Tire help needed!
04-25-2014, 08:32 AM | #1 |
Rep 75
Drives: 2009 BMW 328i
Tire help needed!
Hi everyone! Sorry for posting here but no one was able to help me in the Tire/ Wheels forum.
I have an e90 LCI with 205/55/16 Continental RFT with 282 rims(hideous, I know). I was looking for new wheels and found some on craigslist(pictures below) $500 for the set, does anyone know the style? They are 17" but I don't think they are RFT. My question is, can I use conventional tires on my 09 328i (LCI) and can I use my TPMS from my current tires? What problems can I run into? A local European shop that specializes in BMW's quoted me to mount them at $98 for all 4 tires. Thanks for your help guys! Here are the pictures of the Wheels, anyone know the style? |
04-25-2014, 08:42 AM | #3 |
1792
Rep 4,216
you can definitely use non-rft tires on your 328... I would recommend them in a heartbeat. You should also be able to use your current TPMS on new wheels.
According to http://felgenkatalog.auto-treff.com/ that 5er wheel style is 138, and the offsets will most likely be different compared to your stock setup. Also ensure that if your car is RWD, you get a set from a donor car with RWD (for the staggered setup). AWD donor wheels will result in a square setup, which may not work well if your car is RWD. There used to be an offset calculator on the wheels and tires section of the forum, but can't seem to find it at the moment.
2020 F87 M2 Competition /l\ LBB /i\ Executive Package 2013 E70 X5M /l\ Space Grey /i\ Full Silverstone Leather /l\ LED Headlights /i\ Comfort Access /l\ HUD /i\ Ventilated Seats /l\ 22" BBS SV BMW CCA Member |
04-25-2014, 08:44 AM | #4 |
Captain Dutch Rudder
204
Rep 2,258
Style 138 off an E60. 17" x 7.5"
You can run your TPMS and you will run into basically no issues with conventional tires. I made the switch about a year ago and never looked back.
No more E92 or E82
04-25-2014, 08:48 AM | #5 |
Rep 75
The seller told me they are from an 07 so I'm thinking it's either a 3er or 5.
Would I have to do anything to the car (raise it/ lower it) in order to accommodate the 17", currently have 16". Sorry I'm new to this. |
04-25-2014, 08:55 AM | #6 |
1792
Rep 4,216
no raising or lowering to accommodate a different size wheel. What you will need though is the right profile/width tire combinations. If you search around, you can find the appropriate tire sizes for 17", 18" and 19" setups. If you're going through the whole process of sizing up, I'd recommend an 18" setup. You'll probably want to after a month of seeing your car in 17's.
04-25-2014, 11:04 AM | #7 |
69
Rep 1,766
Get 18" in non-RFTs. With that combo, you can't go wrong in the looks and performance dept.
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
04-25-2014, 11:26 AM | #8 |
Rep 75
Anyone know if I can use wheels from a 2013 328i?
04-25-2014, 04:52 PM | #9 |
Rep 12
Beware....
I wasted a whole Saturday on trying to get a replacement pair of Run Flats through Craigslist here in the Atlanta area. Needless to say I won't be doing it again. First advert I went to was a pre-owned sales place with some service. The guy rolls out the two Conti RFTs. I look them over and one of them has a great big nail sticking through it. "Oh yeah" says the guy. "You can get it repaired". It was clearly to darn close to the tread edge so he must have taken me for an idiot (maybe I was, using CL!). No sale! Next, on to a dingy place stacked high with used tires. This time I couldn't find a problem so bought the pair. However.... On getting home and into proper light, and feeling very carefully inside the tire, lo and behold, another bloody nail. Not so big and hidden in the treads, but poking through none the less. Drove back, got my money back and vowed not to use CL for used tires again! YMMV |
04-25-2014, 05:06 PM | #10 |
56
Rep 425
Non-RFT ride better. Just be sure to throw a fix-a-flat can or some other tire repair kit in for worse case scenarios.
E92 335XI M-Sport - BSM, CR, 6MT, KW Variant 3, Cobb V3, PSS, ETS Charge Pipe and BMS Intake
04-26-2014, 12:00 AM | #11 |
14
Rep 213
Drives: 2014 550. 2015 x328d
Garage List 1972 Mustang Mach 1 [0.00]
2012 Electra Glide ... [0.00] 2017 Premier [0.00] 2022 Genesis GV70 [0.00] 2014 BMW 550I [0.00] |
Make the switch
The best thing I did was get rid of my RFT, they suck.
04-26-2014, 05:45 AM | #13 |
2809
Rep 5,316
Drives: G80 M3 6MT
You can definitely use 2013 3 series wheels, I have a pair on my car.
As for those wheels they are from a E60 5 series |
04-26-2014, 08:40 AM | #14 |
Rep 75
I think it's going to be a really tight squeeze!
04-26-2014, 02:23 PM | #15 |
Fuck it dude, let's go bowling.
886
Rep 2,480
I hope you get your wheel/tire situation sorted. It can be time-consuming finding the right setup, especially a used one. Good luck!
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
04-26-2014, 03:37 PM | #16 |
Rep 75
Was able to try one on before buying, picture below. It didn't rub, anything else I should look for before buying?
