Thermostat is Out
04-22-2014, 01:23 PM | #1 |
Rep 120
Thermostat is Out
Hi all,
So my thermostat has been diagnosed with being the cause of my Service Engine Soon light. I brought it into to get it repaired today, but some people suggest to get the waterpump replaced at the same time. However, my water pump is not the reason why the car is shooting out the code, and my car is sitting at 66k miles at the moment. Dear owners, would you recommend getting the water pump changed as well? Right now I'm quoted around $400 to fix the thermostat, and around $1000 to do the whole thing. |
04-22-2014, 01:45 PM | #3 |
30
Rep 644
$1,000 is a great price for water pump and thermostat on a 335i. I assume it includes new coolant.
You should do it. With a 2007 335i your pump could go out anytime in the next 130,000 miles but will probably go out withing 5,000 or getting your thermostat replaced. I just did mine at 100k and it was working perfectly. I was just tired of toying with the BMW water pump gods. |
04-22-2014, 01:49 PM | #4 |
23
Rep 322
What's the cost for a waterpump replacement only? Ask for a quote on paper so you can refer to that in the future. If it is significantly more than the difference, yes. If not, then keep driving. Do you live far from the dealership? If so, spare you the time and get it done now. Do you plan to keep the car for a while? If so, better enjoy the investment now. If you plan to sell it in the next 30k miles, leave it, you might be lucky...
04-22-2014, 01:50 PM | #5 | |
27
Rep 199
it's all the same work.. and would be cheaper in the long run to get it changed all at once... these WP are tricky anyhow.. it could go out at anytime and there is no min or max mileage to it. |
04-22-2014, 01:51 PM | #6 |
Rep 120
I know the nephew of the owner of the shop, but the shop itself is around 10 miles away. I think it would cost another $800 to fix the waterpump by itself.
Essentially, I'm gambling an extra $200 on the next 5k-10k miles. Which is probably around another year for me. @Fortyb I don't trust my own mechanical skills. With a car like this, I would rather not do my own work on the engine. (First big investment post-college) |
04-22-2014, 01:55 PM | #8 |
80
Rep 1,076
Drives: 07 335i e93 6MT
My tstat was throwing a code too so was planning on just doing the t stat myself and not the water pump but everyone does say just do it together since they are both together and pump will go out sooner or later. However, after a couple month of driving, the t stat code went away and I'm on day 5 with no code and oil temp warms up quickly. Not sure what's going on. I have the t stat ready to install but might just wait till the pump starts to fail and do it all together
07 BMW 335i E93 6MT (Praying neighborhood doesn't get flooded...again) 04 Infiniti G35 Coupe 6MT (Flooded) 08 Audi TT 2.0T DSG (Flooded) 03 Subaru WRX 5MT (Flooded) |
04-22-2014, 02:17 PM | #9 | |
23
Rep 322
04-22-2014, 02:38 PM | #10 | |
Rep 120
04-22-2014, 02:42 PM | #11 |
70
Rep 628
Change them together, will save you the hassle for going through the process again, not sure if just because the thermostat failed the pump will eventually fail, but its good measure to do both, did the thermostat failure leave you stranded? Because I know if the water pump fails it will.
04-22-2014, 02:44 PM | #12 |
1855
Rep 2,554
If you don't replace it now. You'll be taking it back very soon to get it changed. I recommend getting it done now. And I also recommend doing it yourself to save some cash but that's your call.
04-22-2014, 03:01 PM | #13 |
30
Rep 644
When the pump quits, it is usually quick. Your radiator fan will go on full blast then about 10 seconds later you will get the yellow over temp light, then about 20 seconds later you will get the red over temp and go into limp mode. In heavy traffic you will be stuck where you are. That will suck for you and all of those other commuting Schlubs. You will not make any friends.
04-22-2014, 03:04 PM | #14 |
Rep 11
Our thermostat went out two years ago at about $300. A month later the water pump went, about $600. Do them both together and save your time, which is worht something. I'm a gear head, but my understanding is that the thermostat and waterpump are electronic (really? What's wrong with the good old $5 thermostat and $80 belt driven water pump - Oh well). I suggest you do both at once! Zuti
04-22-2014, 09:19 PM | #15 |
17314
Rep 18,737
I disagree about changing the water pump if only the t-stat needs replacement. It is not the same labor cost to replace both the t-stat and water pump if only the t-stat is bad. The t-stat is an $80 part and comes off without removing the water pump. The water pump is a $400 part and requires removal of the t-stat, which is why you DO save labor replacing the t-stat when the water pump is bad. The water pump usually throws codes that do not trigger the SES light, but are recorded in the ECU and readable with a BMW scan tool. There is no set mileage when the pump may go, so replacing it preemptively is a crap shoot IMO.
I would have the car scanned first to see if the pump has been throwing codes before I replace it. |
04-23-2014, 01:24 AM | #16 | |
964
Rep 3,854
Drives: 330i, 135i
