build Thread.
05-08-2014, 12:42 PM | #7 | |
13361
Rep 7,484
- Does it take 24 hours to charge? - How long does a single charge last? - Have you checked if its accurate? - What is the battery type? Lithium Ion? Thanks There is so little information available on this. I could not even find a Michelin website with this. I wonder who makes it for them?! |
05-08-2014, 12:44 PM | #8 | |
13361
Rep 7,484
Cheers |
05-09-2014, 03:38 AM | #9 | |
Rep 94
Accuracy - I checked this against the old version (all good) and against a pressure checker (all good and well within 1 PSI). The unit also shuts-off automatically and if required, as the pressure settles, will decide to pump more air in for accuracy. You can change the unit of measurement from BAR to PSI to KPA. I am pleased with it so far.
05-09-2014, 04:14 AM | #10 |
13361
Rep 7,484
Thanks. I found out that there are two versions. One is rechargeable and capable of 10, 0-30psi cycles. I think it will be easier for me to use with the car off - no need to idle the engine to use it. No need to pass cables around or through the cabin to get to the other side.
The Viair ones definitely look robust and have outstanding reviews everywhere I look but I cannot seem to find a UK retailer. The Viair.co.uk website is insecure and there is no HTTPS protocol or anything when you put your details in so that is a no go. Shame because these probably are the best from what I read. Leaning toward the portable solution though as its tempting not to have pass cables around. Some people are saying too that it defaults to 30psi and they do not know how to set it despite reading the manual. There has to be some kind of way surely. The Viair might just win though if I can find a secure way of ordering it. Last edited by Soul_Glo; 05-09-2014 at 04:21 AM.. |
