am i the only one scared?
04-23-2014, 05:49 AM | #1 |
13
Rep 198
I got my 08 335i about 2-3 weeks ago, the more i read on this forum and the more i drive i get more and more scared that something is gonna happen to the engine, let it be the thermostat, the hpfp, coolant leak, and on and on and on.... im pretty sure i just got a coolant leak somewhere in the car, every week or so often the floaty is all the way to the bottom.
I was thinking on further modding this car but now im thinking that i have to save A LOT for these kind of repairs |
04-23-2014, 06:57 AM | #5 |
2050
Rep 6,110
You can't be paranoid. Your initial plan is good. Just set aside some money for repairs and enjoy the car. Once an initial cushion is built, then you can mod to your liking. Good luck and just enjoy the car!!
(And fix the coolant leak)
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
04-23-2014, 07:02 AM | #6 |
Came to the N55 Darkside
1112
Rep 12,740
If it makes you feel any better, no one posts on the forum, or at least hardly ever, that their car is running perfectly and they're so in love with the reliability.
Often, it's usually to get help with a problem, so statistically the possibilities of failure are exaggerated, and skewed in my opinion. That said, I would not own an out of warranty N54 BMW- or any BMW for that matter- out of warranty- repairs can get expensive quickly. Bottom-line: 1) Keep a fund aside, in case things happen. 2) Always factor in the true cost of ownership for a vehicle. 3) If you got the car from a dealer, pony up for a PPI, and ask questions. If you got to car from a private sale, hit the owner up for questions- ask if you can get the car checked by independent mechanic before the sale. You never know how that previous owner treated the car, and that, in turn, may significantly impact your ownership experience. 4) If you keep up on your routine maintenance to the letter, more often than not you'll find your car will continue to serve you well. My dear old grandmother - rest her soul- used to have a saying- "control the things in life you can (your reactions to life events, the relationships you hold, the decisions you make, the chances you pass up or take) and leave the rest to [-> insert whomever or whatever you believe in here.] Spend more time preparing before hand as best you can, and enjoying your car- and less time worrying about things that may never materialize. Good luck! |
04-23-2014, 07:20 AM | #7 | |
13
Rep 198
04-23-2014, 07:45 AM | #9 |
I'll get back to you
7560
Rep 2,132
Maybe should have done a little more research before buying a seven year old car?
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
04-23-2014, 07:46 AM | #10 | |
14
Rep 1,203
Drives: '11 STI, '90 325iS
Be on the ball, do your maintenance on schedule. Read. Learn. Do. DIY when you can.
04-23-2014, 07:52 AM | #12 |
13
Rep 198
04-23-2014, 08:13 AM | #13 |
15
Rep 123
I came from the world of Subaru's where blow head gaskets were our best friends. Mine is at 138k miles and going strong and even on the original clutch.
If you treat your car right it will work forever. Beat the crap out of it and well things can wear out quicker. Best plan is always find the maintenance schedules and stick to them. Then know a local shop in case of an emergency. |
04-23-2014, 08:14 AM | #14 | |
13
Rep 198
04-23-2014, 08:37 AM | #16 |
Curmudgeon and Pedant
690
Rep 3,489
I just want to point out that virtually ALL the problems with these cars are not oil-related. How is changing the oil every 5K going to fix a HPFP, thermostat or water pump, coolant leak, or electronics failure? Answer is: they aren't, you're wasting your money on 5K oil changes. At least go to 7500 for crissakes.
04-23-2014, 08:50 AM | #17 | |
13
Rep 198
04-23-2014, 09:16 AM | #18 |
Rep 112
small case of buyers remorse?
like most have said, theres a maintenance schedule for your car to follow. keep to that, and your and your car should be best friends for awhile. there will be problems along the way just like any car. |
04-23-2014, 09:31 AM | #20 | |
13
Rep 198
again ppl keep talking about maintenance schedule but no one is telling me what maintenances are due when |
04-23-2014, 09:40 AM | #21 |
148
Rep 563
I wouldn't worry too much. I bought my 07 335i almost 2 months ago. Still on original fuel pump and injectors. Turbos were just replaced under warranty along with water pump, coolant expansion tank etc, and car still runs flawless. Yes I am also surprised that its still on the original fuel pump and injectors. Guess I'm one of the lucky ones. Oh and I just hit 81k miles. Happy owner over here.
04-23-2014, 09:42 AM | #22 |
148
Rep 1,100
You have to realize that this is a forum, where people share information- this means sharing problems they have and asking for helping. Therefore you are exposed to a lot more failures.
This forum is only a small population of 335i's. There are tons out there, some of which probably don't have any issue. Just stick with your maintenance plan and all should be good. Cars are meant to be driven!
2010 335i Coupe- Monaco Blue Metallic
