Shift linkage issue, or worse, transmission
04-26-2014, 08:44 AM | #1 |
226
Rep 1,064
Edit 4/28: Solved, clips holding the linkage in place were not in place. They were lying on top of the transmission long enough for one of the pins to back out and cause the linkage to operate incorrectly.
While driving home the other day, from 1-2 it did not engage 2. made a sound so I went to 3 and pulled over. Something is bent or broken in the shift linkage or transmission and the car has 61k miles. It will engage R-1-3-5 but cannot engage 2-4-6. While in gear 1-3-5 the shifter will move around, but the gear stays engaged. To disengage 1-3-5 you must pull the shifter way down almost where 2-4-6 would be. I pulled the shift boot off to look at the shifter ball joint and it looks good. I also got under the car but could not get a good look at the linkage, since it is on top of the transmission. I could just see the under side of the shifter. I am towing it to an independent shop for them to look at it on Monday. I am just hoping it is not major. Has anyone had this issue (I searched and found little to nothing)? What parts must be removed to get to the shift linkage where it attaches to the transmission, will the interior be stripped, or must the trans be dropped? Any ideas? Thanks for the input, I am just trying to get through this and get back to enjoying the car. (Warranty notes, since I passed on buying an extended warranty, this is out of pocket. This will be the first repair outside of warranty. If my total repairs over the extended warranty period exceed the warranty cost, I did it wrong. I am hoping on the other way around of course, but this is not a good start.) Last edited by mxa121; 04-28-2014 at 05:57 PM.. |
04-26-2014, 07:54 PM | #2 |
101
Rep 535
That sucks. Really strange thing to have happen. Whenever i read threads about people having trouble with their automatics, it makes me glad i have the manual. Hope it works out for you.
04-27-2014, 05:53 AM | #3 |
17315
Rep 18,737
When I first started reading this I was thinking the syncro for 2nd was toast, but after reading the whole explanation, I think something broke in the shifting mechanism. It might be a bit pricey to fix. The shop will have to remove the exhaust, heat shields, and drive shaft to get to the shifting mechanism. Sounds like its time for a short shift kit too.
04-27-2014, 06:08 AM | #4 | |
58
Rep 665
Hopefully it's just a linkage-related issue. I don't know for sure, but my guess is the shop will only need to drop the rear tranny mount and driveshaft to get to the linkage and not the entire transmission. In the unlikely even they do need to drop the transmission you may want to consider replacing the clutch at the same time since you will have paid for the bulk of the labor required to do so already. Good luck and let us know the outcome. I don't think I've heard anyone mention your particular problem before.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
04-27-2014, 09:18 AM | #5 | |
17315
Rep 18,737
04-27-2014, 09:30 AM | #6 |
226
Rep 1,064
I will have it at the shop on Monday.
Hopefully they only have to remove the exhaust and driveshaft and not the transmission. I had not thought about replacing the clutch or short shift kit while it was open, really just trying to minimize damage on my wallet at this point. I will keep you updated on the results in case this ever happens to someone else. |
04-27-2014, 10:00 AM | #7 | |
17315
Rep 18,737
04-27-2014, 08:27 PM | #8 | |
226
Rep 1,064
Is SSK worth it? |
04-28-2014, 06:02 PM | #9 |
226
Rep 1,064
The shop called today and solved the problem.
First question, "Who's been working on your car?" Some securing clips on the linkage were removed, and lying on the transmission. They were out of place allowing a pin to wriggle free and cause the linkage to operate incorrectly. They replaced the clips and boom, shifts like a dream. I just did the 60k stuff at a different shop and they were underneath the car quite a bit, but they should not have touched the linkage. I am debating whether I should discuss it with them, but there is no proof that it is their fault that the clips were not attached. The mechanic that replaced the clips mentioned they are a tight fit and could not just fall off from driving. Even without proof, I have lost confidence in the last shop that worked on my car. Shame. I'm out a couple hundred bucks for a small little issue. Glad it was just that. |
04-28-2014, 06:23 PM | #11 | |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Thanks for the follow up good to hear it wasn't serious.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
