XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
      05-03-2014, 03:37 PM   #1
kapusmd
kapusmd's Avatar
Drives: AW 135i
Back dome/map light cover?
I bought the Interior LED Light upgrade but can't figure out how to remove the map/dome light covers in the back seat to swap out the bulbs. I'm afraid to break it. Any tips or pictures?
      05-04-2014, 06:15 AM   #2
fdpxfunix
fdpxfunix's Avatar
187
Drives: X3 xDrive 30d M Sport
Hi
Take a look here for some info... http://e84.xbimmers.com/forums/showthread.php?t=666936
J.
      05-04-2014, 08:23 AM   #3
kapusmd
kapusmd's Avatar
Drives: AW 135i
Thanks. I looked at that post. I didn't see anything about removing the covers over the lights on either side of the back seats.
      05-04-2014, 05:20 PM   #4
fdpxfunix
fdpxfunix's Avatar
187
Ah.
I don't have those, just the centre dome light which includes the 2 map reading lights. I guess your lights on the side are from a different year build, or part of another package?
Gets some pics and I'm sure someone will advise.
J.
      05-06-2014, 09:53 AM   #5
Yarvis
Yarvis's Avatar
11
Drives: 2024 BMW X3 SDrive 30i
Get a small screwdriver you should see a small little notch on the top part of the light housing. Place flat blade in notch and push, there is a clip holding light module in place. Once you push and pull out module you simply unscrew the bulb from its housing and install the new bulb. Easy.
"Life is what happens to you while you're busy making other plans"......John Lennon
Tags
interior bulbs, interior led, interior light, led interior dome issue
xbimmers
