New Item for F22 M235I - Challenge Stainless Steel Brake line kit |
04-24-2014, 02:40 PM | #1 |
270
Rep 2,946
These are the first set we just finished up. We will be keeping this on the shelf for all you M235i guys. Our F30 customers that have essentially the same brakes report much better pedal feel and more linear pressure. Same attributes were reported by our F10 M5 customers as well. A must for anyone taking their car to the track or just wants smooth consistent braking coming into the turns on spirited drives! This full stainless steel line kit for the M235i replaces all your flexible brake lines on your performance car. We retained the stock line configurations and mounting points for an OEM quality fit and finish. Challenge uses stainless steel braided TeflonŽ hoses. Each line has a clear coating protecting it from any of the elements. Stainless steel braided TeflonŽ brake lines will not expand or contract under braking. This results in a vehicle with less brake pedal travel, without locking the brakes. All parts and components are DOT approved. Made in USA and includes lifetime warranty! MSRP: $115.00 Please contact us or any Challenge dealer with questions! Last edited by GTM_Challenge; 04-24-2014 at 03:11 PM.. |
04-25-2014, 08:10 AM | #3 |
102
Rep 775
More than likely will be an upgrade for me shortly. Waiting on some funds to clear up before my next big stage of this platform
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
04-25-2014, 08:42 AM | #4 |
63
Rep 142
When you mention better brake pedal feel, you mean less "mushy" with a bit more resistence? I haven't received my car yet, but when I tried it did not like the brake pedal feel (too mushy and long) nor the clutch (too light).
Actually, is there anything that can be done to add "weight" to the clutch? Thanks |
04-25-2014, 10:21 AM | #5 | |
270
Rep 2,946
04-25-2014, 12:52 PM | #7 | |
270
Rep 2,946
We can ship lines to the UK for super cheap. $12! We'll have a downpipe shortly followed by muffler and mid pipe. Lip and diffuser also on the drawing board |
05-06-2014, 10:55 AM | #9 |
1913
Rep 4,128
Drives: M235i & G30 540i
Always a good mod to add. The feel is always so much better and induces more confidence.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
06-05-2014, 11:00 AM | #11 |
40
Rep 176
Do you know where I can find some reviews of this upgrade? Can I ask my dealer to install them?
I'm interested to slightly upgrade my brakes on the car (new fluids, pads...) to get more confidence on the road and on the track. |
06-05-2014, 11:08 AM | #12 | |
270
Rep 2,946
Your dealer should have no problem installing them as they are a full bolt on part. |
07-02-2014, 08:27 AM | #15 |
105
Rep 212
Thanks. You may want to place this data on your product page
http://challenge-usa.com/blog/produc...ake-line-kits/ |
07-02-2014, 10:23 AM | #16 | |
270
Rep 2,946
07-07-2014, 08:47 AM | #18 |
270
Rep 2,946
Installation time should be about 1 hour labor time plus the cost of brake fluid swap/bleed. That can vary shop to shop and also depends on the type of fluid you choose to use.
08-25-2014, 11:52 AM | #20 | |
270
Rep 2,946
Maybe other companies are using a universal photo instead of photo of the actual part? I assure you there are only the 4 lines on this car to be replaced. A few of the older cars from the E chassis series did have 6 lines though. You can see in the oem diagrams below that the only rubber lines are the ones we include with the kit. All others are hard lines in the factory brake system. Front: Rear: |
