BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Short commute
      04-26-2014, 08:32 PM   #1
PGabriel
15
Drives: M3 E90
Short commute
Hi.
I just got a new M135i. Once I learned that driving the car for short periods daily can eventually lead to a damage, due to inadequate gasoline heating time. Since my commute is very short, will I have trouble in the future using the car this way?
      04-27-2014, 04:14 AM   #2
spoonflames
Harvesting Information
spoonflames's Avatar
Drives: White M135i 5dr
Hi I was not aware of this. Can you tell me more about this?
My commutes are also short which is why I changed from 125d to m135i
      04-27-2014, 05:26 AM   #3
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
If you keep rpm below 3.5k and dont give 100% throttle the first 10 minutes its np.
      04-27-2014, 05:34 AM   #4
Bob UK
11
Drives: 2013 X1 18d X-Drive
Short runs where the car (Any fuel type) does not get properly warmed up can cause problems which is why it's a good idea to take it for a decent run on a regular basis if your normal use is short runs.
120d Sport gone and replaced with X1 18d XDrive MSport Auto.
No Xenons but plenty of creature comforts.
      04-27-2014, 05:38 AM   #5
PGabriel
15
Drives: M3 E90
The problem with a short journey is that the engine never reaches its operating temperature. The engine oil needs to reach its optimum viscosity to properly lubricate the main moving components in the engine. While cold the catalyst is unable to operate at peak efficiency thus reducing the life of your expensive catalyst. The combustion process does not become efficient until the engine reaches its operating temperature. An inefficient burn leaves acids and other toxins that eat your engine.
      04-27-2014, 05:40 AM   #6
PGabriel
15
Drives: M3 E90
The questions then is: HOW LONG using the car this way will it take to start getting trouble?
      04-27-2014, 06:57 AM   #7
ovekvam
Norway
266
Drives: 2021 Galvanic Gold i3S
I don't think the short commute is more harmful than the first 15 minutes of a long drive, but if you only drive like that that, you will never be able to take advantage of the potential of the car, as you will/should always be driving very careful.
The car will also have few miles on it, but the same wear as a long miler. The next owner of the car will probably still pay extra for the short mileage, though, not thinking about the disadvantage.
      04-27-2014, 08:05 AM   #8
PGabriel
15
Drives: M3 E90
Sorry, maybe I made myself misunderstood, my commute is short but I also drive the car for longer periods e.g. travels
      04-27-2014, 02:53 PM   #9
Bob UK
11
Should be fine then.
      04-27-2014, 03:23 PM   #10
HighlandPete
6659
Drives: BMW F11 535i Touring
Hi.
What mileage is your short commute? Does the oil temperature get to a decent figure, or hardly off the stop?
HighlandPete
      04-27-2014, 05:29 PM   #11
PGabriel
15
Drives: M3 E90
HighlandPete
2 km...
On my Tiguan the temp gauge needle does reach the operational level. Don´t know about the bimmer since i haven´t picked her up yet :-)
      04-27-2014, 09:55 PM   #12
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Well, you'll never know, 'cos the M135i doesn't have a temperature guage.
2k commute? That's surely a good walk, in my books...although, having just come back from Brazil, there are 200m walks in Sao Paulo that I'd prefer to take a taxi for, rather than on foot
      04-28-2014, 12:38 AM   #13
ovekvam
Norway
266
My commute is also 2 km. I haven't used the car for this commute for several years. I use my bicycle. Last time I couldn't use the bicycle, due to 85 cm of snow, I used my cross country skies.
      04-28-2014, 04:00 AM   #14
HighlandPete
6659
2 km...
I see why you are concerned, that is no distance for any engine, let alone a 3.0 litre.
I'd imagine you are not going to reach much more than 40C ECT, unless you are in very high ambient temperatures.
I hate using my 535i for the grandson's school run, (4 x 1 mile, a couple of times a month), but at least they are mixed with longer runs.
Personally I see any run which doesn't get the engine to full heat soak is really too short. That is 10 - 12 miles in my model, even more distance in winter temperatures.
HighlandPete
      04-28-2014, 07:23 AM   #15
Ryanponti94
Drives: C2 1.4 HDI 74avg mpg mmmmm
Would you say doing 2x 12mile journeys Monday to Friday with a mix of 1-4m journeys throughout the week be bad for a m135i?
19 and Dreaming of his first BMW....
Currently: C2 1.4 HDI Slow but cheap to run
      04-28-2014, 07:44 AM   #16
ILUSV
ILUSV's Avatar
17
Drives: 2014 M135i
Excellent thread, I have a 2 mile commute as well. I try to take the car for an extended drive at least 3 times a week. I've finally hit 2000KM as well so I've been doing some nice pulls once properly warmed up (giving the car 15 min to warm up). The only thing I'm banking on is the Heat... It’s already 105F here (Saudi Arabia)... much different that Portland, OR
      04-28-2014, 08:23 AM   #17
Honziss
Drives: F20 116d + E81 116i
I guees that critical is number of cold starts per some milage. Every cold start is bad for engine, but it's a big difference if you drive after 200kms on highway or 2kms in the city. My 116d is reaching 90'c oil temperature after 25kms of calm highway cruising when i leave my home and ambient temperature doesn't matter so much..
      04-28-2014, 08:28 AM   #18
ILUSV
ILUSV's Avatar
17
Drives: 2014 M135i
So starting an engine in 100 degree weather the same as 32?
      04-28-2014, 08:51 AM   #19
Honziss
Temperature
Basicaly, as lower starting temp is, then longer you need to heat it up. In my case I'm starting from garage which is under the building, temperature range there is 5'C in very cold winter to 20'C in summer and it nearly doesn't influence heating time. It's more influenced by style of driving, road profile, traffic ahead, startstop on/off.
      04-28-2014, 01:17 PM   #20
ovekvam
Norway
266
Heating the car stationary at idle is not good for the car. It gets up to operating temperature faster if you start driving (gently) right away.
      04-28-2014, 01:31 PM   #21
SteveC
220
Drives: M5
Just enjoy your car
Stop worrying and simply start enjoying your new car
If you do lots of short trips just change your oil more often. Your on-board service monitor will adjust the service interval to compensate for lots of cold starts. The biggest problem with short trips will be fuel consumption, due to the fact the mixture is enriched when the engine is cold.
A diesel does have an issue with its particle filter blocking but I'm not aware of any similar issues with a petrol car, other than the oil contaminating more quickly.
      04-28-2014, 04:24 PM   #22
Bob UK
11
Cat poisoning is the danger with a petrol and short running and an expense on a par with a DPF replacement.
1addicts
