Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Is 2 second cold crank considering a sign for failing HPFP?
      04-30-2014, 10:55 AM   #1
Cloud9blue
Cloud9blue's Avatar
711
Drives: around the potholes
Been noticing the car took a little longer to crank in the morning on some days. Before it would fire up within a second, but now on a few occasion it take 2-4 turns (about 2 second) before firing up, and doesn't seem to be directly related to ambient temperature either. Idling is still smooth, and the car pulls like a train like it always been in the last 5 years.
The car is still on original pump (car was built in Nov. 08, with 32k miles), the dealer wanted to do the pump and injector recall a few years ago, but I told them to hold off as I never had any problem with it.
The car only have a JB4 and pump gas backend flash on it, just had the intake valves walnut blasted two weeks too. Not sure if it is anything to worry about.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins
19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization
      04-30-2014, 10:56 AM   #2
JStang
JStang's Avatar
562
Drives: FDB M3 CS
The car is still on original pump (car was built in Nov. 08), the dealer wanted to do the pump and injector recall a few years ago, but I told them to hold off as I never had any problem with it.
The car only have a JB4 and pump gas backend flash on it. Not sure if it is anything to worry about.
It could be a sign of the HPFP going. Could be a leaking injector too. I have had long cranks for a year or so now and I've just lived to learn with it.
      04-30-2014, 11:02 AM   #3
Tiago@VRSF
Tiago@VRSF's Avatar
2095
Drives: F90 M5
That's a pretty good sign. Take the JB4 out and bring it to the dealer and get them fixed while you can
      04-30-2014, 11:04 AM   #4
AlpineSwift
AlpineSwift's Avatar
77
Drives: 2008 335Xi Coupé
Could also be a weak battery. Check your voltage. Every time my 328 started having long crank issues, it ended up being the battery.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile.
      04-30-2014, 11:08 AM   #5
Cloud9blue
Cloud9blue's Avatar
711
That's what I plan to do too. But I haven't been able to get any sort of codes (no misfire, pump codes, etc.), even when I tried E30 a few weeks ago, the logging show no sign of fuel system problems.
From what I read, most dealers are hesitant to do anything about it unless the ECU starts to throwing out codes.
      04-30-2014, 11:13 AM   #6
Cloud9blue
Cloud9blue's Avatar
711
I actually just replaced the battery just about a month ago though, as I drained the old battery completely when flashing the backend map. It was more than 5 years old, and with the weather around Chicago, I replaced it with slightly replacement battery from Autozone just to be on the safe side. Battery was registered/reset via the BT cable that I have.
There was a slight hesitance in cold crank before the battery replacement, but the problem seems to gotten worse in the last 2 weeks. Will check the voltage tonight just to be safe.
      05-12-2014, 01:32 PM   #7
Cloud9blue
Cloud9blue's Avatar
711
Well, the crank seems to went away completely after I burn through a tank of gas and fill up the newest one with 30/70 e85/93 mix. I did put techron fuel clearner in the previous tank, maybe that was causing the problem...
      05-12-2014, 02:04 PM   #8
135Pats
135Pats's Avatar
456
Drives: A few BMWs
The E88 has been taking its sweet time starting recently, it’s intermittent and only on a cold motor. Takes a full second or two to turn over, it cranks right away. The HPFP has about 2-3K miles on it, so I really, really hope/doubt that is the issue.
I’m still on the stock battery, so perhaps that’s it? But I’ve never gotten a low battery warning before, seems odd it would happen like that.
If it’s the fuel pump, I’m gunna be pissed. Spent a month, about $2K, and 4 tow truck calls trying to get that nonsense sorted out.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII
      05-12-2014, 02:43 PM   #9
chepy24
chepy24's Avatar
30
Drives: 2009 alpine white 335i xdrive
possible the mix of the gas? i was low on gas (less than a quarter tank on an e30 mix) and got this lame snow storm yesterday and car took a little longer to crank filled it up and this morning (more snow and cold temp same as yesterday) car fired right up
